March 25th, 2012, 07:06 PM | #1681 |
March 25th, 2012, 07:25 PM | #1682 |
Join Date: Oct 2011 Motorcycle(s): 1999 Kawasaki ZRX1100, 2006 Yamaha R1, 2006 Kawasaki ZZR600, 2009 Kawasaki Ninja 250R, 2017 Kawasaki Z900 Posts: 320
March 25th, 2012, 07:34 PM | #1683 |
Join Date: Apr 2011 Motorcycle(s): 2011 Green 250R Posts: 346
Finished my last winter mod. A Vortex 15t sprocket, along with
Area P Bryson hugger grips bar ends V-Grill Engine cover black fairing bolts Pro-Tec front & rear pegs Tri's Flushmounts along with mini turn signals under front cowl Seat Cowl |
March 25th, 2012, 07:41 PM | #1684 |
Super Noob
Join Date: Oct 2011 Motorcycle(s): '09 Kawasaki Ninja 250R, '84 Honda Spree 50cc Posts: A lot.
Nice mods bro and nicer bike If you wouldn't mind sharing...where did you get the bolts and engine cover?
March 25th, 2012, 08:03 PM | #1685 |
the bolts came from http://www.sportbikebolts.com/ they sell complete kits but someone else on here had bought the kit but the bigger fairing bolts weren't the same sized heads. I ended up just buying individual bolts and just replaced all the smaller sized bolts. One thing is the hex head tool is one size smaller than EOM size but same size bolts.
The V-Grill engine cover came from Wayan in Indonesia, I bought it thru him and he shipped it with the Bryson Hugger GB. |
March 25th, 2012, 08:21 PM | #1686 |
Join Date: Aug 2011 Motorcycle(s): 2009 Ninja 250r (Sold), 2009 FZ6, 2015 Honda Grom Posts: 898
We should go ride soon.
March 25th, 2012, 08:28 PM | #1687 | |
Super Noob
March 25th, 2012, 09:14 PM | #1690 |
Race bodywork is lighter, usually made of carbon fiber instead of ABS plastic, usually comes unpainted, has no heat shields because CF doesn't melt, often has no headlight, turn signal mounts, mirror mounts, or tail light cutouts and usually requires you to make your own mount points if it does (some have an outlined area to cut if you want), can hold two quarts of oil in the lower belly pan fairing so that you don't blow oil on the track and take out other riders, etc.
March 28th, 2012, 08:48 PM | #1691 |
Join Date: Mar 2012 Motorcycle(s): 2011 Ninja 250R Posts: 3
I bought one!
It's a 2011 250r, limited edition, in green. And now, it's time to learn to ride it.
March 28th, 2012, 09:30 PM | #1692 |
learning stages
Join Date: May 2011 Motorcycle(s): black 09 kawasaki ninja 250 Posts: 284
Spraypainted the exhaust off my 2K9. Black with silver tip. Looks current now. I rather not get a new exhaust for it. I like the SS sounds.
March 29th, 2012, 06:00 AM | #1693 |
Attempted to install new jets and failed miserably.
I removed the carbs, put in the new jets, reinstalled the carbs. Now the bike dies as soon as I turn it on. Decided I'm going to let a pro finish the job, so I called the shop. They don't have an opening until April 20th. So no Ninja until then. |
March 29th, 2012, 06:06 AM | #1694 |
#squid
Join Date: Jul 2011 Motorcycle(s): Track dedicated 2008 ZX6R Posts: A lot.
MOTM - Jul '16
I tightened my chain, and adjusted the rear suspension and idle
March 29th, 2012, 08:01 AM | #1695 |
Join Date: Feb 2012 Motorcycle(s): 2003 Ninja 250 Posts: 91
I slid sideways at 45mph. The car in front on me hit the brakes hard trying to turn suddenly so I had to brake hard downhill, my rear tire started sliding, I released the brake applied throttle and eased past them.
March 29th, 2012, 10:27 AM | #1696 | |
March 29th, 2012, 11:01 AM | #1697 |
Benji, did you make sure the carb bowls were filled before starting it?
Try starting it now, and see what it does. That's always my biggest problem, not filling the carb bowls enough, so I always wonder why in the world my bike won't start |
March 29th, 2012, 11:27 AM | #1698 |
Yeah, they are full. I'm just going to wait. I don't want to ruin anything. Seems to me like I'm going to be spending more time on my bicycle.
April 3rd, 2012, 08:10 PM | #1700 |
CVMA #717
Join Date: Apr 2011 Motorcycle(s): '09 Ninja 250, '12 BMW s1000rr Posts: 28
Finally met up with another Ninja 250 rider (he was on a meetup group, but I told him about this forum). Took him on his first trip to a historic riding location here in the canyons of SoCal.
Do, or do not. There is no try. |
April 3rd, 2012, 08:52 PM | #1701 |
Join Date: Jul 2011 Motorcycle(s): 2010 250R FI, 2006 ZX10R Posts: 175
redesign my ninja.. my crew did most of the part
more color to add on.. before slap on stickers all over my bike
I'm Selling wider (4.5" & 5") aftermarket Wheel for N250r/N300r/Z250/Z250r |
April 4th, 2012, 12:23 AM | #1702 |
Join Date: Dec 2008 Motorcycle(s): 2010 Ninja ZX-6R Posts: 211
Put an M4 Slip on on it
April 4th, 2012, 12:26 AM | #1703 |
It reminds me of Eddie Vanhalens guitar.
April 4th, 2012, 01:17 AM | #1704 |
Join Date: Dec 2011 Motorcycle(s): 2009 Ninja 250R SE Posts: 767
April 4th, 2012, 09:12 AM | #1705 |
Blue Shell magnet
Join Date: Aug 2011 Motorcycle(s): 1997 Ninja 250 Posts: 816
April 4th, 2012, 09:50 AM | #1706 |
Nice, @wandyhee! Even the simple stuff, like the colored side panels, are a nice touch.
April 7th, 2012, 06:48 PM | #1707 |
Super Noob
I installed my A&L rear-set adjusters, still working on finding my sweet spot, but they've already made my riding posture so much more comfortable and sporty
Also went ahead and put Tri's front cowl LED signal light strips. They are bright and increase my visibility!..so yay! for me My ninjette's got teeth! |
April 7th, 2012, 09:58 PM | #1708 |
I put it away for 4 weeks again but I went through a full tank 3 days, so I'd say that I got to ride enough for only being home 5 days.
-Took off my Two Brothers slip-ons and packed them up in bubblewrap/other packing supplies in prep for my Muzzy that should be getting delivered on Tuesday. |
April 8th, 2012, 04:43 PM | #1709 |
Join Date: Oct 2010 Motorcycle(s): 93 ninja 250 Posts: 111
sorta in process, but currently replacing the rear: wheel, tire, brake rotor, brake pads, swingarm, sprocket, and shock. figured it was time for an upgrade.
April 9th, 2012, 09:47 PM | #1710 |
Super Noob
Got home to find my Sling Shot Racing gas cap waiting for me. Was pretty late outside but installation took only about 5 minutes. It's a great product, I get to save weight, it compliments my red/black theme and eliminates the need to fiddle with the key
*I realize I'm more susceptible to prankster/saboteurs, now that my gas tank is easily accessible, but...whatever * |
April 12th, 2012, 10:10 PM | #1711 |
Join Date: Feb 2011 Motorcycle(s): 2003 Ninja 250 Posts: 76
Today I rode to work and then rode home, then....
I burned the back tire off. Then removed the front and back wheels so I can get my new ones put on I got some pics and videos which I will potentially post later, for now its bed time |
April 13th, 2012, 09:01 PM | #1712 |
My painted undertail pretty much guarantees that I will never do this, but that's what the local dealer thought I did when they saw the rear tire I bought in for a loose mount.
April 14th, 2012, 12:38 AM | #1713 |
Hahaha the guy at the dealer had a pretty good chuckle when he saw my wheel. Then proceeded to show it off to some other customers hahaha.
The other people couldn't believe I did that with a 250. Also not very much rubber got onto my bike, which really surprised me because I was expecting the whole inner fender to be covered in it |
April 14th, 2012, 01:15 PM | #1714 |
hahaha he didn't think you could burn a tire on a 250? you can burn rubber on anything!
April 14th, 2012, 03:23 PM | #1715 |
Ya he was totally surprised.
"jschatte" has a some what home built trike and its got like a 50cc engine on it and he can spin the drive tire haha. Today I reinstalled the tires onto my bike, and went for a nice 30 minute ride around town. |
April 14th, 2012, 03:38 PM | #1716 |
Join Date: Jan 2012 Motorcycle(s): 2011 Ninja 250R Posts: 67
Changed oil and filter
Installed tank pad, total failure as it's supposed to go on white/light paint Installed Project D universal GPS mount. Waiting for a plate that will hold my Nexus phone to the mount Hopefully I get around to installing the hugger tomorrow |
April 14th, 2012, 04:45 PM | #1718 |
crash 250, get supersport
Join Date: Apr 2010 Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ Posts: A lot.
Changed the oil and filter for the first time today, was a breeze with kkim's DIY.
Put in Amsoil 10w40 with a K&N-401 filter, lubed the chain afterwards and the bike runs great. Weird thing was that I never really checked my oil until after 2k miles of ownership and when I filled the oil bottles with the used oil, it only came out to about 1.4 quarts when I put in 1.8 quarts of new oil. Must have burnt some oil. |
April 14th, 2012, 06:22 PM | #1719 |
CVMA #717
Did you see the video? Additional details: purchased on ebay, had a shop install it. There's a remote control with 4 buttons 1) on/off, 2) flashing or no flashing (I've been told it's not permitted to ride with flashing on), 3) sort of a "breathing" or "pulsing" glow that gets brighter, then dimmer, and 4) color changer (red, blue, clear, yellow, green, purple, or a setting that will cycle through all the colors). The video has a demonstration of all of those buttons being pushed.
April 14th, 2012, 09:33 PM | #1720 | |
Join Date: Dec 2011 Motorcycle(s): 09 ninja 250r Posts: 5
Discovered something scary about my Ninjette today... | kjohng | General Motorcycling Discussion | 28 | October 15th, 2021 01:40 PM |
Sold the 2006 Ninjette today :( | Renner | General Motorcycling Discussion | 31 | October 16th, 2014 11:46 PM |
Today I Gave My Ninjette Wings! | BlueHairSar | Pictures | 5 | June 20th, 2013 07:38 AM |
my bro went down today on his ninjette | richierich781 | !%@*#$%!)@#&!%@ I crashed! | 46 | January 18th, 2013 11:59 AM |
Ninjette. org hacked today | CC Cowboy | Off-Topic | 9 | April 3rd, 2011 08:55 AM |
