May 20th, 2014, 03:05 PM | #281 |
they call it a "world tour" at the local burger place. the burger is beef and pork, with diced bacon bits mixed in then bacon on top with a chicken breast on top of that then onions and lettuice and some kind of odd spicy chopotle mayo sauce. its pretty good.
May 21st, 2014, 05:15 PM | #283 |
Join Date: May 2014 Motorcycle(s): 09 ninja 250 special edition Posts: 203
Looks tasty what is it?
May 22nd, 2014, 11:05 AM | #284 |
Old and slow
Join Date: May 2014 Motorcycle(s): Suzuki TL1000R, Honda CBR600F3, Ninja 250 Posts: 889
Rifleman’s “Beg for Mercy” Salsa
8 large tomatoes (poached, skinned and diced) 1 can tomato paste 2 Tbs (heaped) Minced Garlic (in oil) 2 cans chilies (finely minced) Cilantro, half bunch (chopped, stems removed) 5 Jalapenos (diced, seeds removed) 1 large red onion (chopped) 1 tsp Roses™ limejuice 1 large yellow onion (chopped) 2 Tbs Extra Virgin Olive oil 1 Tbs. (heaping) Salt 1 Tbs Chili oil or Hot sauce It is preferred to dice, mince, and chop by hand as using a food processor tends to “over process” the materials. Each vegetable piece should be large enough to identify. Poaching Tomatoes is done by heating a pan of water to boiling then immersing the tomatoes for 30 seconds. Roll the tomatoes as any side or part of the tomato above the water will not be properly poached. Core out the stem of the tomato and slip out of the skin. Dice the tomatoes and let most of the liquid drain away. Store purchase minced garlic in oil is acceptable. The larger minced garlic chunks have a milder taste then finely minced or crushed garlic. Cilantro comes as a stem with a leafy top and two small leaves half way down the stem. Cut off the leafy top and the two smaller leaves and throw away the stem. If the stem is included it will produce a harsher metallic flavor. Onions should be diced to the size one would expect for a condiment on a hotdog. I always add a level Tbs of salt and then taste the salsa and add more if needed/desired. Time will also reduce the “salt” taste and bring out the flavor of the other ingredients. If it taste to salty, give it a day or two and taste again. Add more or less Jalapenos to taste; other chilies can be substituted depending on personal taste. Roasting or smoking the chilies will increase the “heat” as well as change the flavor. Chili oil is added to increase the “heat”; the oil I use is also sesame flavored and adds an interesting nose to the salsa. Change the amount to taste. Prepare all ingredients as indicated above. Place in a large bowl or pan and stir until homogeneous. Makes 24 – 36 ounces depending on the size of the tomatoes and onions. To make salsa in the winter time or any time fresh tomatoes are not available, substitute 32 oz of Del Monte Garlic and Herb diced tomatoes |
May 22nd, 2014, 11:55 AM | #285 |
Track Clown
MOTM - Sep '15
Deer, Pig and Cow!
May 22nd, 2014, 12:14 PM | #286 | |
ninjette.org foodie
Join Date: Sep 2013 Motorcycle(s): None...Yet Posts: 248
Cool thanks...., I will definitely be trying this at some point!
Unfortunately, by the time you come to the realization that this does not, in fact, actually say anything remotely useful, you've wasted 3 seconds of your life you'll never get back... |
May 22nd, 2014, 12:17 PM | #287 | |
ninjette.org foodie
May 22nd, 2014, 12:18 PM | #288 | |
ninjette.org foodie
May 23rd, 2014, 09:16 AM | #289 |
Old and slow
the trick to successful poaching of the tomatoes is to put the tomatoes in the big pan and cover them with water... now remove the tomatoes and put the pan on the stove to boil. If you just add water to the pan you either get to much and when you at to tomatoes it spills over, or you add to little and when you add the tomatoes they aren't fully immersed.
just put them in the pan, add water until they are floating and then pull them out, bada BING! |
May 29th, 2014, 11:48 AM | #290 |
chicken alfredo was a staple of my childhood diet. my sister made it seriously at least twice a week. she tried lots of different ways of making it but this is one of my favorites. i make it every now and then (not twice a week!) trimmed chicken breast, soaked in garlic butter for an hour. make a spice mix: salt and pepper to taste (you will be charring the pepper so go easy) lots of garlic, onion powder, paprika, cayanne, a little sugar, a bit of cumin, just a tiny pinch of cinnamon, some basil and diced parsley. start the noodles boiling. mix it well and cover the chicken in it before pan frying in light oil at medium heat for 10 and 8 minutes then set on a plate to the side to finish. get rid of the oil in the pan and replace with a stick of butter. melt the butter then add a cup of heavy cream. simmer for 5 minutes and stir it well. it will come down just a bit, turn the heat off and add 1.5 to 2 cups of grated parmesian cheese. mix non stop for 2 or 3 minutes until it stabilizes. by now your chicken is equalized inside so you can chop it into pieces, put them over the noodles, and pour your alfredo sauce on top. serve with garlic bread. buttered broccoli goes well with it also.
May 29th, 2014, 06:01 PM | #291 |
ninjette.org foodie
sounds good...I'll have to give it a try one of these nights
June 1st, 2014, 01:09 PM | #292 |
Awwww yea... cilantro & lime grilling sauce.
June 8th, 2014, 03:37 PM | #293 |
ninjette.org foodie
Nice...I bet that goes awesome on chicken!
June 20th, 2014, 08:29 AM | #294 |
sweet and spicy teriyaki chicken/bacon fajita kabobs
standard teriyaki (sugar, soy, vinegar, garlic, ginger, onion powder) plus cajon spices (cayanne, paprika, more garlic) let the onions peppers chicken cubes and half slices of bacon marinate for at least an hour. put the chicken and bacon against each other on the kabob stick so the fats melt together and they become one unit of "chacon" (chicken+bacon) grill indirect at first, good heat for about 20 minutes then direct heat and char the bitches until they're nicely charred all around.
June 20th, 2014, 09:06 AM | #295 | |
Certified Troublemaker
Join Date: Oct 2012 Motorcycle(s): 2006 Ninja 250r "Pikachu", 2017 Ninja 650 "Epona" Posts: A lot.
If you add it slowly as its boiling it was ok. Next time i may try adding it to the soda or the peppers first. think it was about a tablespoon but i would add more next time to make it a bit thicker yet.
Raven's Rejuvenation A bruise is a lesson... and each lesson makes us better... |
June 30th, 2014, 11:04 AM | #296 |
June 30th, 2014, 11:20 AM | #297 |
@alex.s
Man.... you should have cooked for us at Jennings. lol And.... why do you eat such foods off paper all the time. Not that I am no better, if you remember I put $60 worth of 2 lobster tails on paper too. hahahahahaha
June 30th, 2014, 11:34 AM | #298 |
i like making the messes. not cleaning them up ;P
June 30th, 2014, 12:07 PM | #300 |
July 10th, 2014, 01:25 PM | #301 | |
ninjette.org foodie
July 10th, 2014, 01:29 PM | #302 |
ninjette.org foodie
Sorry I haven't been on much guys, I feel as though I've been neglecting the thread... Glad you guys are keeping it going
July 10th, 2014, 05:04 PM | #303 |
August 20th, 2014, 04:45 PM | #304 |
ninjette.org foodie
Hey guys, I still don't have a decent ISP yet...still getting settled in here, but I'll try and make it on here a little more often.(promise)
August 20th, 2014, 05:20 PM | #305 |
August 24th, 2014, 05:48 PM | #306 |
Livin' the Minimoto Life
Join Date: Mar 2009 Motorcycle(s): 2022 Honda Navi, 2018 Z-125 Pro Posts: A lot.
My mother-in-law hooked me up. I have the coolest in-laws that I could ever ask for. Before he passed away, my father-in-law and I used to play golf together and do projects. Since he passed away, my wife and I have been doing a lot to help take care of her (she is handicapped).
Well, to say "thanks" for all I have done for her, she gave me a Kitchen Aid Professional 500 mixer. I am putting it to goo use tonight, making bread for the first time. I have never tried baking beyond cornbread because it was a pain without a mixer. I always put my money towards other things (currently photography and bicycles), so it was a great surprise. I am making some bread tonight. SWEET.
--- My IG Page --- My FB page! --- 2022 Honda Navi && 2018 Z-125 Pro |
August 24th, 2014, 08:33 PM | #307 |
Man, nothing like fresh bread right out of the oven...
August 26th, 2014, 07:03 PM | #309 |
LOL
That is cool, but I'd be afraid of what else I'd try to see what the laser would cut through!
September 11th, 2014, 04:57 PM | #310 |
ninjette.org foodie
Off topic, but do any fellow Washington residents know if that used cycle shop in Auburn is any good? I forget the name...
September 11th, 2014, 05:38 PM | #311 |
1/4 English, 3/4 Kick Ass
Join Date: Sep 2011 Motorcycle(s): 2002 Triumph Speed Triple 955i, '05 Suzuki SV650S(retired), '11 Ninja 250R(sold) Posts: A lot.
Makin BBQ ribs!!
September 23rd, 2014, 11:22 AM | #312 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
September 23rd, 2014, 11:31 AM | #313 |
Hey @NDspd!
I made the best ribs I have ever made they other day. Smoked in the smoker for 14h's. I will post the recipe in a bit. Although, I was not ATTGATT lol. I must ask though, your pouring milk into a sauce pan? What was ya makin'?
September 23rd, 2014, 06:40 PM | #314 |
I need some bar b que in a egg roll in my life
September 24th, 2014, 06:16 AM | #315 | |
September 24th, 2014, 04:21 PM | #316 |
Irish egg rolls
That's right... Corn beef an cabbage egg rolls
Make corn beef an cabbage, wrap egg rolls, cook egg rolls, eaaaaaat |
0 out of 1 members found this post helpful. |
September 24th, 2014, 04:35 PM | #318 |
my faaaaaaaveeeeeee! we call them "Sandy potatoes"... not sure why. i think it has something to do with the beach. or maybe someone named sandy.
September 24th, 2014, 05:07 PM | #319 |
Tomorrow either Ruben egg rolls or spring rolls... Mmmm Ruben sandwiches
September 24th, 2014, 05:07 PM | #320 |
**** yo couch
You hate cooking !! | chef | Off-Topic | 8 | August 19th, 2016 01:43 PM |
[roadracingworld.com] - World Superbike Riders Try Cooking A Local Dish In Portugal | Ninjette Newsbot | Motorcycling News | 0 | June 6th, 2013 03:50 PM |
[speedTV.com - racing news] - WSBK: Cooking In Portugal | Ninjette Newsbot | Motorcycling News | 0 | June 6th, 2013 02:10 PM |
[roadracingworld.com] - Eugene Laverty Wins Cooking Competition Thursday At Silversto | Ninjette Newsbot | Motorcycling News | 0 | July 28th, 2011 01:30 PM |
[roadracingworld.com] - Video: Cooking A Holiday Feast Using Tire Warmers! | Ninjette Newsbot | Motorcycling News | 0 | December 13th, 2010 12:10 PM |
