May 2nd, 2015, 01:58 PM | #1 |
Join Date: Sep 2014 Motorcycle(s): 1995 Ninja 250, 2005 R6, 2002 Ducati Monster S4 Posts: 250
Full ninja 250 Paint/ powder coat/ ceramic coat
What started out as just a rear shock upgrade has turned into a little more..
bike is fully apart to get most of it powder coated, ceramic coated, painted. The plan has changed a million times. Current plan is Most stuff: frame, rear swing arm, rims, calipers and most small miscellaneous parts powder coated red. Tank and exhaust white, the tank powder coated or painted white while the exhaust ceramic coated white. Not sure how possible white exhaust is; if not possible then tank will be X and exhaust X too... I think, the seat I might try to upholster it my self red or red and white. some small stuff might powder coat black.. All the stuff... 3 to 4 things are left 1) Taking the pistons out of the calipers 2)the steering column that is held onto the bottom part of the triple tree has a rubber part that I can not take off, if so then I wont powder coat it but paint it.. 3)Been reading and it looks like I made a mistake in not dismantling the forks when still on the tripple tree, but will so how to get around this 4) I have a little gas filter plastic thing stuck inside the tank that I have not been able to take out to avoid it melting when if I get tank powder coated. I am also looking to get a dent remover cuz my tank has some dents.. 5) the master cylinder, is there a rubber part inside the piston or is it just a spring? if there is rubber I must take it off... |
May 8th, 2015, 06:01 PM | #2 |
master cylinder bullseye/sigh glass
UPdate.
the caliper, I tried a grease gun but the nipple was not working well and .. and well no success so I left the caliper at a machine shop to get the piston out, they 'll let me know Tuesday as they are closed thru Tuesday. next, getting the bulls eye/oil sight glass of the master cylinder.. no success yet.. any advice? here is one of my quick attempts Last futzed with by Qomomoko; May 11th, 2015 at 09:31 AM. |
May 8th, 2015, 08:54 PM | #3 |
success.. kind off
May 10th, 2015, 02:13 PM | #4 |
May 11th, 2015, 08:48 AM | #5 |
fork rebuild kit???
Before new paint on the forks and possibly springs....
what is this white residue from? both forks looked good except for that clip under the dirt boot on right fork? oil was clean too. should I order a fork rebuild kit? i can get better close ups, was about to order it but if it is good I can save $25 per fork. http://www.amazon.com/gp/product/B00...A363BFUBCLUQU5 |
May 13th, 2015, 09:53 AM | #6 |
STuff looks good for reuse..
STuff looks good for reuse.. except the caliper which i ordered a rebuild kit for both front and back and SS pistons
for the master (front and rear) cylinders.... still debating.. there are two types of rebuild kits, one includes the piston which is about (K&L) $25 http://www.amazon.com/dp/B001KOHUDU/...I26XNXADB91P82 http://www.amazon.com/dp/B001KOG24I/...I2C0L782U6QQ3L and the smaller kit (allballs)which is washer and boots and the 2 screws for about $15. http://www.amazon.com/dp/B00D0AWXQG/...I13SDM6CMGMMD9 http://www.amazon.com/dp/B00D0AWYMO/...I2S69V1WBLLK38 for the forks... also looks good i think, maybe alittle more cleaning and the seal spring is good as well though looks darker, the one that goes on the oil side. |
May 13th, 2015, 02:12 PM | #7 |
Spring rate...
Also, is it better go to on the .05 kg/mm stiffer side when in between or maybe putting on some lbs?
Sonic springs also tells me to go for .95kg/mm springs me weighting 150 lbs plus 15 lbs of gear and My Ducati Monster S4 weighting 430 lbs... racetech for the 2001 Ducati M 900 says .88 kg/mm.... cant decide... for my ninja 250 Sonic says .8 kg/mm for me at 150 lbs and 15 lbs gear and 340lbs but Racetech says .74 kg/mm cant decide... |
May 15th, 2015, 08:46 PM | #8 |
Stubburn front Caliper Piston removed with grease gun!!
While prepping my ninja 250 for powder coating I ran into a caliper piston that would not budge. Compressed air released the left piston on the video, the right was stuck. I tried the grease gun a week ago, bought at Harbor Freight, but nothing. Grease would not come through the nipple. I got a new nipple and grease gun end and it was was working...
I took video of the beginning but it got corrupted. Here is video of the last episode. Now time to clean the caliper, make sure it is in working condition and then powder coat it!!!! For some reason the pistons did not POP in this method. During the compressed air, that thing popped big time . also... have noticed that the Ninja 250 front and rear caliper actually have different design besides the location of the bleed valve, the internal port for the brake fluid is much larger in what I think is the rear. The rubber rings, 1st one is for dirt and the thicker second ring is the piston seal; dirt one is toast. Pistons are bad too, can see where the mechanics used pliers from the machine shop. :kurt: I already ordered caliper kit for both... Last futzed with by Qomomoko; May 16th, 2015 at 04:22 AM. |
May 16th, 2015, 07:13 AM | #9 | |
May 16th, 2015, 11:15 AM | #10 |
Nice
May 16th, 2015, 02:20 PM | #11 |
Part are getting color!!!!
Parts are getting powder coated somethings that are left 1 weld the 1 inch hole in one of the slipons 2 ceramic coat the slipons and mid pipe white 3 clean and paint engine mostly black and some red 4 order the springs from racetech 5 make two glass bullseyes for two front master cylinders 6 decide on rebuilt kit for rear and front master cylinder and order it 7 finish my custom bracket for my instrument cluster and then put it all together including the carburetor !!!! I will after the bike is running work on making my own cool fairings :headbang: probably mostly white this includes the tank.. the large dent budged a little but the right small one, no way jose, the small one did not budge at all. The other small one moved very little. I would love to have her ready for HMS the 31 track day but will see. |
May 17th, 2015, 06:13 PM | #12 |
half the parts powder coated
May 18th, 2015, 07:35 AM | #13 | |
Ordering today later...
Ordering today.. any last minute advice...?
May 18th, 2015, 08:56 AM | #14 |
You may want to ask the coater to mask the mating surfaces for the rotors, bores for the bearings, threaded holes, etc, on the next batch.
It can be a challenge assembling things with powder on all surfaces. Just a suggestion to save you some headaches. |
May 18th, 2015, 09:07 AM | #15 |
Sand paper
I did.. I think is charging me little so I am not being toooo picky but try too.. I think I'll be using sand paper later lol
Last futzed with by Qomomoko; May 18th, 2015 at 11:02 AM. |
May 18th, 2015, 10:49 AM | #16 | |
Depending on the thickness of the powder, you may want to scrape the surface with a razorblade or scalpel before sanding. Use a small flat piece of thick metal as a sanding block to keep the areas flat when you start sanding. I'd probably start with 100 grit and move to 150/180 once you start to get close to bare metal. Masking is the time-consuming, and costly, part of the process when dealing with complex surfaces that shouldn't be coated due to tolerances or alignment issues. It's much easier to coat something completely and let someone else worry about the details later... |
May 18th, 2015, 11:02 AM | #17 | |
masking
May 19th, 2015, 04:16 PM | #18 |
Action.. Powder coating
Link to original page on YouTube. Last futzed with by Qomomoko; May 20th, 2015 at 12:37 PM. Reason: fixing video link |
May 20th, 2015, 07:39 AM | #19 |
Sorry - that's not encouraging...
I see a ton of threaded holes and areas that don't look like they were masked that should have been... |
May 20th, 2015, 08:12 AM | #20 | |
masking...
threaded areas for screws were not... i'll be dealing with that next |
May 22nd, 2015, 07:33 AM | #21 |
Hi heat paint from rattle can
May 30th, 2015, 02:38 PM | #22 |
Instrument Bracket
To better organize my GPS and Iphone and camera..
First is the one that will replace the entire Instrument cluster on the ninja 250 and the second and third are add ons for the stock instrument cluster on the Monster S4; gonna go pretty much right over the key ligning up just below the instrument cluster, or that is the plan at least. |
May 30th, 2015, 04:37 PM | #23 |
June 3rd, 2015, 05:03 AM | #24 |
Carb painted with heat resistant spray paint.
June 3rd, 2015, 06:40 AM | #25 |
I'm crazy,your excuse is?
powder coat exhaust's heat shield black. | eddieA6987 | 2013 - 2017 Ninja 300 Farkles | 12 | October 24th, 2012 09:36 AM |
[topix.net] - A trench coat made for motorcycling | Ninjette Newsbot | Motorcycling News | 0 | October 16th, 2010 03:30 PM |
[hell for leather] - A trench coat made for motorcycling | Ninjette Newsbot | Motorcycling News | 0 | October 15th, 2010 09:10 AM |
[usridernews.com] - Cool Coat and Key racks | Ninjette Newsbot | Motorcycling News | 0 | July 29th, 2009 04:00 PM |
Anyone Powder Coat their rims yet? | 00v_Lucky | 2008 - 2012 Ninja 250R Farkles | 12 | February 23rd, 2009 03:58 PM |
