#1 |
Join Date: Jan 2015 Motorcycle(s): 2000 EX-250; several other years of the same Posts: 470
94 EX250 build - take 2
I started a build thread about a year ago, and after a little over a month, the project stagnated. I have a renewed drive to complete it, but in a different direction than last year.
Link to previous build... https://www.ninjette.org/forums/showthread.php?t=228089 Where we stand today...
... can't stop updating the bike! |
#2 |
This is the direction that I am headed this time around. What is pictured as red will be blue, and what is black will be a dark grey. I just need to find the exact colors in a spray paint. I'm unsure about the color for the wheels - both matching grey? Both matching blue? Or, one of each?
#3 |
Vintage Screwball
MOTM - Mar '16
Blue wheels!!
Goin' fast on slow bikes! ![]() |
#4 |
I'm crazy,your excuse is?
Color match the wheels to the front/rear paint scheme.
#5 |
Join Date: Aug 2015 Motorcycle(s): 05 Ninja 250, 04 KTM 625 SMC, 01 Xc250 Posts: A lot.
I vote a third color for the wheels, maybe a light gray.
Because Unregistered sucks at riding. ![]() |
#6 |
So, like me, 2 votes for blue front wheel, and grey rear? Once I get the bike mostly painted, and reassembled, I'll take photos all 3 ways, and then make a final decision. Thanks for the input!
#7 |
Any suggestions on filling in this void? It is where the right hand side turn signal bolts on. The previous owner made a faux carbon fibre plate, bolted over it. Not a bad job, but not my style.
I have another lower engine fairing ( disfigured due to heat? ) to use for bits of plastic. I thought I might try to solder weld bits together, then apply a coat of epoxy, then sand to shape. This pic is upside down. It is the main upper fairing.
#8 |
I will also need new tires. I did some research on Ninja 250 faq website, and have decided, based on cost, to go with Pirelli Diablo O.E. Scooter Tire - 130/80 16 rear, and 100/80 16 front. The best price that I can find so far is $150 shipped. Is there a better deal to be found?
I already have Pirelli MT75s on my other 250, and the rear 120/80 16 is too narrow looking.
#9 | |
#10 |
Wheels I went naked on mine, took a sandblaster to them. Purple wasn't gonna cut it.
Tires I've used Kenda K671, and Bridgestone BT45. Both excellent choices the Kendas are inexpensive, excellent wet weather performance, and last a lot of miles perfect for commuting. Good luck on your second attempt, I'm lucky enough to have the free time needed to do mine, so it only took about month to do the bulk of the work. It's maiden long distance voyage was soon after, 700 miles in a single day. Work performed so far, Cut and set sag front fork springs(springs from a Ninja 500 1st generation, rate is .85kg/mm ) Replace fork oil 15wt synthetic Install new fork seals and dust caps Replace rear shock(zx600c) Replace shock oil 15wt synthetic Change gears +1/-2(15/43) Rebuild/tune carbs, adjust idle mixture K&N air filter New brake pads F&R EBC extreme HH New Wave front rotor Used OEM rear rotor Rebuilt calipers Modified OEM seat(gel/foam insert, Custom Seat Creation cover solo line cf silver/cf metal, heated kit) Extra heavy bar ends(3"/23oz) Heated grips w/ foam covers Touring windscreen / 7 JuRock 18" 73%tint w/ flip Shorter bar risers(OEM ZX600c, lower bars about 1 1/2") Removed paint from rims, bare aluminum Bridgestone BT-45s w/ Dynabeads Stainless steel allen head fasteners Stainless steel braided brake lines Shorty adjustable levers HD clutch springs Charge/voltage LED indicator LED clock HID headlight(55w 5k) Replaced all other bulbs with CREE LEDs DIY integrated tail light kit w/clear lens DIY rear fender elimination DIY licence plate mount(LEDs to illuminate the plate/red LEDs tied into brake light) Brake light modulator Maintenance free gel battery Compact air horn 2007 Complete OEM fairing set silver Genuine imitation carbon fiber wrap misc parts Reflective custom graphics ZX-2R silver Reflective custom graphic NINJA red(taillight lens) Reflective rim tape silver Electronic turn indicator relay Replace front side reflectors with flush mount turn indicators LEDs Installed rearview camera system Installed oil cooler Strip paint off grab handle, bare aluminum alloy.* Custom reflective graphic "SERENITY" for windscreen silver Aluminum chain guard from Suzuki Bandit 1200 Swing arm plugs from 08 Ninja 250 Mad Hornets Turn Signal Indicators w/duel color Cree LEDs(amber/white) FH010 R/R modification Digital gear indicator Universal Rear View Side Mirror Rain Board Sun Visor Shade Shield Kawasaki ZRX1200 lowered foot pegs OEM upgrade shift spring All this and full maintenance and rebuild everything else except the motor. I'm sure I'm forget some stuff, but you get the idea SIDENOTE: is that a CBR500 chain guard I see in your parts photo?
violente et ignorantia ZX-2R BLOG Twitter and Instagram = Ghostt_Scott I'm not here to change your mind, just to inform. ![]() |
#11 | |
#12 |
Yup, but it's not working at the moment, cheap LCD screen+H2O=DEATH!!
But it was a handy thing to have, no more blind spot.
#13 |
Couldn't you just... Turn around...? My riding style is way different than yours, but I never really felt like there was a blind spot on a motorcycle.
#14 | |
It's like the Digital gear indicator I added, not a necessary part, but nice to have kind of thing, true FARKLES
#15 | |
Join Date: Jun 2013 Motorcycle(s): 2010 Ninja 250 Posts: 596
#16 |
Perhaps these might cover it up, and help the looks too
Mad Hornet's flushmount front turn signals /AsianCycle flush-mounts clones
#17 |
I like that idea. Would I try to fill it all at once, or in segments? If all at once, I guess it would set as one piece.
#18 |
#19 |
All at once, use a spreader. I'm thinking treat it like you would Bondo. I've never done it before, not quite sure how well the patch will fuse to the original plastic.
#20 | |
#21 |
I guess I could melt a few paper clips in to the original plastice, to have something for the "new" plastic to bond to? I'll just need to try and see where it goes. I plan to try this weekend.
#22 | |
#23 |
Vintage Screwball
MOTM - Mar '16
IMO, I would use aluminum foil for the backing. The ABS cement won't stick to it.
#24 |
Another option is keep checking eBay, I got a complete of plastics from an 07' for $200.00 shipped.
If you keep an eye out you might find an upper for cheap, and save time and aggravation.
#25 |
Yeah. I thought of that. No good deals right now - either eBay or Craigslist...
#26 | |
How much you willing to spend ? If you don't mind me asking. Also don't forget the check the sale section here.
#27 |
After searching many home improvement, department, and auto parts stores, I decided to try these these colors - based upon price, availability, and past experience:
Gloss Deep Blue 249114 - 12 oz. Spray <img src="http://www.rustoleum.com/~/media/DigitalEncyclopedia/Product/RustoleumUSA/CBG/painters-touch-ultra-cover-2x/gloss/249114_0213_PTO_12oz_2xUltraCover_Gloss_DeepBlue.ashx" alt="Ocean Mist"/> Gloss Dark Gray 249115 - 12 oz. Spray <img src="http://www.rustoleum.com/~/media/DigitalEncyclopedia/Product/RustoleumUSA/CBG/painters-touch-ultra-cover-2x/gloss/249115_0213_PTO_12oz_2xUltraCover_Gloss_DarkGray.ashx" alt="Ocean Mist"/>
#28 | |
#29 |
I painted a couple of random parts today, to see how the paint would actually look... I don't like it
![]() I might need to go with another color scheme.
#30 |
I hope I like my paint scheme better. I already ordered all the paint.
#31 |
For jets try PM @ducatiman
#32 | |
#33 |
I have been searching for alternate paint colors, within the $4 to $6 per spray paint can range, and am not finding any dark blue and dark grey combination that I like. I am considering an orange & flat black combo, where the orange would replace the red / blue, and flat black, the black / grey...
Items needing paint: frame wheels all plastics mufflers gas tank swing arm forks So, I spent a few hours dismantling my donor bike, and doing inventory. The donor bike will be used for engine, wiring harness, cooling system.
#34 |
Send @ducatiman a PM he carries carburetor parts, be a lot cheaper.
#35 |
I'm partial to orange myself, and look into satin black instead of flat.
#36 |
On another note, when I use rattle can I use Krylon Fusion
http://www.krylon.com/products/fusion-for-plastic/
#37 |
Thanks for the input Ghostt!
I have 2 other ideas for the blue / dark grey combo... Ultra Cover 2x Gloss Spray - Gloss Navy Blue Rust-Oleum 248930 Automotive High Performance Wheel Spray Paint, Graphite If that doesn't work, Plastidip! Plasti Dip - Flex Blue 11oz PLASTI DIP GUNMETAL GRAY Except for the gloss navy blue, I cannot find any of the other colors locally. It's too cold to paint today, anyway. I have so many plastic parts to repair and prep, so that is on tap for today.
#38 | |
Old tires dismounted this weekend. Now to clean and paint.
#39 |
Parts have been arriving. All Balls steering and wheel bearings, tires, brake pads, and wind deflector. Lots more ordered in the last few days. I want to put the bike back together right.
#40 |
I completely disassembled the front caliper for inspection and cleaning. I have ordered a Galfer SS front brake hose, and need to replace the caliper seals.
Two motorcycles to build one | Donovan1 | 1986 - 2007 Ninja 250R Tech Talk | 11 | March 7th, 2016 09:01 AM |
a.kozak's 06 ex250 build (custom front end) | a.kozak | 1986 - 2007 Ninja 250R Farkles | 16 | October 22nd, 2014 07:31 AM |
90 build up | justin_ninja | 1986 - 2007 Ninja 250R Tech Talk | 4 | January 12th, 2013 03:53 PM |
Build Off or Rip Off? | eddiekay | General Motorcycling Discussion | 13 | December 9th, 2011 08:08 AM |
2009 SE Build | Betlog | Pictures | 8 | July 21st, 2010 09:59 PM |
