Old August 16th, 2017, 02:07 PM   #1
GAU-8
Socially inept. Yet FUN!
GAU-8's Avatar
Motorcycle(s): Current machines- 1992 SECA II 600, 2006 Ninja 250, 2008 Ninja 250
Front brake...brakes on it's own...
This is interesting. First mechanical issues, since I picked up the ninjette a few weeks ago. This started happening a day or two ago.
The front brake engages pressure on it's own. Both stationary, and riding. But it isn't all the time. I can park it after a quick ride, next day, front brake is locked up. Or, I can be doing a puttering ride, just to stroll around,.. Then it slowly engages on it's own. ( revs climb, bike slowly dives down. Front locked up. Other times, I come back to it, and the pressure is gone.
I bled the brakes, first day recieving the bike, and has not been faulty, till recently.
Going to do a full overhaul on the system. I have never experienced this situation, where it applies pressure ( and releases on it's own.) I find it interesting. I can understand items being frozen/locked. ( for ex:bike sitting for years) but not one that. Builds up , and releases on its own.
GAU-8 is offline   Reply With Quote
Old August 16th, 2017, 02:20 PM   #2
Rubber hose is constricted.
Old August 16th, 2017, 02:30 PM   #3
I would look at the reservoir and master cylinder.
Check that the gasket is set properly in the cap on the reservoir so the diaphragm will expand and contract properly.
It may get hot from the engine heat when parked, then not be able to expand without applying pressure.
If that's not the issue, I would plan on a complete overhaul of both the master cylinder and caliper before riding.
That situation could prove to be very dangerous.
Old August 16th, 2017, 02:35 PM   #4
Jethro offers a good possibility.
Another possibility is a non-stock brake lever that's not letting the master cylinder's piston fully retract. That keeps the little hole covered so pressure can't get out of the line. It's very dangerous, and can lead to a locked front wheel at high speed. It doesn't take much warming up of the fluid to make it expand enough to get the brake dragging, which heats it up more, ending up with a locked wheel. It happened to a friend while riding his Buell the day after installing a non-stock brake lever.
Alternatively, anything that's clogging that little hole, like dirt or corrosion, could do something similar.
Old August 16th, 2017, 03:18 PM   #5
GAU-8
GAU-8's Avatar
The front brake engages pressure on it's own. Both stationary, and riding. But it isn't all the time. I can park it after a quick ride, next day, front brake is locked up. Or, I can be doing a puttering ride, just to stroll around,.. Then it slowly engages on it's on. ( revs climb, bike slowly dives down. Front locked up. Other times, I come back to it, and the pressure is gone.
Old August 16th, 2017, 03:24 PM   #6
GAU-8
GAU-8's Avatar
I have extra levers, and reseviors. I'll see if the one equipped is stock (it's mounted on the adjustable knob for hand size)
I figured it stems from my actuation of the brake, and becomes a delayed/stored energy issue. Thanks for replys. Yup, if I am going to check several areas, worth doing a full overhaul/rebuild.
Old August 16th, 2017, 07:29 PM   #7
ducatiman
ducatiman's Avatar
Testing my memory here, but I seem to recall, long ago, an acquaintance having a similar issue due to his inattentive use of incompatible brake fluids. Other than that, I just can't remember the gritty details.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old August 17th, 2017, 06:28 AM   #8
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!)
MOTM - Nov '15
This brake issue, its cause & solution has been dealt with before on this (and other) forums but I haven't been able to find it yet though if my rusty memory is correct; the answer is above. I'll keep looking and see if there's anything different than what's been suggested.
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over
SLOWn60 is offline   Reply With Quote
Old August 17th, 2017, 11:00 AM   #9
Ghostt
Ghostt's Avatar
I would first so a service of the caliper, which includes flush and fill with fresh fluid
Here's the write-up.
I recommend that every time you change your pads, you service the calipers, he's my write-up to help you out. It should fix your initial problem, and keep your calipers in top working order.
For those of you whom are scratching their heads, here you go,*
Front Caliper Service (also rear as well)
Many folks have posted here with a Varity of front brake problems.
*Many of which are attributable to the lack of proper maintenance.
*Here’s how you can always have a brake like when your bike was new.
A short list of the problems and the causes.
Soft lever or lever goes to the bar.
The usual cause is the pistons are pushed too far back into the caliper by a flexing a warped, coned, disc.
*Using up too much piston travel before the disc is pinched.
Juddering in sync with wheel rotation.
The disc is worn, and its thickness varies. *This causes the caliper to “sink” into the thin part and when the thick part comes around, it gets wedged into a smaller space causing a tightening of the brake. Then the tight spot passes through and it like the brake is released. Then repeat, repeat.
Cupped, coned, or warped disc.
Unfortunately this is a common problem with EX’s the cause is the disc is stretched in the center due to being rigidly bolted to the wheel. *The huge force of braking is transmitted to the wheel through the webbed center of the disc which gets stretched and becomes larger than the space it occupies in the center of the disc. This causes the center to push to the side trying to find room for itself.
*Resulting is a cone shaped disc.
Soft lever 2
The caliper has pistons only on one side, so as the pads wear the caliper must shift sideways apply even pressure on both sides of the disc.
*To allow this the caliper floats on two pins. *If these pins get dry (no grease) dirty or bent. The caliper won’t center itself and bends the disc to wherever it is.
This take up lever travel and when released pushes the pistons further back than necessary.
*If not fixed will eventually destroy the disc (warp it).
Ok how to prevent all of the above.
When new pad time comes around, resist the temptation to just pop in new one and go.
*Every time you must do these things.
Remove caliper disassemble and clean it.
Clean and re grease the sliding pins.
Polish the caliper pistons to remove dirt. If you just push the pistons back into the caliper leaks will result. Or binding.
Tools required:
12 mm socket
8mm open end wrench
3” or bigger C clamp
a supply of new bake fluid.
wire brush and or steel wool.
Remove the caliper from the fork leg but leave the brake line on.
Remove the old pads and the mounting frame (the sliding pins)
Remove the cover from the Master Cylinder on the Handel bar.
Attach the C clamp to one of the pistons but don’t squeeze it. *Pump the lever on the bar slowly to push out the other piston almost all the way. *Put the C clamp on that piston and push out the other one.
Remove both pistons by hand.
Remove all the rubber part from the caliper, the seals are in the grooves in the caliper and dull pointed thingy will get them out easy.
Disconnect the caliper from the brake line.
Soak all the rubber parts in new clean brake fluid * ONLY!!!!! * Rub them with you fingers till as clean as new.
The caliper can be cleaned with a wire brush or even a Moto tool for the internal grooves, NOW’s the time to paint it if you wish.
Polish the pistons till they are smooth and shinny. They are chrome plated. If any of the plating is chipped or damaged below the dust cap groove. *Replace it.
The master cylinder is the subject of another write up and we’ll assume it in good working order here.
If you suspect your disc is bad, your bets bet is to replace it with an after market one fro EBC or Galpher.
*Don’t remove the disc unless you intend to replace it. *It will assume a new shape if it is * stressed and will not be flat again. You can try to check its condition by placing a straight edge across the face of the pad swept area looking for any distortion.
Re assembly
Take the nice clean rubber seals and install them into the caliper then the Dust covers.
Wet all the rubber with new clean brake fluid and partially fill the caliper with new fluid.
Push the pistons though the dust seals and into the caliper body until the dust covers snap into the grooves.
Fill the MC with new fluid and pump the lever while holding the Line above the MC till clean fluid flows.
Connect the line to the caliper while holding it above the MC.
Pump the lever with the bleeder valve open till fluid flow from the bleeder.
*Hold the caliper so that the bleeder is the highest point.
Close the bleeder and pump more fluid into the caliper but don’t push the pistons all the way out.
Then squeeze the pistons all the way back in and install the new pads.
Re grease the slider pins and assemble the dust seals and re mount the caliper on the forks but leave the bolts loose.
Now clamp the caliper to the disc with the brake lever.
Look at the space between the fork lugs and the caliper, clamp and release a few times as you tighten the bolts by hand. It one lug touches much before the other the odds are you mounting bracket is bent. You can straighten it.
*After you get it the best you can. Some shim washers made from alum can stock can be fitted to the loose side.*
** *What we are doing here is trying to minimize the bedd in time and gets the best pad life.
Ok with everything tight you should be through, Notice we don’t need to bleed the brakes, but if you screwed up in any of the above steps, you might do that here.
Be careful to Bedd in the new pads gently.
*Too much pressure too soon will burn the pad material as only a small area will be gripping at first. You also won’t have full braking power till the pads are fully familiar with the disc
I also recommend flush and fill with new brake fluid, also I'd go with 5.1DOT.
No matter what kind of brake fluid you choose, always periodically flush and fill with new fluid.
This is the one I use
https://m.motul.com/ca/en-us/product...-1-brake-fluid
Also inspect the brake lines, replace is needed, http://faq.ninja250.org/wiki/Stainle..._lines_upgrade
Venhill Introduction
Greetings everyone!
I wanted to take a moment to introduce you to Venhill...
Venhill manufactures some of the highest quality brake lines and cables you can get. We've been in business since 1971 and currently offer a full range of brake lines for the Ninja 250, first and second generations.
Our website, venhillusa.com, is setup to take orders for any year Ninja 250 as well as many other bikes. You can pick your bike and then customize your kits as you wish. We offer many different colors of hose as well as different finishes and materials for hardware. All of these options can be selected during the purchase process, so you'll be sure to get exactly what you want. You can even add length to hoses if needed.
To get an idea of our reputation, have a look at our eBay feedback.
If you have any questions or comments about Venhill products or brake lines or cables in general, please share them. I'm happy to be a resource for general information about brake lines and cables as well. Technical questions are welcome!
Please take a look at our website and let us know what you think. We just recently did a complete makeover and are interested in feedback. (venhillusa.com)
Have a great day and stay safe,
Chris
Venhill USA
For the detail oriented out there, some interesting things you might want to know about Venhill and our products:
Our factory is ISO 9001-2000 approved, which basically means we have the ability to consistently produce quality products. To qualify for ISO approval your factory and quality control mechanisms are evaluated as to whether your "good" products happen by chance, or if they are a result of good quality control.
All of our hoses are built to DOT/TUV spec and have been certified as such. We submitted hoses to the TUV (German DOT) for testing and only by passing are we allowed to use the TUV symbol on our hoses. Every hose we sell is built to these specifications, even if it is for track or offroad use only. It just makes for a higher quality product.
All of our hoses are hydraulically crimped, not hand crimped, and leak/pressure tested in a water bath. Yes, we immerse every hose we build in a water bath and pressurize it to check for leaks and to verify integrity of the crimps.
Venhill's hose core is authentic DuPont Teflon which is more expensive than generic "PTFE" but is stronger with a smoother inner bore. This is surrounded by 96 strands of braided marine grade stainless wire. 96 strands is more dense than some other braided line brands and the marine grade alloy is a stronger metal, which reduces expansion, the reason rubber hoses feel "spongy". Finally, we coat the braid with a UV-resistant PVC, extruded on during manufacture. This protects the hose as well as body and paint work.
Our hose design uses free-floating swivels, which allow you to loosely install everything before the hoses are tightened into place. This ensures the hose is not forced into a twist or kink when the banjo bolts are tightened. If you're worried about leaks, don't be. Our swivels work on the same premise as every threaded connection on a car or truck.
As you can see, we're sort of obsessed with quality and safety. We look at it this way: If we're asking you to put our brake lines on your bike, you're trusting us with the integrity of your brakes. That's a serious concept and we refuse to compromise when it comes to the integrity of your brakes.
I have these stainless steel lines on my Ninjette, and so far, some good, I recommend getting the stainless steel banjo bolts, I noticed my chrome ones have started to rust slightly, a good excuse for me to upgrade to titanium
On my 91 EX500 I have Spiegler, in orange to match that bike.
So you have made the decision that your OEM rubber lines need to be changed.
So why choose Spiegler Brake Lines?
A: Strength
That’s the short answer. But it doesn’t tell the whole story.
Spiegler Brake Lines strength comes from our innovation and research, materials and construction, knowledge and experience, service and support.
At Spiegler, we believe that the more you know about what we put into our products, the better you’ll be able to answer that question yourself.
That’s the short version; now let’s cover this topic more in depth.
Most OEM manufacturer recommend that you replace your rubber brake lines every 2 to 3 years. Why do the OEM’s recommend this? Over time OEM rubber lines deteriorate rapidly due to expansion and UV damage. This leads to increased braking distances and possible failure.
At Spiegler, our brake lines are made of only the finest materials available.
Outside casings are made of tightly woven stainless steel braiding that exceeds our competitors
The inside is made with DuPont’s PTFE-Teflon which eliminates expansion and adds durability
Crimp sleeves are made from stainless steel; competitors are using mostly carbon steel
Unique patented adjustable banjo fittings eliminate line twist during installation.
30% weight savings in comparison to other stainless steel braided brake lines
DOT approved
Lifetime warranty
117 color combinations possible which allows customers to personalize their bikes
We can build your lines to any specifications for custom applications
All brake line kits come ready for install
For more information on why you should choose Spiegler Brake Lines, you can view the following pages for a more detailed look into Spiegler brake lines.
When it comes to safety items like brakes, when in doubt, throw them out, it's your safety in your hands, and is cheaper than a visit to the ER.
Buy quality pads,I personally recommend EBC brand either the HH, or the Extreme HH.
EBC full floating rotor, replace the OEM rubber line with a stainless steel braided brake line, cheaper than replacing them with OEM.
On my 500 I have Spiegler line
http://www.spieglerusa.com/brakes/cy...line-kits.html
On my Ninja 250 i went with Venhill
http://www.venhillusa.com/products.html
With all that, it will stop on a dime, and leave you nine cents in change.
look here http://ebcbrakes.com/products/motorcycle/
And also read this, http://www.ex-500.com/wiki/index.php...otors_and_Pads
That should answer any questions you might have.
violente et ignorantia
ZX-2R BLOG
Old August 17th, 2017, 12:08 PM   #10
GAU-8
GAU-8's Avatar
Thanks for all the info.
Long story short, I got it working again. Once when I saw how corroded everything was, I cleaned up what was usable, (caliper, pistons, resevior) replaced what was not (o-rings, hoses, rubber goods) with new.
Again, thanks for the input.
Super slueths have closed another case..
Old August 17th, 2017, 12:41 PM   #11
Good work, C.
Old August 29th, 2017, 06:59 AM   #12
Heated water expands, cooling water contracts... which explains your intermittent brake pressure problem. (water is a funny substance, it doesn't act like other liquids 100% of the time. it has a goldylocks temp zone)
So how did the full brake service go? I assume you got it fixed by now.
Old August 29th, 2017, 07:29 AM   #13
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
Gremlins.....
Old August 29th, 2017, 07:30 AM   #14
The bleed hole in master cylinder reservoir may be blocked, preventing pressure in the system from being able to get out. This is very dangerous. I've seen it cause a locked front wheel at high speed, with the resulting crash.
Old August 29th, 2017, 08:02 AM   #15
Wait, what?
https://www.ninjette.org/forums/showthread.php?t=301318
Why are we starting over?
Old August 29th, 2017, 08:28 AM   #16
Good question Jay. I assumed this was a different case, but I didn't check.
Old August 29th, 2017, 08:47 AM   #17
Originally Posted by jkv45 View Post
Wait, what?
My bad, I checked unanswered threads and saw this. Perhaps @Alex will merge the threads or just close this one.
Sorry...
Old August 29th, 2017, 08:51 AM   #18
/merged
Old August 29th, 2017, 08:56 AM   #19
More Gremlins at work...
Thanks Alex.
Old September 13th, 2017, 05:40 PM   #20
Capekev
Motorcycle(s): 1996 Ninja 250R
I just bought my 250r and it was wrecked when I bought it. It still starts, runs, and rides but on a sharp left turn it locks the front wheel. My initial thought was that the lever was hitting the mirror which was completely bent around backwards and o still think that's the case but I haven't had it running yet since I took all that off. I'm hoping it was that simple.
The lever is bent a little too so I'm not too sure it's not that.
Capekev is offline   Reply With Quote
Old September 13th, 2017, 06:31 PM   #21
Also make sure brake-lines aren't routed in some weird way that causes them to be tightened when bars are turned. That will squeeze brakes too.
Please Help! I'm an idiot without front brakes! Falcor 2008 - 2012 Ninja 250R Tech Talk 14 May 1st, 2014 07:36 AM
Front brakes fast1075 1986 - 2007 Ninja 250R Tech Talk 4 January 22nd, 2014 01:45 PM
Front Brakes checho323 2008 - 2012 Ninja 250R Tech Talk 5 February 25th, 2012 02:16 PM
Questions about front brakes outasight20 1986 - 2007 Ninja 250R Tech Talk 21 December 27th, 2011 03:06 PM
