#5722 |
Board Member
One should do it every year.
#5723 |
Join Date: Nov 2012 Motorcycle(s): 2012 Ninja 250R, 2007 Ninja 650R, 2001 F650 Dakar Posts: A lot.
I may aim to do it more frequently than that, if necessary, though I really just want to find something that doesn't fling off like that. I really don't like goopy gunk building up and getting stuck in everything, then slowly dripping off when hot.
#5724 | |
#squid
Join Date: Jul 2011 Motorcycle(s): Track dedicated 2008 ZX6R Posts: A lot.
MOTM - Jul '16
Or every time you lube. Not that hard. Consider it weight savings ![]()
#5725 |
Board Member
Oh I do it a lot...
#5726 |
Going from track to street is harder... but I am ready for the benefit tomorrow.
#5727 |
Join Date: Dec 2013 Motorcycle(s): 2011 250R SE Posts: 326
Commuted on it to work. Noticed the mileage looked odd so I had to go almost a mile before pulling over and taking a pic.
You have to click on the pic to really see it... 12,345.6 miles |
#5728 |
Certified Troublemaker
Join Date: Oct 2012 Motorcycle(s): 2006 Ninja 250r "Pikachu", 2017 Ninja 650 "Epona" Posts: A lot.
Thats awesome!
![]() Raven's Rejuvenation ![]() ![]() A bruise is a lesson... and each lesson makes us better... |
#5729 |
Board Member
#5730 |
Join Date: Sep 2013 Motorcycle(s): Ducati 1198s, Triumph D675, Suzuki SV1000s, `08 Ninja 250, `11 Ninja 250, Suzuki GS750 Posts: 368
No pics yet, bought kit from aftermarketcycles, and also purchased a cheap 415 chain off ebay, its what I currently have on the bike. Going to see how long it last. The chain was $15 shipped compared to $80 for the DID from aftermarketcycles.
MCRA.com |
#5731 |
**** **** ****. I thought I was going to finish buttoning up the crankcase tonight but I ran into a problem installing a rod one of the bearings popped out while I was installing the cap and got wedged against the other bearing scratching both pieces. FML. Now I got to wait until next week to get new ones and pay a stupid shipping cost.
More scraping gasket maker....
#5732 | |
Board Member
I began installing my air/fuel ratio gauge. Should be done tomorrow. Excited... |
#5733 |
Which one did you go with? I was looking at getting one to wire into my GPX Pro.
MCRA.com |
#5734 | |
Board Member
I looked at the Wego III and a few others with data logging, but they were getting expensive and did not fit where I wanted to mount it. Koso has gauges that integrate the a/f ratio into the display but I did not want a whole gauge either. The only odd thing is how the manual goes into great depth to explain that the (O2) sensor has a short life-span. Considering car (O2) sensors last 100,000 miles or more, one would think that this sensor could at least last a few years. It also states that leaded fuels shorten its life further....so I guess I'm back to good ole petrol for a few weeks. |
#5735 | |
MCRA.com |
#5736 | |
#5737 |
Board Member
May also be because it is wideband. Just seemed odd.
#5738 |
Join Date: May 2014 Motorcycle(s): 2004 Ninja 250R Posts: 26
#5739 |
Fresh Deli Meat
Join Date: Feb 2014 Motorcycle(s): 2009 250R Ninja -Neener- Posts: 678
Nenette and I made some new friends tonight. A gixxer and a ducati were having a rev contest. We joined in
We shall call thee "Seahorse." -Antiant on Couvade Syndrome |
#5740 |
Hooligan
Join Date: Jun 2013 Motorcycle(s): 2013 Ninja EX300 Posts: 250
Gave it a bath and then took it for a ride to help it dry off. That's the best drying method, right?!
![]() Qui patiens est, teres. Teres est, ieiunare. | Twitter: @Rogue_300 |
#5741 |
Had to disconnect seemingly every cable, wire, and hose to get the birdcage (upper fairing stay) off just so I could figure out how best to route my HID wire harnesses. Was forced to go ahead and replace my leaking petcock while I was at it.
Now the bike won't stay on (sputters out eventually). ![]() |
#5742 |
Goobered up one do my valve shim bucket container area. Knocked the head off my make shift bench porting the head. I bent in the edge and it looks oblongish. Hope my repair doesn't cause any issues. ****ing Mosquitos.
#5743 |
Certified looney toon
MOTM Jul '13, Jul '14
Met friends IRL, added more miles, had friends swap the 250 pipe to the stock 300 exhaust, yanked a few hoses from the CA system and added a longer hose for the new overflow.
Test ride tomorrow to make sure all is well and good for the ride home.
![]() Hey Unregistered! The code [you] shows the username currently logged in. ![]() IBA # 56020 AMA # 521481 ![]() Hold yourself to the same rules you expect others to follow. |
#5744 |
#5745 |
Dark!!
Tomorrow. ![]()
#5746 |
MOTM - Sep '14
Found one rusty link?
![]() Keep calm and ride on ![]() Never quit on a rainy day -ally99 |
#5747 | |
Join Date: Jun 2013 Motorcycle(s): 2010 Ninja 250 Posts: 596
Someone needs to stand in the corner! |
#5748 |
Finally got in a decent ride to try out my new clip-ons, shorty levers, OEM R6 '06+ throttle tube, new heavier fork oil and .75 springs… Also wrapped my header. Fun times were had.
#5749 |
crash 250, get supersport
Join Date: Apr 2010 Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ Posts: A lot.
Talked to a neighbor that just got a 300, looks like they're loving every single second on it.
ZX-6R is officially for sale: https://www.ninjette.org/forums/showthread.php?t=186176 |
#5750 |
#5751 |
#5752 |
Board Member
Nice
#5753 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
Wondering where this extra bolt is supposed to go,
#5754 |
Board Member
Pic?
#5755 |
Parts in hand for a prep for races in PA this weekend.
![]() Previous text werd! foshizzle! brah! Thinking "ninjettor.org" this time around but hard to make outta black tape. Maybe save that one for the championship race weekend, since I am tied for 1st ![]()
#5756 |
Board Member
're jetting carbs....
#5757 |
#5758 |
I did finally put my air filter in... I'm kinda sad my bike isn't as loud, an doesn't pop like its nuts anymore... But I'm sure it's better for my bike, an my neighbors
I put three bolts in the wrong holes, and pretty much just slapped the fairings back together to get rid of a onlooker that was whining like a girl the whole time I worked on my bike. It hasn't exploded, and the fairings are more secure than I have seen on bikes, I just don't like extra parts, or knowing I got stuff in the wrong spot |
#5759 |
Researched on how to tackle my porting job on the head. Came about learning more stuff about the 300 head. Thinking of swapping to the 300 crankcase lower. Still debating. May swap to the 300 head after some repairs.
#5760 |
Rode over 200 miles, much of it through mountains and canyons. It was such a privilege riding the Crest with a relatively new rider, and so much fun.
Discovered something scary about my Ninjette today... | kjohng | General Motorcycling Discussion | 28 | October 15th, 2021 01:40 PM |
Sold the 2006 Ninjette today :( | Renner | General Motorcycling Discussion | 31 | October 16th, 2014 11:46 PM |
Today I Gave My Ninjette Wings! | BlueHairSar | Pictures | 5 | June 20th, 2013 07:38 AM |
my bro went down today on his ninjette | richierich781 | !%@*#$%!)@#&!%@ I crashed! | 46 | January 18th, 2013 11:59 AM |
Ninjette. org hacked today | CC Cowboy | Off-Topic | 9 | April 3rd, 2011 08:55 AM |
