Old August 14th, 2016, 08:14 AM   #7561
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
+1
Old August 14th, 2016, 08:22 AM   #7562
cuong-nutz
cuong-nutz's Avatar
HalfFast Racing Team
Old August 14th, 2016, 12:26 PM   #7563
Today is coolant, oil and chain cleaning day for me. Of course at the same time I will be checking for loose bolts and other problems. Next stop, brakes.... and I have some concerns in this area but will save that for tomorrow.
Old August 14th, 2016, 12:43 PM   #7564
cuong-nutz
cuong-nutz's Avatar
That reminds me, I need to replace my original rear brake pads.
Old August 14th, 2016, 12:53 PM   #7565
Gir-r-done!
Old August 14th, 2016, 01:02 PM   #7566
ForceofWill
Blind 250 Loving Whore
ForceofWill's Avatar
Just put a new chain on one of the bikes, do you leave that crazy thick wax on or clean it all off and use your own lube? It's covered in that crap.
Old August 14th, 2016, 01:25 PM   #7567
I clean off the "sling" after the first ride (after the chain gets hot) as well as wipe all "excess" off the chain itself. I hate cleaning the buildup around the front sprocket as much as I hate changing tires manually. The only other part worse is cleaning a rear shock.
Old August 14th, 2016, 02:12 PM   #7568
JohnnyBravo
It's about to be getting to new chain time round these parts too
Old August 14th, 2016, 02:36 PM   #7569
I know my bike(s) are far from perfect, but nothing says "I don't care about my safety than a dirty, unkempt bike." Soooo many times I have caught loose bolts, undone fasteners and such while simply wiping off wheels, engine and forks. Just do it and have a peek under at your oil drain bolt since you have your knees bent.
ps... You want extra "attention" at track day tech, show up with a dirty bike.
Old August 14th, 2016, 10:07 PM   #7570
cuong-nutz
cuong-nutz's Avatar
Oh man the chain too lol
Old August 14th, 2016, 11:02 PM   #7571
JohnnyBravo
Mine is pretty much dead from the looks of it
Old August 15th, 2016, 06:53 PM   #7572
cuong-nutz
cuong-nutz's Avatar
I have rear brakes again. Lost the peg a long time ago and also replaced the rear brake pads. I had an issue with the slide pin being siezed. Now the only issue I have now is the rear brake pressure switch is not activating the rear brake light. Fuggggggggg.
Does @csmith12 approve?
Old August 15th, 2016, 06:59 PM   #7573
No, your oil sight glass is terrible. lol
Old August 15th, 2016, 07:03 PM   #7574
cuong-nutz
cuong-nutz's Avatar
It's been rainy here lol
Old August 17th, 2016, 01:45 PM   #7575
BDfromBC
Motorcycle(s): EX250-J
Changed out my clutch springs a week and a half ago, and over tightened the bolt, causing the gasket to pinch,(so tight it sheared the bolt lol)
So today I got my new bolt and clutch cover gasket. Installed it and cleaned up the mess.
When I finished that, I threw on some new HH sintered pads up front... My front pads were TOAST!
Now to go do a little riding since I've been off the horse since the oil leak began!
BDfromBC is offline   Reply With Quote
Old August 17th, 2016, 03:29 PM   #7576
mgentz
Board Member
@Ghostt Cue up the caliper post....
Last futzed with by mgentz; August 18th, 2016 at 04:00 AM.
Old August 17th, 2016, 06:00 PM   #7577
LittleRedNinjette
Certified Troublemaker
LittleRedNinjette's Avatar
Raven's Rejuvenation
Old August 17th, 2016, 06:00 PM   #7578
BDfromBC
Originally Posted by mgentz View Post
@Ghost. Cue up the caliper post....
No doubt I thought that was coming before anyone else
But I did do some caliper maintenence.. not as thorough as he may, but I did what needed to be done... My bike is one year old
Old August 17th, 2016, 09:34 PM   #7579
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
ordered headers!
TEAM ALFALFA
www.apexassassins.com
Old August 18th, 2016, 04:59 AM   #7580
Ghostt
Ghostt's Avatar
I recommend that every time you change your pads, you service the calipers, he's my write-up to help you out. It should fix your initial problem, and keep your calipers in top working order.
For those of you whom are scratching their heads, here you go,*
Front Caliper Service (also rear as well)
Many folks have posted here with a Varity of front brake problems.
*Many of which are attributable to the lack of proper maintenance.
*Here’s how you can always have a brake like when your bike was new.
A short list of the problems and the causes.
Soft lever or lever goes to the bar.
The usual cause is the pistons are pushed too far back into the caliper by a flexing a warped, coned, disc.
*Using up too much piston travel before the disc is pinched.
Juddering in sync with wheel rotation.
The disc is worn, and its thickness varies. *This causes the caliper to “sink” into the thin part and when the thick part comes around, it gets wedged into a smaller space causing a tightening of the brake. Then the tight spot passes through and it like the brake is released. Then repeat, repeat.
Cupped, coned, or warped disc.
Unfortunately this is a common problem with EX’s the cause is the disc is stretched in the center due to being rigidly bolted to the wheel. *The huge force of braking is transmitted to the wheel through the webbed center of the disc which gets stretched and becomes larger than the space it occupies in the center of the disc. This causes the center to push to the side trying to find room for itself.
*Resulting is a cone shaped disc.
Soft lever 2
The caliper has pistons only on one side, so as the pads wear the caliper must shift sideways apply even pressure on both sides of the disc.
*To allow this the caliper floats on two pins. *If these pins get dry (no grease) dirty or bent. The caliper won’t center itself and bends the disc to wherever it is.
This take up lever travel and when released pushes the pistons further back than necessary.
*If not fixed will eventually destroy the disc (warp it).
Ok how to prevent all of the above.
When new pad time comes around, resist the temptation to just pop in new one and go.
*Every time you must do these things.
Remove caliper disassemble and clean it.
Clean and re grease the sliding pins.
Polish the caliper pistons to remove dirt. If you just push the pistons back into the caliper leaks will result. Or binding.
Tools required:
12 mm socket
8mm open end wrench
3” or bigger C clamp
a supply of new bake fluid.
wire brush and or steel wool.
Remove the caliper from the fork leg but leave the brake line on.
Remove the old pads and the mounting frame (the sliding pins)
Remove the cover from the Master Cylinder on the Handel bar.
Attach the C clamp to one of the pistons but don’t squeeze it. *Pump the lever on the bar slowly to push out the other piston almost all the way. *Put the C clamp on that piston and push out the other one.
Remove both pistons by hand.
Remove all the rubber part from the caliper, the seals are in the grooves in the caliper and dull pointed thingy will get them out easy.
Disconnect the caliper from the brake line.
Soak all the rubber parts in new clean brake fluid * ONLY!!!!! * Rub them with you fingers till as clean as new.
The caliper can be cleaned with a wire brush or even a Moto tool for the internal grooves, NOW’s the time to paint it if you wish.
Polish the pistons till they are smooth and shinny. They are chrome plated. If any of the plating is chipped or damaged below the dust cap groove. *Replace it.
The master cylinder is the subject of another write up and we’ll assume it in good working order here.
If you suspect your disc is bad, your bets bet is to replace it with an after market one fro EBC or Galpher.
*Don’t remove the disc unless you intend to replace it. *It will assume a new shape if it is * stressed and will not be flat again. You can try to check its condition by placing a straight edge across the face of the pad swept area looking for any distortion.
Re assembly
Take the nice clean rubber seals and install them into the caliper then the Dust covers.
Wet all the rubber with new clean brake fluid and partially fill the caliper with new fluid.
Push the pistons though the dust seals and into the caliper body until the dust covers snap into the grooves.
Fill the MC with new fluid and pump the lever while holding the Line above the MC till clean fluid flows.
Connect the line to the caliper while holding it above the MC.
Pump the lever with the bleeder valve open till fluid flow from the bleeder.
*Hold the caliper so that the bleeder is the highest point.
Close the bleeder and pump more fluid into the caliper but don’t push the pistons all the way out.
Then squeeze the pistons all the way back in and install the new pads.
Re grease the slider pins and assemble the dust seals and re mount the caliper on the forks but leave the bolts loose.
Now clamp the caliper to the disc with the brake lever.
Look at the space between the fork lugs and the caliper, clamp and release a few times as you tighten the bolts by hand. It one lug touches much before the other the odds are you mounting bracket is bent. You can straighten it.
*After you get it the best you can. Some shim washers made from alum can stock can be fitted to the loose side.*
** *What we are doing here is trying to minimize the bedd in time and gets the best pad life.
Ok with everything tight you should be through, Notice we don’t need to bleed the brakes, but if you screwed up in any of the above steps, you might do that here.
Be careful to Bedd in the new pads gently.
*Too much pressure too soon will burn the pad material as only a small area will be gripping at first. You also won’t have full braking power till the pads are fully familiar with the disc
I also recommend flush and fill with new brake fluid, also I'd go with 5.1DOT.
No matter what kind of brake fluid you choose, always periodically flush and fill with new fluid.
This is the one I use
https://m.motul.com/ca/en-us/product...-1-brake-fluid
Also inspect the brake lines, replace is needed, http://faq.ninja250.org/wiki/Stainle..._lines_upgrade
Venhill Introduction
Greetings everyone!
I wanted to take a moment to introduce you to Venhill...
Venhill manufactures some of the highest quality brake lines and cables you can get. We've been in business since 1971 and currently offer a full range of brake lines for the Ninja 250, first and second generations.
Our website, venhillusa.com, is setup to take orders for any year Ninja 250 as well as many other bikes. You can pick your bike and then customize your kits as you wish. We offer many different colors of hose as well as different finishes and materials for hardware. All of these options can be selected during the purchase process, so you'll be sure to get exactly what you want. You can even add length to hoses if needed.
To get an idea of our reputation, have a look at our eBay feedback.
If you have any questions or comments about Venhill products or brake lines or cables in general, please share them. I'm happy to be a resource for general information about brake lines and cables as well. Technical questions are welcome!
Please take a look at our website and let us know what you think. We just recently did a complete makeover and are interested in feedback. (venhillusa.com)
Have a great day and stay safe,
Chris
Venhill USA
For the detail oriented out there, some interesting things you might want to know about Venhill and our products:
Our factory is ISO 9001-2000 approved, which basically means we have the ability to consistently produce quality products. To qualify for ISO approval your factory and quality control mechanisms are evaluated as to whether your "good" products happen by chance, or if they are a result of good quality control.
All of our hoses are built to DOT/TUV spec and have been certified as such. We submitted hoses to the TUV (German DOT) for testing and only by passing are we allowed to use the TUV symbol on our hoses. Every hose we sell is built to these specifications, even if it is for track or offroad use only. It just makes for a higher quality product.
All of our hoses are hydraulically crimped, not hand crimped, and leak/pressure tested in a water bath. Yes, we immerse every hose we build in a water bath and pressurize it to check for leaks and to verify integrity of the crimps.
Venhill's hose core is authentic DuPont Teflon which is more expensive than generic "PTFE" but is stronger with a smoother inner bore. This is surrounded by 96 strands of braided marine grade stainless wire. 96 strands is more dense than some other braided line brands and the marine grade alloy is a stronger metal, which reduces expansion, the reason rubber hoses feel "spongy". Finally, we coat the braid with a UV-resistant PVC, extruded on during manufacture. This protects the hose as well as body and paint work.
Our hose design uses free-floating swivels, which allow you to loosely install everything before the hoses are tightened into place. This ensures the hose is not forced into a twist or kink when the banjo bolts are tightened. If you're worried about leaks, don't be. Our swivels work on the same premise as every threaded connection on a car or truck.
As you can see, we're sort of obsessed with quality and safety. We look at it this way: If we're asking you to put our brake lines on your bike, you're trusting us with the integrity of your brakes. That's a serious concept and we refuse to compromise when it comes to the integrity of your brakes.
I have these stainless steel lines on my Ninjette, and so far, some good, I recommend getting the stainless steel banjo bolts, I noticed my chrome ones have started to rust slightly, a good excuse for me to upgrade to titanium
On my 91 EX500 I have Spiegler, in orange to match that bike.
So you have made the decision that your OEM rubber lines need to be changed.
So why choose Spiegler Brake Lines?
A: Strength
That’s the short answer. But it doesn’t tell the whole story.
Spiegler Brake Lines strength comes from our innovation and research, materials and construction, knowledge and experience, service and support.
At Spiegler, we believe that the more you know about what we put into our products, the better you’ll be able to answer that question yourself.
That’s the short version; now let’s cover this topic more in depth.
Most OEM manufacturer recommend that you replace your rubber brake lines every 2 to 3 years. Why do the OEM’s recommend this? Over time OEM rubber lines deteriorate rapidly due to expansion and UV damage. This leads to increased braking distances and possible failure.
At Spiegler, our brake lines are made of only the finest materials available.
Outside casings are made of tightly woven stainless steel braiding that exceeds our competitors
The inside is made with DuPont’s PTFE-Teflon which eliminates expansion and adds durability
Crimp sleeves are made from stainless steel; competitors are using mostly carbon steel
Unique patented adjustable banjo fittings eliminate line twist during installation.
30% weight savings in comparison to other stainless steel braided brake lines
DOT approved
Lifetime warranty
117 color combinations possible which allows customers to personalize their bikes
We can build your lines to any specifications for custom applications
All brake line kits come ready for install
For more information on why you should choose Spiegler Brake Lines, you can view the following pages for a more detailed look into Spiegler brake lines.
When it comes to safety items like brakes, when in doubt, throw them out, it's your safety in your hands, and is cheaper than a visit to the ER.
Buy quality pads,I personally recommend EBC brand either the HH, or the Extreme HH.
EBC full floating rotor, replace the OEM rubber line with a stainless steel braided brake line, cheaper than replacing them with OEM.
On my 500 I have Spiegler line
http://www.spieglerusa.com/brakes/cy...line-kits.html
On my Ninja 250 i went with Venhill
http://www.venhillusa.com/products.html
With all that, it will stop on a dime, and leave you nine cents in change.
look here http://ebcbrakes.com/products/motorcycle/
And also read this, http://www.ex-500.com/wiki/index.php...otors_and_Pads
That should answer any questions you might have.
violente et ignorantia
ZX-2R BLOG
Old August 18th, 2016, 05:01 AM   #7581
Ghostt
Ghostt's Avatar
Which brand of springs did you decide on? And how did you like them?
ZX-2R BLOG
Old August 18th, 2016, 07:55 AM   #7582
BDfromBC
Red face
I went with EBC as the brand. Honestly, a lot less change in feel then I expected on the 300, with its 3 springs... On the 250 I felt a night and day difference doing the same change (4 springs) last year.
I could sense some slight slippage in high rpm @ lower gears, it did remedy that for certain
I'd say on the 250 your lever gets about 15-18% stiffer, on the 300 it gets about 8-10% stiffer, hopefully that gives a little insight or review on these springs
Old August 18th, 2016, 08:17 AM   #7583
...Did you hear that? that was the joke flying over ghost's head!
Thanks for being such a huge help here, Scott. Just giving you a rough time.
Old August 18th, 2016, 11:09 AM   #7584
tgold
Motorcycle(s): 2006 1050 Speed Triple, 2010 250 Ninja racebike, YZF320RR? Racebike
MOTM - Nov '15
Ordered a 13 tooth sprocket for the racebike as the track configuration for the next round has a significantly shorter main straight. Top speed will be around 7.5mph slower than with my 14/46 gearing.
Took the caliper apart and polished the pistons to a mirror finish. Yes Ghostt, I replaced the seals
Bought a programmable ignition, but I decided to wait to install till I can schedule some dyno time before trying it out.
Looking at installing an FZR400 axle as well. Same diameter as the 250 Ninja but a little longer and it's hollow. If it works then I can make my own Pitbull style trailer restraint.
tgold is offline   Reply With Quote
Old August 18th, 2016, 06:37 PM   #7585
Ghostt
Ghostt's Avatar
@BDfromBC I recommend changing them out to the Barnett springs for a ZX600, it's a common upgrade for the EX500.
@choneofakind no worries, it's all in good fun.
ZX-2R BLOG
Old August 18th, 2016, 07:16 PM   #7586
mgentz
Board Member
I actually like his write up...
Old August 18th, 2016, 11:03 PM   #7587
JohnnyBravo
It's way better than mine
Old August 19th, 2016, 03:26 AM   #7588
Ghostt
Ghostt's Avatar
Thank you both, it's comprised of my many, many years working on bikes.
Calipers are one of the most overlooked items on a bike, I'd rank it up there with valve adjustment.
Another thing is that while it's written for bikes, it also works for cages as well.
As we all know the front does almost all of the stopping, in the case of the Ninjette all you have is one disk, one caliper, this is why I stress the importance of doing the caliper maintenance.
It's easley enough done, and free most of the time if you don't require parts. If you do require parts, it because you took time to look at them carefully, something that wouldn't happen of you just pop the new pads in.
I fully understand the need to get it up and running ASAP, but doing the maintenance only takes a few minutes.
Considering the alternative, ER, hospital, lost time at work, damaged bike, etc... Or even worse, it's really a No-brainer.
IMHO.
ZX-2R BLOG
Old August 19th, 2016, 10:18 AM   #7589
JohnnyBravo
^+111111111
Cleaning a chain that looks like a model t that's been left out in a field since the civil war
Old August 19th, 2016, 11:30 AM   #7590
cuong-nutz
cuong-nutz's Avatar
^+111111111
All this rain doesn't help with my chain either.
Old August 19th, 2016, 11:36 AM   #7591
JohnnyBravo
Did y'all get flooded good like my family in CenTex? Their cows were swimming laps
Eh gonna have to replace it before the track... It's beat like a red headed stepchild
Old August 19th, 2016, 07:51 PM   #7592
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
Motorcycle(s): '09 250 SE 'Booger'
Pulled the snorkel and took 'er for a spin. Louder, hurt power in lower half of rev range, but now pulls all the way to redline instead of falling off past 11k or so. Should be nice on the track but for the street id prefer the snorkel in place.
Raised the idle speed ~100 rpm a few days ago and engine braking was hugely reduced! Just what I wanted, the engine braking was driving me crazy on the track. Cant wait till my next track day.
Last futzed with by Dave Wolfe; August 19th, 2016 at 07:53 PM. Reason: Typooo
Dave Wolfe is offline   Reply With Quote
Old August 20th, 2016, 09:46 AM   #7593
cuong-nutz
cuong-nutz's Avatar
It wasn't as bad here but I have decided it wasn't worth the work to ride on a rainy day especially with all the knuckleheads on the road.
Old August 20th, 2016, 12:05 PM   #7594
JohnnyBravo
Thumbs up
I don't ride in the rain unless I have too
Old August 20th, 2016, 02:17 PM   #7595
Try shimming the needles up with 1 or 2 SAE #4 washers and playing with the idle mix screws as needed. That will add fuel in the mid-throttle range and take care of that lower RPM lag/midrange hesitation.
From the factory, they're jetted less rich than optimum with the needle height and idle mix screw setting so they can be deemed acceptable by the EPA, but then the top end WOT has a bigger jet than needed to protect the engine at high RPM and big loads. A little playing with the jetting goes a long way.
Old August 20th, 2016, 02:50 PM   #7596
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
I did all that when I got the bike last year. Made a dramatic difference to the lower rev range. A de-snorkled bike on stock jetting would be horrible.
Im gonna leave jets as-is for now. It carburates cleanly at low revs still, just down on power a bit. No worse than a stock bike Id say.
Old August 23rd, 2016, 08:08 AM   #7597
sp3ak
Installed an LED brake light bulb (from superbrightleds.com) and a modulator (https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1). Pleased so far as I've tested in in the warehouse, will see how it does out on the street.
I decided on the LED bulb as I was reading most of the modulators work better with them as the LED can keep up better with the pulsing. This modulator does 4 fast and then 4 slower flashes before staying solid (no configurations available, hence the lower cost). I'm looking forward to using it to get people to back off my bumper a bit. I don't know if it's just me but people seem to like to ride up on me a lot. I know my speedo is off by about 8%-10% as I've verified it with GPS (got the info from the 250wiki) but jeez lay off!
Enjoy working on your Ninja's today, here in NC it's a great day to ride!
sp3ak is offline   Reply With Quote
Old August 23rd, 2016, 08:32 AM   #7598
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!)
MOTM - Nov '15
Rolled over 10k km last night. I predict a valve check is on the agenda this weekend!
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over
SLOWn60 is offline   Reply With Quote
Old August 24th, 2016, 04:21 PM   #7599
Chicagobob
Chicagobob's Avatar
Motorcycle(s): '06 Ninja 250, 2018 Honda GL1800B
Rim tape "removal"
Black Sharpie to the rescue. PO's yellow rim tape is hidden!
Chicagobob is offline   Reply With Quote
Old August 25th, 2016, 10:10 AM   #7600
sp3ak
@Chicagobob - I was checking out your build thread, looks really great!
I took my first run on the highway today. Merged in with traffic no problem and cruised at about 70mph. Just had to go down one exit but I felt like it was very smooth and that I had plenty of power.
Discovered something scary about my Ninjette today... kjohng General Motorcycling Discussion 28 October 15th, 2021 01:40 PM
Sold the 2006 Ninjette today :( Renner General Motorcycling Discussion 31 October 16th, 2014 11:46 PM
Today I Gave My Ninjette Wings! BlueHairSar Pictures 5 June 20th, 2013 07:38 AM
my bro went down today on his ninjette richierich781 !%@*#$%!)@#&!%@ I crashed! 46 January 18th, 2013 11:59 AM
Ninjette. org hacked today CC Cowboy Off-Topic 9 April 3rd, 2011 08:55 AM
