January 13th, 2015, 07:12 AM | #41 | ||
Inline 4!!!
January 13th, 2015, 09:10 PM | #42 |
ran when parked
Join Date: Aug 2013 Motorcycle(s): Freeride 250R, KLX250SF, mopeds Posts: A lot.
MOTM - Sep '17, Dec '14
Instagram: @katie.baden |
January 23rd, 2015, 08:38 PM | #43 |
ran when parked
installed the new radiator. bike starts up fine with the tipover sensor connector plugged in, but until I get a new headlight I can't ride it at all. tipover sensor is located in the headlight.
discovered the cam chain rattling around. need to order a manual cam chain tensioner which I have to call in from work to get the discount. should cost me about $43. the bike also needs a front tire, so I'm going to take the tire of my SV650 and put it on this bike and the SV will get a new rosso 2 front tire. it also needs rear brake pads. the rear rotor is a bit wavy but I measured it and it's within spec. also needs a new ignition, someone tried to steal it and someone replaced the ignition with a crappy chinese one that's all messed up.
January 24th, 2015, 04:18 AM | #44 |
Manual cam chain tensioner. How do you know when it's properly tensioned? Start the bike and adjust the tension until the kawi tick is gone?
January 24th, 2015, 09:02 AM | #45 | |
It takes an ear for it. When you're done, you should be able to hear a faint tick at idle but it should be silky smooth sounding when reving. Did I mention DO NOT OVERTIGHTEN?!?!?!?
January 24th, 2015, 01:52 PM | #46 |
Join Date: Apr 2011 Motorcycle(s): 2002 Honda 919, 2004 Ninja 500R NAKED Posts: A lot.
Just to clarify a little, the rattle you hear is the actual mechanism inside the CCT rattling and NOT the cam chain itself. You could ride the bike forever on the stock CCT with the rattle and it would never hurt a thing, hence why Honda never recalled them, it's just annoying to hear the rattle.
Manual CCTs are great though, My F4i came with one. You'll know if it's too loose or too tight, I got mine on a little tight after my valve adjustment and I could hear a faint whine from the overtensioned cam chain. I just backed it off a little and started the bike to make sure it sounded right. Another little word of advice, take the throttle bodies off for the CCT install, it'll make it soooo much easier for you. You should be able to adjust it without removing anything IIRC, as long as you have a good assortment of wrenches lol. |
January 24th, 2015, 07:44 PM | #47 |
ran when parked
cheers people. thanks for the advice. that's pretty much consistent with what I heard and what I was planning. this is where I call my coworker over from his lift next to me to make sure I don't **** it up
January 24th, 2015, 07:47 PM | #48 |
ran when parked
came to work today to see some coolant underneath the bike. the water pump hose and pipe was pretty grimey and I cleaned it off but apparently not enough or didn't tighten the clamp hard enough. I moved the hose up a little and added another clamp. what's better than one radiator hose clamp? TWO RADIATOR HOSE CLAMPS!! this is called 'PERFORMANCE MODS' people.
February 21st, 2015, 03:33 PM | #49 |
ran when parked
gettin there....
installed the headlight and cleaned up the wiring. I need to solder something in the kill switch area and install the rest of the bodywork (working on getting a fairing as I type..) starts & runs & rides but it snowed 6 inches so I couldnt do a victory lap round the parking lot
February 25th, 2015, 03:34 PM | #50 | |
February 26th, 2015, 08:33 PM | #51 |
ran when parked
haha no thanks, I think I'm just going to sell it, put 3/4 of the money into my savings for college and spend the rest on gear and upgrades for my SV!
should receive a black OEM upper fairing tomorrow almost ready to get goin.. here's the stuff I had to/have to get done to it before it's 100% ready to be sold and MD state inspected -radiator install w/coolant flush ($79) DONE -headlight install w/replace fuse ($75) DONE -install cam chain tensioner ($43) -clean up right handlebar controls ($0) DONE -clean up front subharness wiring ($0) DONE -fr/rr brake fluid flush ($0) -rr brake pads ($19) -fr tire ($0 - takeoff from my SV which is getting a new rosso II) -oil/filter change ($4) -fr fairing ($111) -clutch lever ($6) -right side mirror ($20) -grips ($10) -ignition/key replace ($4? takeoff from cbr600rr) -adjust/lube cables/pivot points ($0) -clean/lube/adjust chain ($0) just to let you know what kinda stuff goes into repairing crash damage and getting a bike ready for selling. if i didnt work at a shop these prices would be a LOT higher lol
February 28th, 2015, 04:00 PM | #52 |
ran when parked
much progress today!!!!
4 out of 4 members found this post helpful. |
February 28th, 2015, 10:13 PM | #53 |
bixenon in the low beam side!!!
March 20th, 2015, 07:39 PM | #54 |
ran when parked
I installed the APE manual cam chain tensioner a couple days ago. it was a huge bitch. the tensioner is right behind the frame in a place that's pretty hard to get to. but in total it took me about two hours start to finish. 100% eliminated the cam chain rattle.
it looks so good, I almost wanna keep it. I got a set of used oem mirrors today and I have brake pads and a clutch lever to throw on maybe tomorrow. I listed it on craigslist for $3900 or best offer but I haven't had any bites yet. If I can't get $3300 for it I'll probably just keep it.
March 20th, 2015, 09:30 PM | #55 |
just list it as $2500 + fees and then once they've looked at the bike haggle them down from 3800 to 3300 so they feel like they got a good deal on those stupid dealer fees
March 23rd, 2015, 06:32 AM | #56 |
Fighting Texas Aggie '05
GLWS - a nice F4i is actually the bike that keeps jumping up in my mind as the bike I would like to pick up. Every time I ride the 6R on the street I just keep thinking I would enjoy something similar but with a bit more comfort.
April 19th, 2015, 04:30 PM | #57 |
ran when parked
SOLD!
to a squid in shorts and flip flops for $3,000 cash. byebye bike.
April 20th, 2015, 04:48 AM | #58 |
Certified Troublemaker
Join Date: Oct 2012 Motorcycle(s): 2006 Ninja 250r "Pikachu", 2017 Ninja 650 "Epona" Posts: A lot.
Congrats on the sale!
Raven's Rejuvenation A bruise is a lesson... and each lesson makes us better... |
[motorcyclenews.com - news] - 50 quick road miles on the new Honda CBR600 | Ninjette Newsbot | Motorcycling News | 0 | May 5th, 2013 09:30 AM |
Honda CBR600 FS2 (F4i) In beautiful colours! | Matz | The Ex-Ninjetters Lair | 1 | March 30th, 2013 09:39 PM |
Letting Go! 2006 CBR600 F4i | bluebr65 | The Ex-Ninjetters Lair | 12 | July 24th, 2012 12:26 PM |
My "new" 1999 Honda CBR600 F4 | Anthony_marr | The Ex-Ninjetters Lair | 19 | May 15th, 2011 08:22 AM |
