October 2nd, 2014, 12:04 PM | #201 |
Do I understand it right that the frame is made of steel? Or aluminium. And intended to be flexible and stable for high-speed riding. I thought stiffer was better at high speeds. My interpretation: they selected a manufacturing method that is cheaper/easier for small volumes. Just need to set up a shop with a frame jig.
And the fuel tank seems tiny. Perhaps 10 L. If my fuel gauge starts flashing with 3.5 L remaining, corresponding to almost 100 km range, the fuel gauge on the H2 will flash as you exit from the gas station after a fill-up. One might also wonder at which tracks you would benefit from 300 hp. As I understand it even MotoGP stopped long ago trying to get the most hp from the engines, since they are at max throttle with no restriction from traction control only a few seconds per lap. Instead it's all about finding a combination of engine and traction control that gives best drive out of the turns. Spa maybe? Hockenheim? No typical motorcycle tracks. And the time you gain per lap must be gained at the longest straight, by reaching perhaps 330 km/h instead of 300 km/h for a few hundred meters, then braking maybe 50 m earlier? Still want one but not sure why. |
October 2nd, 2014, 12:41 PM | #202 |
I want to see the H2R ridden at the Isle of Man TT! Obviously it won't be able to run in any race class but I'm curious to see what lap times it would run. Now that would be an insane video!
October 2nd, 2014, 12:48 PM | #203 | |
World Class Ninja
Join Date: Sep 2014 Motorcycle(s): 2002 Ninja 250, 96 VFR750, 79 Yamaha XS1100 Special Posts: 224
That would be nuts probably one of the few places where this kind of power might decrease laptimes. The only other place would be Pikes Peak that i could think of
Life is not a journey to the grave with the to arrive safely in one pretty and well preserved piece, but to skid across the line, thoroughly used up, worn out, leaking oil, shouting, GERONIMO! |
October 2nd, 2014, 01:26 PM | #204 |
Mr. 988
Blast to the past. The old Rad Greaves Hayabusa had canard wings. Unlike the H2, the Greaves RadBusa had, what looks like, wings attached to the axles
"I'm the one that's got to die when it's time for me to die, so let me live my life, the way I want to" - Jimi Hendrix Cancer |
October 2nd, 2014, 03:03 PM | #205 |
Join Date: Jun 2012 Motorcycle(s): 2013 Ninja 300 Posts: 718
People forget about the Hayabusa when they call the H2R ugly.
DISCLAIMER: I generally have no idea what I'm talking about. |
October 2nd, 2014, 04:34 PM | #206 |
It's not as simple as "it has to be stiff" or "its too flexible...
Don't make me launch isn't my rant on chassis design again. |
October 2nd, 2014, 04:36 PM | #207 |
Private Joker
MOTM - Mar '14
also, I agree the busa is ugly while this has it's redeeming characteristics, it's just over the top styling instead of looking just plain bad
October 3rd, 2014, 03:27 PM | #208 |
Join Date: Apr 2011 Motorcycle(s): 2002 Honda 919, 2004 Ninja 500R NAKED Posts: A lot.
Maybe they'll lop off a cylinder and down the boost and give us that supercharged 750 triple we all want
October 5th, 2014, 07:29 AM | #209 |
Mr. 988
October 5th, 2014, 08:12 AM | #210 | |
And there needs to be a good bit of profit on top of that! |
October 5th, 2014, 08:42 AM | #211 |
60,300.00 for the dealer?!?!
I'd expect that to list at at least 80,000 and they'll maybe have ONE for show off purposes only. Probably closer to 90,000 |
October 5th, 2014, 08:50 AM | #212 |
Certified Troublemaker
Join Date: Oct 2012 Motorcycle(s): 2006 Ninja 250r "Pikachu", 2017 Ninja 650 "Epona" Posts: A lot.
Raven's Rejuvenation A bruise is a lesson... and each lesson makes us better... |
October 5th, 2014, 10:41 AM | #213 |
World Class Ninja
Well i guess it is more of a hyper bike then I imagined.
October 5th, 2014, 10:42 AM | #214 |
World Class Ninja
that more then the Mission RS + GP package holy sheeet
October 5th, 2014, 11:24 AM | #215 |
I guess their target 'competition' was the likes of the Desmosdici or the very super duper high end Panigale? That's in the neighborhood of 60,000 right? I don't know much about the pricing of anything that expensive.
October 5th, 2014, 12:06 PM | #216 |
That's stupid expensive. I'd rather have one of these! Much more useful and it costs $78,995.
October 5th, 2014, 01:56 PM | #217 |
Join Date: Dec 2013 Motorcycle(s): Ducati 999 2012 Ninja 250r Ducati748 Yellow finally running 2003 SV650 S (SOLD) Posts: A lot.
I think the only track this bike will see is 1\4 mile long where you can use full throttle almost the entire 5-6 second race! This bike does not seem to be race course oriented like the superleggera and I bet the Ducati could lap a track a few seconds quicker but the H2 would pull it on the straights
October 5th, 2014, 03:42 PM | #218 |
Join Date: Sep 2013 Motorcycle(s): 2006 Ninja 250, 2004 Buell XB12s, Honda 110 Elite Posts: 332
There is no way that bike would be intended for 1/4 mile racing. Too tall, too short. Now the engine on the other hand in a properly designed drag chassis (if the transmission ratios are appropriate) would be "interesting". It could go mid to low 7's. But I bet it would not be very durable for drag racing at all.
The tubing chassis makes sense in multiple ways, including leaving plenty of room for engine/plumbing. In reality, it is just boastful display of engineering capability, and it's intended mark is the new "world's fastest production motorcycle". If you want to see a real one, I'll bet they will have one or two on display at the AIM show in a couple of weeks in Orlando.
"They don't pay me enough to ride this thing!" Kenny Roberts after winning the Indy Mile on the TZ750 powered Grand National bike. |
October 5th, 2014, 03:44 PM | #219 |
World Class Ninja
Pikes Peak that is all.
October 5th, 2014, 04:45 PM | #220 |
Teaser 'Track or Street' Video
Apparently one of the street promo vids got leaked. Here it is.
Link to original page on YouTube. |
October 5th, 2014, 05:34 PM | #221 |
Join Date: Jun 2013 Motorcycle(s): N650 (and others) Posts: 408
That's the one I saw, told you, $60000 invoice!
October 5th, 2014, 07:56 PM | #222 |
Inline 4!!!
I think that hayabussa isn't ugly... I don't know, It's not "great looking" but it's not ugly either.
As for the 60k price tag for the DEALER, that's INSANE! Any guesses on the price tag on the street edition?
October 5th, 2014, 11:20 PM | #223 |
I ripped this from the youtube video above:
October 6th, 2014, 12:51 AM | #224 |
Freedom for Germany
It looks like the competition starts... http://www.yamahamotorsports.com/sport/sneekpeek.aspx
October 6th, 2014, 08:17 AM | #225 | |
October 6th, 2014, 07:58 PM | #227 |
Join Date: Dec 2008 Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike Posts: 890
October 6th, 2014, 08:02 PM | #228 |
Private Joker
MOTM - Mar '14
is yamaha ever going to come out with a new r6? They've gotta do something with it to drive the used market prices down
October 6th, 2014, 09:33 PM | #229 |
October 6th, 2014, 10:25 PM | #230 |
nm, rear lights may be a requirement under wet conditions, it's late, wasn't thinking.
October 7th, 2014, 06:26 AM | #232 |
World Class Ninja
its tough to tell with nothing else to compare it too as well as the relatively short shots, I mean it is a large bike, and from what I can hear I doesn't sound like it is in the right rpm range to make the power it needs to come out of the corners quickly. A few of those shorts were very grunty, and where is the chirping.
October 7th, 2014, 06:41 AM | #233 |
It will be hard to hear the chirping normally, probably. Welcome to marketing? Last futzed with by xorbe; October 7th, 2014 at 08:58 AM. |
October 7th, 2014, 06:46 AM | #234 |
It's usually that way with all factory vehicles...
Paint side up, rubber side down! |
October 7th, 2014, 06:53 AM | #235 |
MOTM - Sep '14
Keep calm and ride on -Motofool Never quit on a rainy day -ally99 |
October 7th, 2014, 08:23 AM | #236 |
You must've missed this:
October 7th, 2014, 09:36 AM | #237 |
I can't even imagine hitting a bird at 200+mph, but Derek Keyes, an R&D rider for Kawasaki did just that on the H2R. What a mess!
http://lanesplitter.jalopnik.com/not...3098822/+damon |
October 7th, 2014, 01:51 PM | #238 |
Niiiiicceeee
October 7th, 2014, 02:04 PM | #239 | |
World Class Ninja
October 7th, 2014, 02:41 PM | #240 | |
Private Joker
MOTM - Mar '14
pikes peak the extra power is indeed useless
[visordown.com] - Kawasaki’s supercharged four-cylinder engine | Ninjette Newsbot | Motorcycling News | 0 | November 20th, 2013 12:30 PM |
[visordown.com] - Victory anniversary bike launch this month | Ninjette Newsbot | Motorcycling News | 0 | January 8th, 2013 11:00 AM |
[topix.net] - TVS Motor to launch '125cc' Phoenix this month | Ninjette Newsbot | Motorcycling News | 0 | September 12th, 2012 02:50 PM |
[visordown.com] - Supercharged 90bhp 100kg Cagiva Mito | Ninjette Newsbot | Motorcycling News | 0 | June 18th, 2009 01:20 PM |
[visordown.com] - Classic supercharged Vincent sells for £200,000 | Ninjette Newsbot | Motorcycling News | 0 | October 20th, 2008 07:10 AM |
