September 16th, 2013, 07:55 PM | #1 |
Join Date: Apr 2013 Motorcycle(s): Triumph Street Triple R Posts: 380
To bleed or not to bleed...
Getting ready to install my Vortex rear sets. I bought the replacement banjo bolt with the inline pressure sensor which means that I need to remove the stock banjo bolt from the master cylinder and splice stuff up.
Just wondering if I should play it safe and bleed the rear brakes since removing the banjo bolt will leak brake fluid. |
September 17th, 2013, 05:26 AM | #2 |
Join Date: Dec 2008 Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike Posts: 890
Yes, you should bleed the brakes.
September 17th, 2013, 03:59 PM | #3 |
Should I drain all of the old fluid or just bleed and top off the reservior (have a mix of old and new fluid)? Does it actually matter?
September 17th, 2013, 04:09 PM | #4 |
MOTM - Jan '18, Sep '13
I would just bleed until the brake feels firm again.
September 17th, 2013, 05:20 PM | #5 |
I'm crazy,your excuse is?
Bleed it all out, nothing is better than all new fluid probably took longer to post and come back than to have flushed it all out.
October 4th, 2013, 09:06 AM | #6 |
Join Date: Aug 2013 Motorcycle(s): 2013 Ninja 300ex SE(non-ABS) Posts: 15
^Agreed. If you're going to do anything, why do a half job. Treat your bike right and she'll treat you right
October 4th, 2013, 10:23 AM | #7 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
Though you could get away with a lil old an little new, why half booty it? It will be more work to go all the way, and your fluid probly isn't that old, so you should be fine either way, but a full job is better than a quick fix if your not in a pickle... Your not in a pickle are ya?
October 6th, 2013, 04:43 PM | #8 | |
October 6th, 2013, 10:10 PM | #9 |
You bleed at the master cylinder by loosening the banjo bolt. Use towels around it since it's going to be a bit messy.
October 7th, 2013, 02:40 AM | #10 |
Join Date: Aug 2012 Motorcycle(s): '11 250R SE (FI), '14 Daytona 675, '14 Sprint 1050 GT SE Posts: 121
We had a similar task this weekend on Akima's and my Ninjas for a group braided line fitting. We realised after fitting the lines that whilst the caliper was bled of air, there was still air trapped at the top of the line, in the union/banjo bolt area.
I didn't think of loosening the banjo bolt, so our solution was to briefly disconnect the lever and reservoir assembly from the bar, and pump the lever whilst trying to coax the air bubble up past the piston back into the (sealed) reservoir. This seemed to work for us. I would have worried cracking the bolt loose in case the crush washers shifted but I guess we're talking *just* cracked enough to pass air/fluid then torqued back up again. Interesting... Cheers, Pete |
How do you guys bleed your brakes? | psych0hans | 2008 - 2012 Ninja 250R Tech Talk | 7 | June 10th, 2014 07:01 PM |
Would you rather sweat or bleed? *Graphic images* | cuong-nutz | Motorcycle Gear | 48 | July 18th, 2013 07:17 AM |
How to bleed the brakes questions. | Mr.E | 2008 - 2012 Ninja 250R Tech Talk | 8 | November 2nd, 2011 10:00 AM |
do I need to bleed the brakes? | nickadolph | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 5th, 2011 01:27 AM |
tube for brake bleed | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 10 | June 26th, 2009 08:17 AM |
