View Poll Results: Kickstand pivoting.. yay/nay? | |||
Yay! | 22 | 41.51% | |
Nay! | 31 | 58.49% | |
Voters: 53. You may not vote on this poll |
Thread Tools |
June 28th, 2013, 07:34 PM | #41 |
Fix It Till Ya Break It
Join Date: Oct 2011 Motorcycle(s): 08 250RRrrrr Posts: 623
i do it all the time, i find the kick stand on the 250 much beefier than a super sport, but then again i usually bear hug the thing when i pick it up, so not all the weight is on it.
July 2nd, 2013, 02:23 PM | #42 | |||
July 2nd, 2013, 02:28 PM | #43 | |||
July 2nd, 2013, 02:59 PM | #44 |
Join Date: May 2013 Motorcycle(s): '75 CB550:.'82 XV920:.'00 KLR650:.'00 EX250:.'08 Ninja 250 Posts: A lot.
MOTM - June '15
I have done it many many times in the last 19,000 miles on the KLR a few times with the XV, CB550, and most recently the ninja.
The KLR is 400 pounds and TALL never an issue, I also mount the KLR like a horse (whil it is on the stand) because it's so tall I can't swing a leg over.
'82 XV920: Soon to be tracker--'00 KLR685:adv --'04 DRZ400E--'12 Super Tenere --'13 Versys Ride more, worry less. |
July 2nd, 2013, 05:58 PM | #45 |
I don't have a kickstand...
July 2nd, 2013, 06:02 PM | #46 |
Join Date: Apr 2013 Motorcycle(s): '04 919 / '08 250r / '95 xr100 Posts: 39
I do it to wiggle out or into a tight spot in the garage, never all the way around - will have to give it a try
July 2nd, 2013, 06:13 PM | #47 |
I'm crazy,your excuse is?
gonna try it too
July 2nd, 2013, 06:35 PM | #48 |
Fast-Guy wannabe
MOTM - Jan '13
Ever since I moved into my new place(2 months ago) i spin the bike a full 270 every day. I tried in the past just to see if I could and I was never able to get it to balance. Once I needed to though I figured out the handle bars need to be turned to the right and not the left and then it was easy.
I'm going to say it adds a lot of stress to the joint and may waller it out over time if you to abrupt with transition the weight on and off but if you smooth you shouldn't see any problems for a long time. Just regularly check that bolt like you should anyways and you be safe. |
July 2nd, 2013, 06:38 PM | #49 |
Fast-Guy wannabe
MOTM - Jan '13
Oh and I only hold the handle bars putting all the weight on the stand, it was the easiest way to do it in my opinion.
July 5th, 2013, 07:50 PM | #50 |
I do it all the time, never had any problems
July 6th, 2013, 04:58 AM | #51 | |
The tip will dig into the surface.
July 6th, 2013, 03:02 PM | #52 |
Cheers, think I'm starting to get the hang of it, but I'll need to get a short plank or something to keep the patio from getting wrecked.
Turning the bars all the way right, left hand on the right bar, right hand on the Y shaped part of the frame, pull it up onto the stand, push the rear down a bit to balance it & it's easy to turn it. |
July 6th, 2013, 07:41 PM | #53 | |
July 7th, 2013, 09:20 AM | #55 |
^^ the 90's called, they want that entire video back...
July 7th, 2013, 09:22 AM | #56 |
Yes to kickstand pivot
Chest Protector... Yay/Nay??? | deeno415 | Motorcycle Gear | 44 | September 5th, 2013 12:47 AM |
[superbikeplanet.com] - Lord, Help Me, I Can't Cha-eyay-yay-yay-yay-yaaaannnge. | Ninjette Newsbot | Motorcycling News | 0 | June 12th, 2013 10:20 AM |
Fork Oil change, Yay or Nay?? | LoneRonin | 2008 - 2012 Ninja 250R Tech Talk | 6 | April 3rd, 2013 08:16 PM |
Call of Duty: Black Ops II - Yay or Nay? | ajcadoo | Off-Topic | 31 | May 3rd, 2012 08:39 PM |
Putting sticker/vinyl/decals to personalize your Ninja...yay or nay? | dkstariob | General Motorcycling Discussion | 28 | January 15th, 2011 08:27 PM |
