January 29th, 2015, 11:06 PM | #1 |
Shifter spring to tighten pedal/lever?
Where did I see a magic little "as seen on TV" type of product that claimed to be a tiny spring that replaced an OEM spring in the shifter mechanism which tightened up the shifter play?
I saw it on a website in the past few days but can't find it again... Does this ring a bell for anyone? Does anyone know what I'm talking about? It was a spring (about an inch long) that claimed to drastically reduce the sloppiness of the OEM shift lever.. (FWIW I'm aware that a loose drive chain will cause a sloppy shift lever feel, and that's not the issue I'm trying to resolve.) Thanks!
Just batshit crazy. All his posts are endless diatribes. Some are actually entertaining but mostly batshit crazy. |
January 29th, 2015, 11:21 PM | #2 |
Dang, lots of internet browsing history searching.... I found what I was looking for.
Does anyone have any experience with this spring? It's effects on shifter feel? http://www.factorypro.com/Prod_Pages/prodk04.html
January 29th, 2015, 11:33 PM | #3 |
step 1: remove shifter star spring cover bolt from the top of the engine case
step 2: place two washers in hole and replace the bolt step 3: profit?
January 29th, 2015, 11:52 PM | #4 |
I got one.
It is stiffer, I have no mis shifts ever. But If I don't shift hard enough it doesn't complete the shift. |
January 30th, 2015, 01:19 AM | #5 |
Now that sounds good to me
January 30th, 2015, 07:40 AM | #6 | |
Fighting Texas Aggie '05
Assuming you press the shift lever with the same force, on a higher rate spring equipped shifter you get less movement at a linear rate, on a preloaded spring you get less/no movement for the initial force application and then stock spring compression rate once past the preload. Interestingly I am not sure one or the other provides you a "better" feel or engagement percentage (or that it matters in an off on situation like the shifter because of short free length and short travel) but they are not exactly the same result.
January 30th, 2015, 11:38 AM | #7 | |
Can anyone sum up exactly what this spring does in simple terms?
January 30th, 2015, 11:40 AM | #8 |
$22.36 seems a little pricey for a spring.
January 30th, 2015, 11:56 AM | #9 |
I'm crazy,your excuse is?
You could pull out spring and stretch it. Maybe a free mod!
January 30th, 2015, 03:53 PM | #10 |
Join Date: May 2014 Motorcycle(s): Ninja 250R & CBR250R Posts: 105
I have one of the Factory Pro springs that I tried and didn't like so I switched back to stock. $12 shipped
January 30th, 2015, 03:56 PM | #12 |
Spring could just be worn out.
And to correctly change a springs rate, is cutting it and shime it to the original length, just like the forks of example.
January 30th, 2015, 04:07 PM | #13 |
To me, it was much stiffer and took a lot more effort to engage the gears. I still use standard shift and I was almost unable to pull the shifter up hard enough to shift up through the gears. It also felt like the throw of the shifter was shortened but that could just be in my mind.
January 30th, 2015, 04:34 PM | #14 |
technically speaking its not possible for the throw to change just by the spring. but stiffer spring would definitely make stiffer pedal
January 30th, 2015, 04:43 PM | #15 |
Sure, and that makes sense. I'm not sure how to describe what I meant, exactly. Maybe the stiffer spring takes some of the play out of the shifter and that's why it feels shorter? Or, like I said, it's just in my head. Haha
bent shifter pedal | reroka | 2008 - 2012 Ninja 250R Tech Talk | 14 | June 11th, 2014 05:59 PM |
WTB: Rubber Grip on Shifter pedal | DmbShn41 | Items Wanted | 0 | September 29th, 2013 04:26 PM |
[2fiddy.com] - Ninja 250R Rearsets, Brake Pedal, Shifter | Ninjette Newsbot | Motorcycling News | 0 | October 7th, 2008 02:08 PM |
