August 11th, 2012, 07:53 PM | #1 |
Repair broken windscreen?
Well I busted up my Zero Gravity Sport Touring windscreen and I was wondering what kind of glue or adhesive I can use to put it back together.
August 11th, 2012, 08:05 PM | #2 |
supposedly you can fuse it back together, but with the complex angle of the cracks the repair might not work.
i would tape the pieces back together and rough out the back of the screen then apply epoxy and fabric to entire back. it won't be clear anymore though. |
August 11th, 2012, 08:10 PM | #3 |
I might have to go with the epoxy route. I abuse my bike pretty bad.
August 11th, 2012, 08:10 PM | #4 |
what happened
August 11th, 2012, 08:15 PM | #5 |
Jigglin' your Jiglets
MOTM - Apr '13
Damn your windshield looks worse than mine from when I totalled my bike!
August 11th, 2012, 08:15 PM | #6 |
Lowsided at the track earlier today. Front tire slid while I was leaned over. Right side mirror bracket hit the ground and squeezed the windscreen causing it to crack and break. I'll have to review the video to see if it shows what exactly happened to cause me to go down.
August 11th, 2012, 08:17 PM | #7 |
Did you have an aftermarket windscreen? the ZG ST windscreen is a whole lot thinner compared to the OE windscreen. I still love the brain tumor of a windscreen the ST is.
August 11th, 2012, 08:50 PM | #8 |
MOTM - Apr '13
Yea it was a double bubble, I just installed my ST one and took it out for a spin, it makes such a difference.
August 11th, 2012, 08:55 PM | #9 |
I know it was a big difference compared to stock. Today was a bad day for me. I misplaced the wellnuts and the two washers to mount my right side mirror at the track. They're prolly sitting there on the track parking lot....... I need to leave them in a baggy next time.
August 11th, 2012, 09:22 PM | #10 |
Not sure if you can glue it but this is pretty cool.
August 11th, 2012, 09:29 PM | #11 |
I've actually seen that done firsthand at the track.
August 11th, 2012, 11:17 PM | #12 |
I told you bro
Join Date: Jun 2012 Motorcycle(s): 1996 Ninja 250r Posts: 680
You might find a strong glue if you go into your local hobby store or a hobby town store and look for a really high strength model glue. I'm not sure if you could find stronger online or at home depot, but they make some crazy strong stuff for model vehicles. They usually don't eat into the plastic like super glue and dry clear.
August 12th, 2012, 10:05 AM | #13 | |
August 12th, 2012, 07:41 PM | #14 |
Found what I needed. Went around to all the hardware stores and finally stopped at a fish store where I found some acrylic solvent called Weld-On. They had a tube of Weld-On 16 which is a gel type but I opted for the liquid in a can form (Weld-On 4) since it sets faster. I didn't have a needle applicator bottle so I used a needle syringe. Stuff is a whole lot better than Epoxy and is specifically designed for stuff like this!
Working time is 1-2 min, fix time is 3 min, and 80% strength is 24-36 hrs. Bond will gradually strengthen over time! To use this, you'll need a needle applicator bottle so you don't drip this stuff everywhere. With you the bottle you'll have fine control of the solvent and placement. . Make sure the windscreen is cleaned of oil and marks. If the solvent drips and touches the oil or mark, it'll stain the windscreen. Also avoid using tape to hold the pieces together, the solvent will get onto it and melt the tapes adhesive and bond it to the screen. You can probably remove it afterwards with acetone probably. Align two pieces together and apply a slow steady flow of the solvent down the crack till it fills it all. Apply gentle pressure to help the solvent soften the edges of the crack and then press together for it to bond firmly. This stuff is not a glue but more of a solvent that "welds" the plastic together. Works with plastics of butyrate, polycarbonate, and styrene according to the can. If the solvent spills, DO NOT WIPE IT! WIPING IT WILL MAR THE PLASTIC SURFACE. Just let the solvent evaporate. I botched the alignment since it was kind difficult to line up the curved surfaces so it has a lip at the crack in some places. Used tape which wasn't a good idea nor not cleaning the windscreen prior to application. Origination of break:
August 12th, 2012, 08:36 PM | #15 |
Join Date: Aug 2012 Motorcycle(s): 1992 Ninja 250, 1987 Yamaha FZ700TC Posts: 13
Glue from an aquarium store... brilliant! I've got a shattered windscreen on my Yamaha, and since there is nothing to lose by trying, I'm going to try this method on it. Thanks for the idea.
Scott |
August 12th, 2012, 08:43 PM | #16 |
Big fish/Aquarium stores should stock it for fixing and building acrylic tanks. You can probably find this stuff at your local plastic stores and large glass companies. Lowes and Home Depot will not have it. An old Ace hardware may have it. So far the bond feels really strong.
Need Repair Advice | SJK | 2008 - 2012 Ninja 250R Tech Talk | 16 | May 17th, 2014 02:09 PM |
[topix.net] - Joe's Scooter Repair: Not limited to just scooters, they also repair AT | Ninjette Newsbot | Motorcycling News | 0 | August 12th, 2012 08:30 PM |
[roadracingworld.com] - Beaubier Had Surgery Wednesday To Repair A Broken Knee Cap | Ninjette Newsbot | Motorcycling News | 0 | March 29th, 2012 11:10 AM |
[roadracingworld.com] - Beaubier Had Surgery Wednesday To Repair A Broken Knee Cap | Ninjette Newsbot | Motorcycling News | 0 | March 29th, 2012 09:40 AM |
[roadracingworld.com] - Dovizioso Has Surgery To Repair Broken Collarbone | Ninjette Newsbot | Motorcycling News | 0 | January 9th, 2012 10:30 AM |
