September 13th, 2012, 03:13 PM | #1 |
Jigglin' your Jiglets
MOTM - Apr '13
Jetting, Dyno Tuning, AFRs??? Help A Jiglet Out
Alright, so I went down for another dyno run today to see where I'm at. I was running dynojet 108 mains, dynojet needles on the third clip, and idle screws about 3 turns out. So we got on the dyno and got some weirdness, some super duper lean weirdness. We couldn't figure it out but I suggested maybe the afr meter wasn't far enough in the exhaust. The guy thought it was worth a shot and spent 20 minutes modifying his little tool to go further down the exhaust and this is what we got
Configuration Area P Race Exhaust K&N 0990 Pod Filters Main: Dynojet 108 Needle: 4th Position Clip Idle Screws: 3 Turns Much better! So as you can see I'm way to lean in most parts and a little rich in some parts. Before we took this dyno the guy changed the clip position to #4 on the needle (didn't even charge me ) so at this point I'm one position away from the richest clip position. He also gave me some Keihn 115's which is the next size up main jet, he recommends I put those in and put the clip to the 5th position. In addition to the free jets he said the next dyno run would be free as well So what do you guys think? Obviously my midrange is super lean and the powerband has the AFR dip too low and then rise too high. What's the next step?
September 13th, 2012, 03:29 PM | #3 | |
MOTM - Apr '13
I can only raise the needle 1 more clip, so raise it by one and put 2 washers under? 2 sizes bigger on the main????? Ugh I'll go order some
September 13th, 2012, 04:38 PM | #4 |
Then turn the idle mix screws in. 3 turns out is pretty far. Try a quarter turn
September 13th, 2012, 04:39 PM | #5 |
MOTM - Apr '13
Is that the slow jet from the site you told me about?
September 13th, 2012, 04:41 PM | #6 |
Yes. The pilot jet is the slow jet.
You have the stock pilot jet in there now right? Just turn the mix screws in. |
September 13th, 2012, 04:48 PM | #7 |
MOTM - Apr '13
Why would I turn the screws in?
September 13th, 2012, 04:55 PM | #9 |
It's rich at the bottom. The mix screws control fuel. Further out = more fuel for the same amount of air. Further in = less fuel for the same amount of air.
Turn them in to lean the mixture a little bit. alex said to go down a pilot jet, but if it's got the stock pilot and the mix screw is out at 3 turns, it doesn't make sense when you can just put the mix screw back in a little bit. |
September 13th, 2012, 04:58 PM | #10 |
you know looking back at the chart it looks like the needle is over correcting. set mix screws to stock and just go up two on the main jet and by then you should be able to lower the needle back to the center clip.
September 13th, 2012, 04:58 PM | #11 |
@Jiggles, is it the stock pilot or not???
he said he's out at 3 turns. 2.5 is the stock setting. So he has to undo what he did before we decide if it needs a smaller pilot or not. SOMEONE still hasn't said if he changed out the pilot or not. If it's the stock pilot, there's no need to go down a size. Just turn the mix screw in to where it should be. If anything, he would need a larger pilot when switching to a pod filter, assuming he didn't change the mix screws. Right? |
September 13th, 2012, 05:01 PM | #12 |
pod filters make less stable air. less air is able to flow at low flow rates which means when its at a low flow rate, the turbulence will be very high and so it makes stock pilots too rich. its what people blame on a "lack of vacuum" (an odd thought which requires a lack of understand of how an engine works) or blame it on "lack of engine intake back pressure" or "intake resistance" because of the airbox instead of realizing that they were just lazy and didnt adjust the pilot system. this is usually why people claim pod filters make bikes "gutless" at low rpm. backpressure like people talk about there is useful for creating a negative pressure between exhaust strokes to aid pulling out the exhaust gas, but it doesnt work like that for the intake until you get into ram air
September 13th, 2012, 05:02 PM | #13 |
MOTM - Apr '13
Yea its a stock pilot jet. Those mixture screws were pissing me off so what I eventually ended up doing was turning them all the way in then following alexs directions on turning them out and I ended up at 3 turns. So I should turn them in how far?
September 13th, 2012, 05:05 PM | #15 |
MOTM - Apr '13
So by turning them in that should fix up the bottom poopy part but it will make then entire range slightly more lean correct? So I should still pull the needle out more right?
September 13th, 2012, 05:06 PM | #16 |
OHHH that makes sense alex thanks! So then would long runners on the intake help? that would help get air all going one direction. I know my efi kit has some pretty good runners between the K&N and the TB's, and it seems just fine down low.
Or velocity stacks? Could I get more low end by going back to the airbox? |
September 13th, 2012, 05:06 PM | #17 | ||
September 13th, 2012, 05:07 PM | #18 | |
MOTM - Apr '13
this
September 13th, 2012, 05:09 PM | #19 |
MOTM - Apr '13
Welp, were shooting for as close as possible before I go back to the dyno. Then we are going to dyno tune it
September 13th, 2012, 05:17 PM | #20 | |
September 13th, 2012, 06:01 PM | #21 |
MOTM - Sep '18, Feb '16
What number pilots are you running? I used #48. Are you running a modified ignition box? Like the BRT? I used 117 jets with timing advanced.
The clip position will change the relationship between the needle and the jet . If you go with a larger jet you will want to move the needle back down a little. Or it will be rich over the whole power band. Turn the idle crews out 2.5 turs . And go one richer with the pilot and the 115. Then retest It looks like you are rich at idle then lean through the pilot. At 7500 your power flattens out . This is normal and can be corrected with adding a couple deg of timing in that area. Why is the torque curve so flat?
September 13th, 2012, 06:06 PM | #22 | |
MOTM - Apr '13
Torque curve is just smooshed down to make room for the AFR
September 13th, 2012, 06:21 PM | #23 |
Join Date: Jan 2011 Motorcycle(s): 2012 Black & Yellow Ninja 250 Posts: 70
I don't mean to threadjack, but when this is all said and done is it possible to organize the 3 or 4 threads covering the creation of "Jiggle's Jiglet"? (and maybe give it a more family friendly title).
I've learned a lot following Jiggles on his merry adventures and I'm seriously considering this route myself. All the forum research I've done so far has left me confused. There are opposing methods championed for how this should be done, and having those different ideas hashed out in the open, and explained in simple English like this has been extremely helpful. Last futzed with by Ninja Chris; September 13th, 2012 at 06:26 PM. Reason: grammatic fluxuations |
September 13th, 2012, 06:39 PM | #24 |
Join Date: Jun 2012 Motorcycle(s): 2010 Ninja 250 Posts: 212
lol Jiggles should put up a DIY of how to install all this crap.... I should then go with similar mods and use his settings since i cant afford to have my **** dynoed
September 13th, 2012, 07:35 PM | #25 | ||
MOTM - Apr '13
There is a very jiggly 250 which was my build thread, then there was help ive no clue wtf needles do, and now there is fine tuning the jetting. If you want to find all these threads just click my name then go to view profile > statistics > all threads started by jiggles. A few hours sorting through that and you can find these threads Quote:
http://www.ninjette.org/forums/showthread.php?t=114107
September 13th, 2012, 08:19 PM | #26 |
MOTM - Apr '13
Question for my ecotrons homies @choneofakind @EMSRacer07 @lgk
I'm considering getting an AFR gauge (wideband O2) installed onto the midpipe of my exhaust in order to give me at home AFR numbers so its easier to tune. I do want to switch to ecotrons eventually, like next summer maybe. So if I did get the ecotrons kit with the narrow band sensors on both pipes and the AFR gauge on the midpipe would that make tuning rich mode a hell of a lot easier? (lol @ 3 O2 bungs on a ninja 250) Matt also has an option to do wideband sensors though it is an additional $278 to do 1 wide band O2 and I'll have already spent about $150 on the AFR gauge. So question is, do you think it would be worth that extra $278 to do the wideband route with ecotrons and have the kit tune itself (though each injector would not be receiving its own data but an averaged feedback of both) or do you think it would better to save that extra money, install the narrowbands in both pipes as well as the AFR gauge and tune rich mode myself?
September 13th, 2012, 08:29 PM | #27 | |
I think you're documenting your journey so well it is sticky or wiki worthy. |
September 13th, 2012, 08:34 PM | #28 |
Sean, I'm really not sure. Judging by my bike, running 3 oxygen sensors might be pushing it a bit power-wise
You'd likely have to talk to Matt ahead of time. You'll prolly need some custom software, where each injector supplies the same amount of fuel, based on the reading from one sensor, rather than each injector being influenced by the readings off of in individual sensor. But if you can get it to work, tuning would be a breeze: just tell it what your desired lambda table! I need some dyno time to figure out how mine is doing in rich mode. I think my rich map is more rich than it needs to be from about 12k up |
September 13th, 2012, 08:36 PM | #29 |
MOTM - Apr '13
My intent is for every DIY to be accompanied by a Jiggly Vid
September 13th, 2012, 08:42 PM | #30 | |
MOTM - Apr '13
I'll simplify it lol If you had a AFR gauge along with your current kit would you find it rather easy to tune rich mode? And would you rather tune rich mode like that or for $278 more allow rich mode to self tune (though possibly at the cost of "averaged" data between each injector)? And I don't think the O2 sensors would really block too much exhaust do you? 1 in each header and 1 in the midpipe? I could always remove and plug the midpipe one if I needed to right?
September 13th, 2012, 08:47 PM | #31 |
yeah it would be easy. But I wouldn't be able to reliably power that many sensors. I have a tiny battery.
You'd still need to leave it in learning mode for a while so it got an idea of what your system needed. Then pull the NB O2 sensors and put the WB O2 sensor in your mid pipe and double check everything in rich mode. Then leave it in rich mode. That better? The wideband would be good for double checking |
September 13th, 2012, 08:58 PM | #32 |
MOTM - Apr '13
Ah, so you wouldn't leave all three in eh? Ok, I think Ill go the standard ecotrons route with an AFR gauge. Sounds fun But for now I'll get the AFR gauge for the carbs
September 13th, 2012, 09:16 PM | #33 |
Join Date: Aug 2010 Motorcycle(s): Bike-less, Can I ride yours? Posts: 318
Hey Jiggles...
Ninja 300 + PC + Area P
RR stands for Responsible Riding... Right? |
September 13th, 2012, 09:29 PM | #34 |
MOTM - Apr '13
That sounds kinda gay, how about bored out 250 + ecotrons + area p
September 13th, 2012, 09:33 PM | #35 | |
Although, I kinda like keeping mods to a minimum. It seems as if whenever you mod something, the fit & finish is never the same quality as oem. Just curious, where do you go to school for engineering?
September 13th, 2012, 09:40 PM | #36 |
MOTM - Apr '13
San Jose State. How do you know I'm an engineer? lol
Its not like I'd be swapping out a new motor or anything and with the airbox gone there is plenty of space for EFI Also my ninja cost $4000 + $700 (AP + jets) + $100 (Air filter, other odds and ends) so $4800. Yours will cost lets say $5500 OTD + $600 (AP) + $300 (PC) +$100 (Air filters, odds and ends) so $6500. Yep more expensive lol. Don't know what a big bore kit would cost or if I even want to do it, probably a few hundred though
September 13th, 2012, 09:48 PM | #37 | |
But you have to consider, a fully modded 250(not bored out) will have ~32 hp. The ninja 300, although we don't know for sure what the WHP will be, will probably be around ~32 hp also. Plus here in WA we don't have as awful dealer fees. I got my 2010 SE(in 2011) just $100 more OTD than the msrp Regardless, I guess there is some joy in working on your own bike so there is that.
September 13th, 2012, 09:51 PM | #38 |
MOTM - Apr '13
I don't like the way the 300 looks anyway
And if the engine is easily swappable then maybe I'll do that!
September 14th, 2012, 05:59 AM | #39 |
i'm not sure how matt wires his wideband unit.
if the ecu can actually read/log the data from the wideband it definitely worth it. i went with the innovate mtx and i have a spare lc-1 in case i need narrowband emulator function. right now i took the guage/sensor off and plugged it off since someone thought it would be cool to try and steal the guage... the power usage is the most at startup when the heater is on. if you plan on a lot of stop and go driving i would tune and then remove it. as far as placement i copied greg737's setup.
September 14th, 2012, 07:39 AM | #40 |
Join Date: Nov 2011 Motorcycle(s): 2007 Ninja 250 (sold), '06 Ninja 650R Posts: 455
One thing that you have to remember @Jiggles is that the dyno run is at full throttle. So what you are seeing on the graph is the overall performance of the main jet.
Yes it is lean in the mid range, but looks pretty good from 7000 to redline. This is more a function of airfilter and carburator geometry. You could probably go up one main jet size to bring the whole graph down. Then go a little leaner on the needle clip position. Ideal stoichiometric AFR for gasoline is 14.7. Ideal for power is what the tuners have put on your graph. As far as the rest of the throttle response, you are going to have to go by feel. |
Dynamometer / Tuning / Jetting / Performance / Cost Question | dcj13 | General Motorcycling Discussion | 2 | December 20th, 2014 05:22 PM |
Dyno-tuning Results Two Brothers Exhaust | tubarney | 2008 - 2012 Ninja 250R Tech Talk | 11 | June 21st, 2012 07:23 PM |
Dyno Charts with jetting and stock exhaust? | KURT | 2008 - 2012 Ninja 250R Tech Talk | 5 | February 27th, 2011 10:03 AM |
08 250R Dyno / after full exhaust + jetting | Order | Videos | 20 | January 19th, 2011 11:12 PM |
Dyno (re)Tuning Mods (with problems) vs Stock - Video and Graphs | TheDuck | 2008 - 2012 Ninja 250R Tech Talk | 5 | May 9th, 2010 02:27 PM |
