July 9th, 2014, 05:46 PM | #1 |
Join Date: Jul 2014 Motorcycle(s): 1996 ninja 250 Posts: 49
Steel gas tank repair
I have a crack in my gas tank which someone already tried to fix with cheap flex seal... Was thinking of brazing it shut but everyone says it won't work any tips?
July 9th, 2014, 05:52 PM | #2 |
The crack is from tip to tip of the tools and is about 1mm wide
July 9th, 2014, 05:54 PM | #3 |
the problem is that the inside will continue to rust and will start clogging up the fuel filter / carb jets
July 9th, 2014, 06:09 PM | #4 |
It's not rusted out the bikes been dropped on that side and the bolts sticking out now and not flush like the other side. but I could use a inner tank coater to deal the inside once it's shut but want to know if it'll braze because on a bunch of other sites they say you can't
July 9th, 2014, 07:11 PM | #5 | |
Please, please, do not attempt doing it yourself; a good shop should know how to do it safely: I have seen it done many times, .... and I have known of some explosions as well. If you must do it yourself, do not use a live flame, use a solder iron and soft solder, after cleaning the surface and inside the crack (and inside the tank if possible) absolutely well.
July 9th, 2014, 07:58 PM | #6 |
I would clean the tank out with compressed air removing any remaining vapours and while doing any heating I would have a line bleeding nitrogen into the tank so ignition won't be possible
July 9th, 2014, 08:07 PM | #7 |
I'm crazy,your excuse is?
Sounds like a plan.
July 9th, 2014, 08:31 PM | #8 |
Join Date: Feb 2014 Motorcycle(s): Rebel 250s, Ninja 250s VN750s (currently nine total) Posts: 465
When you get ready to seal the inside of the tank, this is the stuff to use. Infinitely better than Kreem, Red Kote, etc. If I were you, I'd drill two small holes at the end of the crack to prevent any further cracking, tape over the crack, and then just use the Caswell. It strengthens the tank as well as sealing it. http://www.caswellplating.com/restor...nk-sealer.html
July 9th, 2014, 08:40 PM | #9 | |
Although the most of air is nitrogen, pure N2 (28.0 g/mol) is lighter that air; hence, you will have O2 trying to sneak into the cavity.
July 9th, 2014, 08:58 PM | #10 |
Join Date: May 2013 Motorcycle(s): honda crf230l & 2013 ninja 300se wife has Honda crf230l & honda cbr250r repsol Posts: 222
I would look for a used tank in good condition.
Gas Tank Lock stuck? Maintenance for gas cap with pics! | Skippii | 1986 - 2007 Ninja 250R Tech Talk | 35 | May 6th, 2021 09:03 PM |
04 Tank repair/replacement | ansabolic | 1986 - 2007 Ninja 250R Tech Talk | 33 | August 14th, 2012 03:16 AM |
How to repair/seal a rusted gas tank | g21-30 | General Motorcycling Discussion | 6 | January 8th, 2009 12:51 AM |
