September 26th, 2013, 11:53 PM | #1 |
n00b with the b00bs
Join Date: Jan 2013 Motorcycle(s): 2007 EX250, 2008 EX250, 2001 ZR-7S, 2010 ZX-6R Posts: 470
2007 won't idle. Vacuum leak or something else?
Hey everybody!
I went to start my pre-gen ninja 250 and it won't idle. It has only been sitting about 3 weeks so I don't think it's clogged carbs. I can start it with the choke on. When it warms up and I start to reduce the amount of choke, the idle starts to surge. If I take the choke completely off it dies. If I give it throttle with the choke on it dies. It was running fine when I last rode it. I figured it was a vacuum leak. I sprayed carb cleaner on all of external areas that could be leaking and listened for the idle to even out for a bit. The only time that worked was when I sprayed it in the air cleaner. The air cleaner screen is clean. Since nothing obvious was coming up, I started disassembling. I completely removed the carbs and ended up cleaning/rebuilding them. But as I suspected, they were spotless. All of the hoses seemed ok. I re-assembled everything and put it all back together. No surprise, the issue is still there. Here's a video of how it's running. I would appreciate any recommendations for root cause and next steps. I was hoping to take it to a track day on Saturday. http://youtu.be/4syU_BwHyFU |
September 27th, 2013, 05:35 AM | #2 |
Join Date: May 2013 Motorcycle(s): '89 klr 650, '00 250r Posts: 177
If nothings changed since the last time you rode it and it was running fine then, I wouldd suspect the carbs. One quick thing qyou could do would be drain the carbs and then try and run it. Some fresher gas may help but who knows. Or keep running it with the choke on and play with the throttle and hope something clears up.
September 27th, 2013, 05:37 AM | #3 |
Those high rpms' can hurt a cold engine !!!
Continuous start ups don't solve a problem but create a new one: dead battery. It seems that you have missed some little passages that belong to the idle circuit. After sitting for a month, a friend had the same exact problem and called me. I always believed that clogs produced by gasoline upon evaporation can be dissolved by gasoline plus heat. So, using only choke, I made the idle stable at around 2K rpm and gently started moving the bike and took it to the freeway for a spirited ride (kept choke open all the way). Ten miles later, and every time he started it later in that week, the bike was idling as new.
September 27th, 2013, 06:57 AM | #4 |
I'd drain the fuel and refill with fresh before going much further.
Condensation can form quickly if the temps are changing and the tank is low. Always start your troubleshooting with known good fuel. It one of the easiest problems to fix and nothing else will make it run right if the fuel is bad. Use 87 without Ethanol if you can. |
September 27th, 2013, 07:27 AM | #5 |
I'm crazy,your excuse is?
Make sure your battery is fully charged also.
September 27th, 2013, 09:50 AM | #6 |
n00b with the b00bs
Yeah, the battery is starting to get weak
After I pulled/cleaned/re-adjusted the carbs last night, I'm positive the "let it warm up and ride it" isn't an option. I've employed that a lot in the last 12 years and currently this is behaving differently. There's something else going on. My theory is that it's running rich. After it warms up a little, if I give it throttle it kills it (too much fuel). If I lower the choke more than half way, it kills it (not getting enough air). I can't get it to idle consistently. If there's a vacuum leak, and it's running rich, then that makes sense... No it doesn't. 'Cause a vacuum leak would allow it to run without the choke because it would be adding air. So there's too much air and it's running lean. Having it die when adding throttle means too much fuel and running rich? Which then points to a clogged air passage somewhere... And the surging is the diaphragms adjusting to the vacuum needs... &*^#$*(@#^$@*!!!! |
September 27th, 2013, 10:04 AM | #7 | |
Yes, you could roll away with the choke fully open and opening the throttle very little.
September 27th, 2013, 10:15 AM | #8 |
the answer is obvious.
you suck at cleaning carbs! open them up again. remove each jet. spray carb cleaner in the jet, then twist a tooth pick through the jet. soak the jet in carb cleaner then scrape the inside with another tooth pick. dont use metal it will scratch things up. spray carb cleaner through the internal passages in the carbs and if you can, soak them or even use one of those fancy ultrasonic cleaners. i've known many people to "clean their carbs spotless" and yet still have issues until i go and pull crap out of their jets... "but it was clean!"... not clean enough i guess. maybe dirty fuel filter is fouling it up again... dirty gas tank? rusty gas tank? **** in the petcock floating down stream? you have replaced the gas in it right? there could be lots of different reasons its getting dirty again or remaining dirty... but what you describe is a clogged main jet.
September 27th, 2013, 10:35 AM | #9 |
n00b with the b00bs
September 27th, 2013, 10:43 AM | #10 | |
I'd first replace the fuel, drain the float bowls, then start it and keep it running for a few minutes, then adjust the idle speed screw to see if it will idle without the choke. If it idles poorly, make some adjustments to the idle mixture screws (turn them out most likely). If it won't idle by doing those things I would say the pilot jets should be removed and carefully cleaned. |
September 27th, 2013, 11:22 AM | #11 |
Join Date: Oct 2010 Motorcycle(s): '02 Ninja 250, '98 Triumph Sprint 900, '69 H-D Sportster XLCH 900 Posts: 80
Alex is right. You're not cleaning the carbs correctly. If you follow the instructions for carb cleaning and proper set-up, meaning correct float height and sync, that are on the "How-To" page of that other Ninja 250 web site your problems will go away.
j98sprint |
September 27th, 2013, 12:01 PM | #12 | |
n00b with the b00bs
I totally get and have used the theory you are speaking of - the get it rolling with the choke on, ride it with load and higher RPM, get it good and warm and it clears itself up. Something is too effed up in the fuel system to allow it to move under load, even when it's revving above 5K with the choke fully on. I am going to try to replace the gas in the tank. That was a good call. I've got some happy Nevada gas that doesn't have all the California emissions/ethanol junk in it. Except right now all of my gas tanks are full. D'oh! |
September 27th, 2013, 01:36 PM | #13 | |
87 without Ethanol is always the best, but not everyone can get it unfortunately. |
September 27th, 2013, 01:37 PM | #14 | |
n00b with the b00bs
By "idle mixture screws" - I'm pulling from my memory - are you referring to the external screw you adjust when you sync the carbs, or the pilot jet screws under the bottom of the carbs? Thanks. |
September 27th, 2013, 04:16 PM | #15 | |
Secret Passages Yes, those are the screws that have been mentioned above. Actually, they need to be removed for a proper cleaning of the idle or pilot circuits (be gentle with their O-rings). You don't really need to replace the tank, cleaning it up from debris and some water and adding a good in-line filter will suffice, IMHO. A decent flow of clean air and gasoline is all the carbs ask for.
September 28th, 2013, 01:27 AM | #16 |
n00b with the b00bs
Found the culprit! The o-ring in the idle circuit is in multiple pieces...
September 28th, 2013, 01:35 AM | #17 |
n00b with the b00bs
So, yeah, after work I filled a small spare tank with fresh gas and hooked it in to the carbs and it still ran poorly with the surge. So I loaded it up with all of my track stuff, threw the fairing in the back seat, swung by auto zone for 2 cans of carb cleaner, seafoam, hose clamps, and new vacuum hose. I headed up to Willow Springs and tore the damn thing all apart again. Luckily one of the trackxperience guys had an o-ring kit. He's purring like a kitten, now!
September 28th, 2013, 07:50 AM | #18 |
September 28th, 2013, 10:47 AM | #19 |
Join Date: Sep 2013 Motorcycle(s): 2006 Ninja 250, 2004 Buell XB12s, Honda 110 Elite Posts: 332
Choke
I can't help myself. The "choke" isn't a choke. It is an enrichening device. It does not function at all except at idle r very small throttle openings.
September 28th, 2013, 08:14 PM | #20 |
September 28th, 2013, 08:24 PM | #21 | |
Note that not every idle mixture system operates the same - some are air-bleeds that are opposite (IN is RICHER), so you need to know which system your carbs use. The screws used for syncing the carbs are on the top, and alter the relationship between the carbs. |
September 29th, 2013, 08:59 PM | #22 | |
n00b with the b00bs
September 30th, 2013, 05:30 AM | #23 |
In the photo of the bad o-ring on the mix screw, where's the washer? There should be a little washer between the spring and o-ring or else the new one will grind down and look just like the old one.
Oh, and there are 6 jets you need to clean when you clean a set of Ninja carbs. Each carb has a choke jet, pilot jet and main jet. The choke jet is often overlooked and AFAIK is not removable. So you just have to use a thin wire or blast it with air or carb cleaner. The main and pilot jets must be removed in order to properly clean them.
September 30th, 2013, 09:28 AM | #24 | |
n00b with the b00bs
#1stworldproblems |
2005 ninja 250 vacuum leak/clog? | fuel664 | 1986 - 2007 Ninja 250R Tech Talk | 31 | July 29th, 2015 06:53 PM |
Vacuum leak maybe? | iflylow | 1986 - 2007 Ninja 250R Tech Talk | 4 | February 24th, 2014 01:47 PM |
Vacuum hose cross caused leak | Quick1 | 1986 - 2007 Ninja 250R Tech Talk | 9 | December 23rd, 2013 03:19 PM |
Won't "run right", won't idle, choke only, etc?? - SOLUTION HERE | Jiggyfly | 2008 - 2012 Ninja 250R Tech Talk | 5 | May 16th, 2012 09:50 AM |
Whats going on? - (won't idle without throttle) | dlebe250 | 1986 - 2007 Ninja 250R Tech Talk | 9 | January 19th, 2011 11:16 AM |
