Old March 14th, 2015, 03:26 PM   #1
agentbad
agentbad's Avatar
What do you guys clean your pod filters with?
Doing some carb work today and was wondering is there anything special I should use to clean my K&N pod filters with. The pod on my crankcase breather is especially dirty at the moment. I usually just use a tub of mild dishwasher soup and water. I know K&N makes there own cleaner but do you really need that?
Old March 14th, 2015, 04:08 PM   #2
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
run water inside to outside and air dry overnight.
TEAM ALFALFA
www.apexassassins.com
Old March 14th, 2015, 05:05 PM   #3
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
i use the no toil filter oil for my pod so i use the no toil cleaner, i use kerosene for foam dirtbike filters
Old March 14th, 2015, 05:56 PM   #4
Ghostt
Ghostt's Avatar
I personally use a mix of water and Dawn to clean my K&Ns .
BTW I thought we covered the whole pod filters are bad thing for the carburetors?
violente et ignorantia
ZX-2R BLOG
Old March 15th, 2015, 10:21 AM   #5
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
^ but mom... all the cool kids are doing it
Old March 15th, 2015, 10:42 AM   #6
rollo19
Motorcycle(s): 09 Ninja 250R, 98 RS150R
K&N Cleaner let dry overnight, then apply K&N oil.
rollo19 is offline   Reply With Quote
Old March 15th, 2015, 12:22 PM   #7
TBC
TBC's Avatar
Motorcycle(s): 2004 Ninja 250F
Why is that?
TBC is offline   Reply With Quote
Old March 15th, 2015, 03:05 PM   #8
Ghostt
Ghostt's Avatar
Originally Posted by TBC View Post
Why is that?
Okay you asked for it, so here's my 2¢ write-up on the subject,
I would highly recommend that you DO NOT REMOVE THE AIR BOX, the carburetors on the bike are CV type and need to box to function properly, buy a K&N that fits the OEM airbox(K&N KA-2508 Kawasaki High Performance Replacement Air Filter by K&N* *Amazon.com: K&N KA-2508 Kawasaki High Performance Replacement Air Filter: Automotive* ) that's the short version.
Long boring but important answer, CV carbs stands for "constant velocity". The function of the carbs is dependent on having a calm reservoir (airbox) from which to intake air at said constant velocity. Pods draw from the turbulent, unpredictable air swirling past them as you ride, which is anything but constant. Other carbs work fine with pods. CV's = no bueno, save yourself the headaches.
Now onto jetting, first you need to tune the idle mixture screws first, I recommend 3 full turns out from bottom as a good starting point, then fine tune them afterwards. As far as buying a jet kit, I personally don't have one on either my 250, or 500 ninjas. I did got up one size on my main jets, due to they are lean from the factory, and shimmed the main needles with a small washer.
Let just take a minute to think about Kawasaki invested so much time, materials, and money into the airbox?
Do you think for one minute if they could get away with a simple pod filters they would have done that already.
ZX-2R BLOG
Old March 15th, 2015, 04:12 PM   #9
TBC
TBC's Avatar
What's the result of providing the carb with turbulent air? Is it just inconsistency in the tune?
Not trying to give you a hard time - just curious.
Old March 15th, 2015, 04:25 PM   #10
gantt
gantt's Avatar
Motorcycle(s): 2019 Ninja 400, Sold 2012 Ninja 650, Sold 2009 Ninja 250r, Sold 2007 DRZ400s
The airbox is also designed to quiet down the intake side. Part of the noise and emissions regulations. Its been proven the pods make more peak HP. But to each his own. Not a huge difference in any case. I did away with it for the ease and convenience after removing the airbox.
gantt is offline   Reply With Quote
Old March 15th, 2015, 05:01 PM   #11
BlownWideOpen
BlownWideOpen's Avatar
Motorcycle(s): Stuff
+1. Life is just easier without airboxes. Why can't people just do what they want?
Paint side up, rubber side down!
BlownWideOpen is offline   Reply With Quote
Old March 15th, 2015, 05:41 PM   #12
agentbad
agentbad's Avatar
Now you tell me.
Old March 15th, 2015, 05:47 PM   #13
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
Originally Posted by agentbad View Post
Now you tell me.
Welcome to the darkside!
Maa Kawi designed a wonderful machine, does not mean it could not be made better, or at the very least modified to one's own preference. I just cut the frame on mine, jus cause.
My Cafe Racer Build
My intro post
Old March 15th, 2015, 07:47 PM   #14
Ghostt
Ghostt's Avatar
I'm not arguing that fact the pods don't make more peak HP, although marginal, but for everyday street use, your better sticking with the OEM airbox, better, smoother and more reliable performance.
After all a dyno is a stationary device, so the air flow the carburetors are less prone to air turbulence, as in the real world or riding on the street. Try your dyno run, and then wave a fan around the carburetors to disrupt and cause turbulence.
If your building a track bike, then by all means go pods, after all on the track your running in the upper RPMs, so no worries about street ability.
I'm not say that the bike won't run with the pods, it will. I'm just saying for street use they simply are not worth the aggravation they cause.
Been there, done that, smoked that.
If you truly want to improve the carburetors, then spend the money and time and replace the CV ones, with Flat Side type carburetors, but these also have a downside.
keep in mind that flat sides are great. Around the street, normal driving, not as good as a well tuned CV carb. Flat sides are mostly for race track use.
CV carbs, when working properly, give better low RPM and throttle change performance. Flat sides can bog on large throttle changes. Racing is mostly large throttle conditions, not stop and go traffic....
Fuel economy suffers too with a flat side.
It like asking are racing slicks better then regular street tires?
The answer depends...If you are on the highway in a light rain, racing slicks are awful....
If you are racing, racing slicks are perfect for the job.....
IMHO, and price was no object, replace them with a VM series round slide mikuni and be done with it.
As my famous saying goes,
I'm not your mom and I'm not paying for your parts, so do whatever you want with your own bike.
ZX-2R BLOG
Last futzed with by Ghostt; March 15th, 2015 at 09:38 PM.
Old March 16th, 2015, 10:29 AM   #15
agentbad
agentbad's Avatar
If I were to replace anything it would be swapping the carbs for EFI. I do agree with getting things right on the carbs is a hassle but it's worth it when you hit the highway.
Old March 16th, 2015, 10:33 AM   #16
Ghostt
Ghostt's Avatar
Now your talking, that would be the end game for sure.
ZX-2R BLOG
Pod filters worth it? Lllewis87 1986 - 2007 Ninja 250R Tech Talk 24 May 19th, 2014 07:47 AM
Those with pod filters Dark 2013 - 2017 Ninja 300 Tech Talk 9 July 26th, 2013 08:03 PM
just installed pod filters lolibater General Motorcycling Discussion 42 January 19th, 2013 11:00 PM
chrome pod filters snowsoldier 2008 - 2012 Ninja 250R Tech Talk 2 May 16th, 2011 09:21 PM
Pod Filters coolbreeze 1986 - 2007 Ninja 250R Tech Talk 4 February 28th, 2011 07:28 PM
