Old May 21st, 2014, 04:00 PM   #1
agentbad
agentbad's Avatar
Drive Lash and the Cush drive
I have been getting a fair bit of drive lash lately and was wondering if getting a new cush drive would smooth things out. I mentioned it to my mechanic when I got it inspected a few weeks ago and said my cush drive needed to be replaced and tried to sell me a new chain as well. So as soon as I got home I adjusted the chain to spec, realigned the back wheel, and cleaned/lubed everything. The chain was just a little out of spec and after tightening things up most of the drive lash is gone however I still feel it a little bit in the back wheel. Should I get a new cush drive or just do the mod and shim the thing?
Old May 21st, 2014, 04:05 PM   #2
Trailerboy531
Gear crash test dummy
Trailerboy531's Avatar
Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r
When you say drive lash...
CVMA #531
Trailerboy531 is offline   Reply With Quote
Old May 21st, 2014, 04:09 PM   #3
agentbad
agentbad's Avatar
Jerkiness when cracking open the throttling or releasing it. I do a lot of engine braking so I probably notice it more then but I hardly notice at speed.
¯\_( ツ)_/¯
Old May 21st, 2014, 04:10 PM   #4
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Originally Posted by agentbad View Post
...Should I get a new cush drive or just do the mod and shim the thing?
I replaced my cush drive and found the new one was almost as loose as the old one. I ended up putting in a bunch of shims anyway.
If I were you with what I now know, I'd just put in the shims and keep the old cush.
Old May 21st, 2014, 04:15 PM   #5
agentbad
agentbad's Avatar
I've read that elsewhere too so I guess I'll just shim it and go from there. What did you use for shims I've seen plastic from a milk jug and pieces of tile flooring.
Old May 21st, 2014, 04:23 PM   #6
dcj13
Participant
dcj13's Avatar
I used an old one-quart oil container (or two). Dang near anything will work.
Old May 21st, 2014, 07:57 PM   #7
http://faq.ninja250.org/wiki/How_to_shim_the_cush_drive
Old May 21st, 2014, 11:01 PM   #8
Singh2jz
Singh2jz's Avatar
Motorcycle(s): '07 ex250-F/J
Originally Posted by Motofool View Post
You beat me too it!
The Bike | The Truck
Old May 22nd, 2014, 04:52 AM   #9
agentbad
agentbad's Avatar
Have you guys done the mod? Does it make a difference?
Old May 22nd, 2014, 04:59 AM   #10
I have done it before. On some bikes it made a small difference, others not so much. It was more about the carbs and getting them to react well to the initial shot of gas to not lurch the bike forward.
Shimming is pretty easy and completely reversible if you don't like it. Start there, if that don't work, time to look at the carbs/airbox. Specifically check the sync of the carbs.
Old May 22nd, 2014, 05:36 AM   #11
mgentz
Board Member
This thread is very informative.
Old November 10th, 2014, 04:49 PM   #12
Me3
Motorcycle(s): GPX250
Sorry to thread mine, but I was interested in this line specifically:
Can you elaborate on this at all, beyond the carb sync? I have had the idle mixtures all the way lean and rich, with rich smoothing the transition somewhat but not fixing the issue entirely.
I have no binding/sticking in any mechanical part, and have even raised the idle to 2000 to try and pull the carbs off the idle circuit to see if this helps, but still get quite a surge when opening the throttle. Engine runs fine everywhere but the initial roll on.
Me3 is offline   Reply With Quote
Old November 10th, 2014, 05:52 PM   #13
Ninjinsky
Ninjinsky's Avatar
I had a an annual inspection fail on cush drive (UK) and replaced it. Don't know if it is a legal issue in the US but it fails roadworthiness here.
Guess I could have shimmed it, they would never know
Old November 10th, 2014, 05:55 PM   #14
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
Do you drane the oil first?
Old November 11th, 2014, 07:51 AM   #15
baxtc1
baxtc1's Avatar
Motorcycle(s): '92 GPX 250 (Gone and replaced with '08 V-Strom), 2005 Suzuki C50.
Drive lash, how is your clutch housing?
Originally Posted by jgcable;
I ride a 2006 Custom HD Wideglide..... and I almost have to sign autographs when I park it.
baxtc1 is offline   Reply With Quote
Old November 11th, 2014, 08:33 AM   #16
Half of the cycles in the U.S. would probably fail that inspection.
Seems a bit over-the-top to worry about play in the cush drive to me. Big Brother is watching you - very closely...
Old November 11th, 2014, 02:45 PM   #17
greenaero
Motorcycle Hypermiler
greenaero's Avatar
Motorcycle(s): 1999 & 2005 Kawasaki Ninja 250R's
As others above have stated : shim it
235 MPG Hypermotorcycling to a better tomorrow
greenaero is offline   Reply With Quote
Old November 11th, 2014, 04:08 PM   #18
Welcome Me3!
In a nutshell;
Throttle cable slack in spec
Clean carbs
Well adjusted mix screws
Carbs in sync
Idle set within spec
Good spark (blue in color)
Clean/clear air filter
Chain tight and within spec looseness
Cush drive inspection, replace or shim per rider needs
Basically, a well tuned/running 250 can go from idle to pinned without much fuss.
Old November 14th, 2014, 12:03 AM   #19
Me3
Welcome Me3!
In a nutshell;
Clean carbs
Carbs in sync
Thnkas for that.
I have checked everything bar the sync and shim the cush drive - the bike has only done 8000ks, so I will look to sync the carbs on the weekend.
Old November 19th, 2014, 01:36 PM   #20
kxpower?
kxpower?'s Avatar
Motorcycle(s): Ugly 89 frankenstien special ex250, and the "Zooks" : 1982 GS450 and 1979 GS1000
Just a shot in the dark that you could try in 20 minutes for a dollar or two I might shim the needles by one washer. If more gas off the pilot helps richening the transition might help too. My 2 cents...
BUUUUUUUUUUUT make damn sure you feel good that everything on Chris's list is good too or you'll be chasing your tail.
Oh god the bikes are multiplying!!!
kxpower? is offline   Reply With Quote
Old November 19th, 2014, 01:55 PM   #21
we mostly don't have any kind of annual inspection on motorcycles here. the only exception is if it has been salvaged and you are registering it again... you have to have a brake and lights inspection and they also check the vin to make sure its not stolen.
Cush Drive Questions tbeck3r 2008 - 2012 Ninja 250R Tech Talk 12 March 18th, 2015 09:45 PM
Cush Drive Shim PsHYk 2008 - 2012 Ninja 250R Tech Talk 24 June 30th, 2012 12:51 PM
WTB: 08+ Sprocket Carrier and Cush Drive SNAPPY Items Wanted 0 April 4th, 2012 08:37 PM
Cush Drive Replacement jorgecornet Videos 11 May 26th, 2010 08:27 AM
Technical: Cush Drive on 2008 Ex250R Sailariel 2008 - 2012 Ninja 250R Tech Talk 19 May 25th, 2009 05:24 PM
