May 12th, 2014, 09:39 PM | #1 |
Join Date: May 2014 Motorcycle(s): 2011 Ninja 250 Posts: 17
Shifter Linkage Screw Up
Hey guys,
I was hoping my next post with you all would be one of rainbows and butterflies due to a project completed. However……I need to walk the plank of shame on this one for a stupid rookie mistake. Interested on how stupid my screw up is? Weeeellll here goes….. I was changing the chain and sprockets on my beastly 250. I put the shifter back onto the rod that the front sprocket is on (cam shaft rod?). Everything is fine and dandy, job complete it's all good. I sit on the bike and the shifter is up a little too high for my liking. I went down to take it off and the screw broke off inside the black coupler that goes onto the shaft. Most likely because Boris the Cave Man (me) overtightened the screw. Soooo now I'm looking at a half broken off screw in the dang thing with no real hope of correcting the issue. I have gotten half of what is left in there out, problem is that theres a burr where the screw broke off inside and I'm afraid that it has stripped out the threads inside the coupler. Should also be noted that I have not fully gotten the broken screw out, just half of it…… Having said all that, I'm wondering if ya'll have any advice on what I should do from here…….I'm thinking about buying a new coupler and calling it a day. |
May 12th, 2014, 10:22 PM | #2 |
Join Date: Dec 2013 Motorcycle(s): 2011 250R SE Posts: 326
I've never had much luck with screw extractors but that's an option. You'd probably want to run a tap down through the threads afterwards to clean up any buggered threads.
If you have the extractor and the tap you can give it a go but if not the part might be a similar price to the tools. I'd probably just buy a replacement... |
May 13th, 2014, 01:55 PM | #3 |
Wannabe Reborn
Probably easier to buy the replacement. Extractors work great only when you still the proper hole, on centered.
May 13th, 2014, 02:40 PM | #4 |
I'm crazy,your excuse is?
The burr is from the bolt twisting off, i would simply get a reverse drill bit- harbor freight sells it, simply try centering the smallest bit first and go up in size, eventually the bolt piece will simply unscrew out. I guess you could also drill out from the opposite side with a normal bit and it will twist it/push it out.
May 13th, 2014, 03:43 PM | #5 | |
So I went ahead and bought a new linkage, thing is that it's from a 1996 zx750. Hopefully it'll fit, looks like it will. Guess we'll find out, unless someone knows something I don't? http://www.ebay.com/itm/191156674843...84.m1497.l2649 |
May 13th, 2014, 05:29 PM | #7 |
May 13th, 2014, 05:49 PM | #9 |
Wannabe Reborn
3D print it. That's more reliable...
May 13th, 2014, 05:52 PM | #10 |
Board Member
drill it, then tap in a smaller screw or bolt. twist like your tightening it as it will run all the way through. use less force next time.
May 13th, 2014, 07:53 PM | #11 |
Fresh Deli Meat
Join Date: Feb 2014 Motorcycle(s): 2009 250R Ninja -Neener- Posts: 678
I had a Polaris 325 Trailboss that blew the centipetal clutch. Didn't have a clutch puller doojiggy so I looked up a DIY using a bolt and some other stuff (go easy on me this was years ago)
Long story short, the soft metal bolt expanded inside and was thoroughly destroyed. It took 3 days with extracters and picks before I gave up and kicked the stupid thing. Took it to the shop and they had it removed, rethreaded, and the clutch belt replaced in 20 minutes. While I am a firm believer that a motorcyclist should work on their own bikes, sometimes a white flag needs to be flown. You could even watch to see how they do it in case it happens again
We shall call thee "Seahorse." -Antiant on Couvade Syndrome |
May 19th, 2014, 04:40 PM | #12 |
Put the new linkage on last night and toke a 45minute ride. Even though it is from a 96 ZX750, it fits like a glove and works as intended. Overall I'm a happy camper as far as correcting my screw up is concerned.
Just thought I'd share that the linkage works well if anyone else was wondering. |
WTB: 2008 250R shifter & linkage | sparky80 | Items Wanted | 0 | January 24th, 2015 09:07 PM |
HELP! Shifter linkage bolt fell off! | The Red Scourge | 2008 - 2012 Ninja 250R Tech Talk | 1 | December 9th, 2013 07:20 AM |
WTB 2008+ Shifter and Linkage | Jojah17 | Items Wanted | 0 | March 14th, 2011 05:53 AM |
shifter linkage adjustment questions (after frame slider install) | BIGT94z | 2008 - 2012 Ninja 250R Tech Talk | 6 | July 24th, 2010 09:40 PM |
