Old October 3rd, 2013, 10:31 AM   #1
gp55445
gp55445's Avatar
Motorcycle(s): 2006 Ninja 250 and 2013 Ninja 300 SE
Changing Plugs - No SP tool in kit
My 2006 was missing the tool kit when I bought it so I don't have a flexible spark plug wrench. I also don't want to remove the tank. Is it possible to change the plugs w/o removing the tank if I use a flex connector on my socket?
Thx
GP
gp55445 is offline   Reply With Quote
Old October 3rd, 2013, 10:39 AM   #2
agentbad
agentbad's Avatar
My bike didn't come with a toolkit either so I just used a standard socket wrench with a extended socket and took my time. If you remove the gas tank it makes it a lot easier. I have similar socket tool that came with my set to bend it around the tight spaces but I just used an extender to get it around the frame and that seemed to work fine. Take your time and don't overtighten the plugs and you should be good.
http://faq.ninja250.org/wiki/Changin...rands_to_avoid
Old October 3rd, 2013, 10:46 AM   #3
cuong-nutz
cuong-nutz's Avatar
Spark plug socket, 3" stubby extension, with ratchet and you're good to go. Removing the tank does make it easier.
HalfFast Racing Team
Old October 3rd, 2013, 12:52 PM   #4
GeorgeRYoung
Motorcycle(s): EX250, C10 Concours
socket needed
18mm thin wall long reach. I use a Craftsman 1/2" drive.
GeorgeRYoung is offline   Reply With Quote
Old October 3rd, 2013, 12:54 PM   #5
gp55445
gp55445's Avatar
Thanks for everyone's advice
Old October 3rd, 2013, 01:32 PM   #6
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
thread JACK warning!!:: antiseize or no antiseize on threads?
My Cafe Racer Build
My intro post
Old October 3rd, 2013, 08:48 PM   #7
The_big_dill
The_big_dill's Avatar
Motorcycle(s): 1987 Ninja 250 custom gold
Ideally, you don't want to use antiseize, you need dielectric grease. Furthermore you don't want to apply anything on plugs that have metal coating on them. Depends on company, but NGK is the only plug you want to be putting in there:
http://www.ngksparkplugs.com/pdf/tb-...1antisieze.pdf
The_big_dill is offline   Reply With Quote
Old October 3rd, 2013, 08:56 PM   #8
cuong-nutz
cuong-nutz's Avatar
Absolutely no antiseize with ngk plugs!
Old October 4th, 2013, 09:07 PM   #9
j98sprint
Motorcycle(s): '02 Ninja 250, '98 Triumph Sprint 900, '69 H-D Sportster XLCH 900
Been using anti-seize on every plug on every motor i've owned over the last 20 + years. I wouldn't install a plug without it.
j98sprint
j98sprint is offline   Reply With Quote
Old October 4th, 2013, 09:17 PM   #10
j98sprint
OK just read the warning not to use anti-seize on NGK plugs. I stand corrected. However I won't stop using the stuff as I was taught to use the "Mechanics Feel" when tightening anything.
Pardon me, I'm just old skool.
j98sprint
Changing Spark plugs w/o removing gas tank? ScorpionNinja 2008 - 2012 Ninja 250R Tech Talk 6 March 9th, 2016 09:12 PM
Spark plug removal tool or tool kit landon1 Items Wanted 11 April 1st, 2015 07:03 PM
Spark plug tool - check/change plugs AmyF 1986 - 2007 Ninja 250R Tech Talk 20 August 2nd, 2014 05:36 AM
WTB- Tool kit, R-0990, jet kit jman511115 Items Wanted 3 July 17th, 2012 01:44 PM
