October 14th, 2014, 11:56 PM | #1 |
Bluegrass in the house
Back in May, I picked up a 98 with 27k miles on it for a great price. The P.O. did nothing except put gas in it, and changed the oil, I think, he did this for about 17k of the total miles.
Needless to say it needed a lot of TLC. I am no stranger to rebuilding bikes, I did my 91 EX500 which was a basket case for sure to say the least, here is the link to see that build: https://picasaweb.google.com/1006527...KIEX500AkaZX5R With that said I went through the bike, repairing, replacing, & modifying as I went, with the exception of the engine/transmission that seems solid no noises or smoke. Here is a link to the evolution as told by pictures. https://picasaweb.google.com/1006527...IDXyZXyoe2m0QE Work performed : Cut and set sag front fork springs(springs from a Ninja 500 1st generation, rate is .80kg/mm ) Replace fork oil 15wt synthetic Install new fork seals and dust caps Replace rear shock(zx600c) Replace shock oil 15wt synthetic Change gears +1/-2 Rebuild/tune carbs, adjust idle mixture K&N air filter New brake pads F&R EBC extreme HH New Wave front rotor Used OEM rear rotor Modified OEM seat(gel/foam insert, Custom Seat Creation cover solo line cf silver/cf metal, heated kit) Extra heavy bar ends(3"/19oz) Heated grips w/ foam covers Touring windscreen(7 JuRock 18" 73%tint flip) Shorter bar risers(ZX600c lower bars about 1 1/2") Bridgestone BT-45s w/ Dynabeads Stainless steel allen head fasteners* Stainless steel braided brake lines Shorty adjustable levers HD clutch springs Charge/voltage LED indicator LED clock HID headlight(55w 6k) Replaced all other bulbs with CREE LEDs DIY integrated tail light kit w/clear lens DIY rear fender elimination DIY licence plate mount(LEDs to illuminate the plate/red LEDs tied into brake light) Flush mount front indicators w/duel color Cree LEDs(amber/white) Brake light modulator Maintenance free gel battery Compact air horn 2007 OEM fairings silver Genuine imitation carbon fiber wrap misc parts Reflective custom decals ZX-2R silver Reflective custom decal NINJA red(taillight lens) Reflective rim tape silver Electronic turn indicator relay Replace front side reflectors with flush mount turn indicators LEDs Installed rearview camera system Installed oil cooler Strip paint off grab handle, bare aluminum alloy.* Installed Universal Rear View Side Mirror Rain Board Sun Visor Shade Shield, converted to genuine imitation carbon fiber wrap with non- visible clear coat applied. All this and full maintenance and rebuild everything else except the motor. I'm sure I'm forget some stuff, but you get the idea |
October 15th, 2014, 07:22 AM | #3 |
Fighting Texas Aggie '05
Howdy
October 15th, 2014, 07:26 AM | #4 |
Welcome Scott! Nice work! I betcha ya'lls got ya some nice roads down there. I should venture down there for a ride one long weekend. Should be beautiful country bout this timema year.
October 15th, 2014, 08:05 AM | #5 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
Welcome to the forum!
October 15th, 2014, 10:26 AM | #6 |
Thank you all for the warm greetings, and if your in my neck of the woods, look me up.
October 15th, 2014, 07:08 PM | #7 |
Hello and welcome.
October 15th, 2014, 07:38 PM | #8 |
Join Date: Jun 2012 Motorcycle(s): 2013 Ninja 300 Posts: 718
Woohoo, more Kentucky people!
DISCLAIMER: I generally have no idea what I'm talking about. |
October 15th, 2014, 08:39 PM | #9 |
Join Date: Dec 2008 Motorcycle(s): '08 Kawasaki EX250 "Yoshi", '99 Kawasaki Concours "Grace", '06 Concours "Belle", '06 Yamaha YZF600R "Slick" Posts: A lot.
< ATGATT > Sweat you can wipe off, Road rash you can't. HEY!! Unregistered!! Does your bike have a name? |
October 15th, 2014, 09:39 PM | #11 |
Join Date: Aug 2014 Motorcycle(s): 2007 Ninjette Posts: 809
WELCOME! 3 questions:
1. How do you like the BT-45s? 2. Is your modified OEM seat noticeably more comfortable? 3. PLEASE post a DIY or How to for your license plate mount.. It's the cleanest iteration I've seen so far!
"That's what" -she |
October 15th, 2014, 09:40 PM | #12 |
Also, the question you see in his signature isn't necessarily directed at YOU. It's directed at whoever is reading it. When I'm logged into my account, I see "Roark", and when you're logged into your account, you see "Ghostt"!
Pretty interesting, huh?
October 15th, 2014, 09:51 PM | #13 |
Intrepid Adventurer
Join Date: Jan 2012 Motorcycle(s): 2004 GSXR 750 , 71 cb350streettracker, 07 Polaris Predator 500 Posts: A lot.
LIFE IS NOT FOR REGRETS OR EXCUSES. Breath deep, seek peace. Embrace the Madness. Life is good, let it be |
October 15th, 2014, 10:00 PM | #14 | |
Yes the seat is most definitely better, even the heated part is just nice to have, like heated grips, once you've tried them, you'll never ride without them again. LOL, your gonna laugh at the plate mount. I had a piece of flat plastic, I just cut it to size, put a bend in it with heat gun, drilled the holes, and mounted it using the bolts that are under the tail. Lighting it up is 2 white LEDs mounted in the top holes, and I put red CREE LEDs in the bottom ones, and tied them into the brake light modulator. I was going to get this one, http://pages.ebay.com/motors/link/?n...741366&alt=web But then I just happen to find the plastic piece. You could also make it out of aluminum |
October 15th, 2014, 10:10 PM | #15 | |
October 16th, 2014, 09:43 AM | #16 | |
Intrepid Adventurer
The pré gens are the ultimate in reliability and adaptability. It does everything ok but nothing great ( besides run for ever and ever) I think it is a great thing there is a strong following for them out there. I have only ever ridden a couple pre gens. They just didn't feel right to me. But they were in rough shape. Maybe someday I will ride a well tuned one and it will change the way I feel. Until then - I prefer almost everything else. Then again if I see one for 400$ on CL then …..
October 16th, 2014, 12:40 PM | #17 |
Join Date: Sep 2010 Motorcycle(s): Cheap Italian Suit. Otherwise known as Dew Kitty Posts: A lot.
Welcome, my friend.
October 29th, 2014, 09:56 AM | #18 |
Got bored today, and decided to swap out the stainless steel windscreen bolts with black ones. Yes I was that bored, so I need some options on how it looks, and do I keep them or switch back to SS?
October 29th, 2014, 12:17 PM | #19 |
October 29th, 2014, 04:33 PM | #20 |
Motorcycle Hypermiler
Join Date: Jan 2012 Motorcycle(s): 1999 & 2005 Kawasaki Ninja 250R's Posts: A lot.
Welcome Scott, nice work on your pre-gen!
235 MPG Hypermotorcycling to a better tomorrow |
November 1st, 2014, 04:41 PM | #21 |
sammich maker
MOTM - Apr '15
Welcome ..I love the tail light
November 1st, 2014, 04:48 PM | #22 |
Thank you, you might notice the red "NINJA" on the taillight, it's reflective, I did this due to when a chopped the fender off, I lost the place for the OEM one, so I did this to keep it legal, and plus it looks cool too.
November 9th, 2014, 02:56 PM | #23 |
Well as the weather gets colder, my attention is turned to more modifications, so I'm making a list and will be working on them hopefully soon, if not around Christmas time.
November 10th, 2014, 07:24 PM | #24 |
Its offical
Her name is now official, and yes it's reflective vinyl silver, to match the other graphics.
November 10th, 2014, 11:20 PM | #25 |
Welcome.
[roadracingworld.com] - Bluegrass Motorsports Park Is For Sale, Asking Price $3.9 Mil | Ninjette Newsbot | Motorcycling News | 0 | December 3rd, 2012 11:20 AM |
[roadracingworld.com] - Something About Bluegrass Motorsports Park From A Guy Who Use | Ninjette Newsbot | Motorcycling News | 0 | February 4th, 2010 01:00 PM |
[roadracingworld.com] - Construction Delays At Bluegrass Motorsports Park Force Fastt | Ninjette Newsbot | Motorcycling News | 0 | June 12th, 2009 11:20 PM |
[roadracingworld.com] - Bluegrass Motorsports Park Won't Be Open In Time For WERA Nat | Ninjette Newsbot | Motorcycling News | 0 | May 14th, 2009 12:40 PM |
