February 18th, 2015, 03:56 PM | #1 |
Join Date: Feb 2015 Motorcycle(s): Range of machines Posts: 1
Aftermarket Gauge - Gear indicator
Hi all, I just ordered an aftermarket gauge for my 2007 hartford 125 vr(its actually just the engine in a DIY go kart). The only thing that wont work is the gear indicator. There are 6 input wires for the gears, and i believe it to be if wire 3 reads 12v, then its in 3rd gear and so on. Is there any way at all of getting it to work. If there was some electrical device that would read in my tach and speedo pulses and compute what gear i was in and output it in the way i described above. Or a method using magnetic sensors on the shifting arm. If anyone could shed some light on the situation or point me in the right direction it would be really appreciated. Thanks
February 18th, 2015, 04:27 PM | #3 |
Welcome Conor! Hopefully someone can help you out with your question soon.
February 18th, 2015, 05:16 PM | #4 |
(Running), okay I'm here,
Here is a write up courtesy of @jdoucet93, that may or may not help you, https://www.ninjette.org/forums/showthread.php?t=91040 I have also done the exact same modification to my Ninjette. It would help if you can supply the make and model for your aftermarket gauges.
February 19th, 2015, 12:33 AM | #5 |
Join Date: Dec 2008 Motorcycle(s): '08 Kawasaki EX250 "Yoshi", '99 Kawasaki Concours "Grace", '06 Concours "Belle", '06 Yamaha YZF600R "Slick" Posts: A lot.
< ATGATT > Sweat you can wipe off, Road rash you can't. HEY!! Unregistered!! Does your bike have a name? |
February 21st, 2015, 07:08 AM | #6 |
Hello and welcome.
February 21st, 2015, 10:33 AM | #7 |
sammich maker
MOTM - Apr '15
Welcome
https://www.brocksperformance.com/VZ...0035+C450.aspx |
February 22nd, 2015, 11:44 PM | #8 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
:narwal:
Anyone use a gear indicator? | Ducati999 | General Motorcycling Discussion | 34 | March 15th, 2014 09:12 PM |
Shift Light, Gear Indicator, Temp Gauge - WHERE ARE YOU???!!! | 2013 kawi girl | 2013 - 2017 Ninja 300 General Discussion | 14 | October 21st, 2012 12:00 AM |
Koso gauge and gear indicator confusion | randomwalk101 | 2008 - 2012 Ninja 250R Tech Talk | 49 | July 29th, 2011 08:35 AM |
Koso gauge & gear Indicator install | randomwalk101 | 2008 - 2012 Ninja 250R Tech Talk | 4 | February 20th, 2011 10:32 PM |
gear indicator? | mike_sema | 2008 - 2012 Ninja 250R Farkles | 11 | December 26th, 2009 03:32 PM |
