Old February 26th, 2014, 03:52 PM   #1
LilMiss
LilMiss's Avatar
Motorcycle(s): Ninja 250; Passenger on a Buell 1125R
I'm short! Anyone else??
I rea the thread about lowering the bike. I'm preparing to order the kit to do it. My question is, I am 4'10. Anybody else this short had success?
LilMiss is offline   Reply With Quote
Old February 26th, 2014, 04:00 PM   #2
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
I know there are short riders on here, so you should be able to find some advice. Though I have found its mostly about inseam vs height. I'm 5'4" with a 29" inseam, found a few guys who are taller than me with the same inseam.
@LittleRedNinjette has lowered her bike so she may have some advice in that direction.
Old February 26th, 2014, 04:05 PM   #3
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
There are also other options, like customizing your seat and such. Can you touch the ground at all? One toe at least?
Old February 26th, 2014, 04:09 PM   #4
My wife is your height. Shaving the seats height as well as width will go a long way.
Old February 26th, 2014, 04:15 PM   #5
NevadaWolf
NevadaWolf's Avatar
One of the things I want to do is get some blocks (?) that move my rearsets back a bit so I can put my feet straight down vs having to go around the pegs.
Old February 26th, 2014, 04:26 PM   #6
LittleRedNinjette
Certified Troublemaker
LittleRedNinjette's Avatar
I used the roaring toyz kit on both my bikes. Its a great setup with the links and the blocks.
Whats your stand over? Mine is 26" or 27" depending on my boots. I have the links at the middle hole and works well for me, not completely flat footed but i like it there.
You can also put a ZX600A '85-'87 rear shock on. That drops it a good bit more. and its a detect bolt on, think we just needed a couple extra washers.
Hope this is helpful!
Old February 26th, 2014, 04:27 PM   #7
LittleRedNinjette
I did this to!
And a saddlemen low seat. These are super comfy!
Old February 26th, 2014, 04:40 PM   #8
LilMiss
LilMiss's Avatar
My inseam is 27 without shoes on. I can toe the bike on both sides, but not balls of feet, which I would we comfortable with even if I can't flat foot quite.
Old February 26th, 2014, 04:41 PM   #9
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
What ever happened to platform shoes? I guess you have to ride the pole to wear them!
Old February 26th, 2014, 04:48 PM   #10
LittleRedNinjette
You sould be fine then, i would go with the seat and the kit.
Smart-ass strikes again!
But yes, some hiding wedge riding boots would probably help too.
Old February 26th, 2014, 04:55 PM   #11
LilMiss
LilMiss's Avatar
Roaring Toyz is what I was going to buy. Not sure on my stand over, I can check tonight.
Old February 26th, 2014, 05:11 PM   #12
Brian
Brian's Avatar
Motorcycle(s): 08 250R
I'm 2'4" and I have no problem with my ninja.
Only kidding.
There are a lot of customization options, but it's important to make sure that when you're done with it you can plant your two feet on the ground firmly or at least get a good hold with your tippy toes so ya don't fall over and die
Brian is offline   Reply With Quote
Old February 26th, 2014, 05:17 PM   #13
LilMiss
LilMiss's Avatar
Only kidding.
Lol. My end goal is not dying, so I definitely agree with you there. What have you done to your bike? Well I just read that you are Brian, not LittleRedNinjette. So if you didn't shorten your bike I understand. Haha
Last futzed with by LilMiss; February 26th, 2014 at 05:20 PM. Reason: I don't read apparently. Lol
Old February 26th, 2014, 05:22 PM   #14
Brian
Brian's Avatar
Just an exhaust muffler upgrade and a ZG windscreen. No problem with height though, I'm actually 5'10 . Really looking forward to a better fender eliminator kit then the sawed off one from the previous owner(s). Also a seat cowl and better headlights in the future once I stop being broke.
Old February 27th, 2014, 12:02 AM   #15
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
My inseam is about 28", potentially slightly less haha. I've been riding a stock height new-gen 250 and 300 with no problems; I only use one foot when stopping. However, I learned to ride on a lowered pre-gen 250 and I'm glad I learned on the lowered bike.
If you're learning to ride, lowering the bike could be useful in gaining experience and confidence. I would keep the stock parts in case you want to raise the bike back up later when you're more comfortable riding. Be careful not to lower the bike too much or you might run into issues there.
Old February 27th, 2014, 12:10 AM   #16
LilMiss
LilMiss's Avatar
Thanks! I am just learning to ride. Been the passenger for a year and a half and am finally in the drivers seat this summer. I definitely like the stock height, and will probably put it back after I'm comfortable. I'm only going to lower it as much as I need to.
Old February 27th, 2014, 09:46 AM   #17
NevadaWolf
NevadaWolf's Avatar
Just keep in mind that you do not need to flat foot both sides. You already said you were aiming for just getting the balls of your feet down which is good.
After awhile of practice, you'll find that you can safely stop with just one foot down, keeping the other on the brake. With just a very slight lean to the left, i can keep my foot stable on the ground while waiting at a light or in traffic.
Just another idea to work towards if you want.
Old February 27th, 2014, 09:57 AM   #18
mikedabike64
Motorcycle(s): 2008 ninja 250
Smile iam 5ft 4
I never had an issue of tippy toeing my bikes, save a dip in the road here and there but, the thought of lowering it just spooks me a little bit I don't know if that's changing the geometry of the bike, or ground clearance issue
I always towed it on all of my bikes, if nothing else it build your calves jk
and since I do more riding at the track then on the street, it is really a non-issue because once you start going you don't get off of your bike until you're back by your truck and who cares if you fall off there.
I did notice in the summertime if your pants stick to your legs, you have to be careful throwing a leg over it he he.
mikedabike64 is offline   Reply With Quote
Old February 27th, 2014, 10:49 AM   #19
Rogue
Hooligan
Rogue's Avatar
Motorcycle(s): 2013 Ninja EX300
I would love to move mine back a bit so I can gain that little bit and stop having so many bruises from banging into the darn things. Please let me know if you get this worked out.
I suggest either the Daytona Ladystars (or M Stars - same boot for both women & men, just different size ranges is all) to gain some height.
Or, if you don't want to spend quite that much on boots (though they are awesome and supremely well made), then you might try the Dainese Sirens. I have the Dainese and they add almost an inch to my inseam. It was the difference between just getting my tippy toes down and having the ball of my foot firmly planted on my 300.
Qui patiens est, teres. Teres est, ieiunare. | Twitter: @Rogue_300
Rogue is offline   Reply With Quote
Old February 27th, 2014, 11:00 AM   #20
LittleRedNinjette
The cost of boots is the only thing keeping me from getting them. But my work boots are thick soled and give me a bit of height.
And they were free.
Old February 27th, 2014, 11:33 AM   #21
fr1dayn1ght
fr1dayn1ght's Avatar
Motorcycle(s): '07 Ninja 250 (sold), 2013 CB500F
im 5'6 and im still having trouble with tip toe-ing the 250 (mostly backing out parking slot), my friend is same height but idk how he can ride a stock R6 without even lowering kit! I saw the way he tip toe the R6 just like those ballet dancer...
I guess short rider and high bike is possible
fr1dayn1ght is offline   Reply With Quote
Old February 27th, 2014, 11:44 AM   #22
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
I rode a full size mx bike. When i came to a stop, i needed to lean the bike over t0 tip toe on one side. I'm 5'9". Really the only trouble would be parking lot maneuvers...
Old February 27th, 2014, 12:05 PM   #23
LittleRedNinjette
Height isn't the biggest factor (i'm 5'1" ) its the standover height. I have stubby legs, but someone else the same height may be all legs thus a higher standover. Its all in how one is built.
Old March 2nd, 2014, 09:39 AM   #24
NevadaWolf
NevadaWolf's Avatar
@LilMiss, if @greenswoave hasn't found a home for them yet and you haven't ordered your kit, check out this thread offering the Roaring Toyz Front Lowering Kit for free
http://www.ninjette.org/forums/showthread.php?t=166515
<-- Linky
Old March 2nd, 2014, 09:58 AM   #25
antiant
antiant
antiant's Avatar
Motorcycle(s): None
MOTM - Oct '14
Your height doesn't matter, what matters is your inseam. People can be the same height and one person can be more leg, more torso, etc. Your inseam is what makes the difference and how you're proportioned.
Edit: Just saw this...
antiant is offline   Reply With Quote
Old March 2nd, 2014, 11:00 AM   #26
tfkrocks
tfkrocks's Avatar
If you are interested, I have a set of Roaring Toys lowering links. They're slightly scraped but still fine to use.
Old March 2nd, 2014, 12:05 PM   #27
greenswoave
greenswoave's Avatar
Motorcycle(s): USA
Thanks for the plug. LilMiss has indeed claimed my kit.
greenswoave is offline   Reply With Quote
Old March 3rd, 2014, 01:26 AM   #28
LilMiss
LilMiss's Avatar
Thanks again greenswoave!
"You live more in 5 minutes on a motorcycle than some people do their whole lives." RIP Chaz R. Sands 1988-2014. I love you yesterday, today and forever.
Old March 3rd, 2014, 01:27 AM   #29
LilMiss
LilMiss's Avatar
I PM'd you btw...I think. Lol
Old March 3rd, 2014, 01:30 AM   #30
NevadaWolf
NevadaWolf's Avatar
Always glad to help. Makes me put my endless surfing of this site to some use,
Jax, FL eh? I may be PMing you for some local knowledge before too long. Thinking of a road trip to your neck of the woods.
Old March 5th, 2014, 07:02 PM   #31
Frogger
Motorcycle(s): 250 ninja, 600 gsxr
Lowering links
I'm 5ft 2 so a bit taller... I don't recommend lowering if you ride track ... But if it's just street riding, then go for it!
If you ride track best thing to do is get the seat shaved. I have a gsxr600 and can't touch after lowering it I raised it back up, def doesn't handle the same (on track) . My 250 is much smaller and much lighter, so that helps but still only can touch one foot, so just practice and balance getting off and on.
Frogger is offline   Reply With Quote
Old March 7th, 2014, 12:55 AM   #32
LilMiss
LilMiss's Avatar
No track...this year anyway. My first year as a driver, so trying to learn. I dot mind tip toeing it, I've played around a little bit in the garage while waiting for a spot to open in the MSF class. I can hold her up, get on and off, but it's much more tiring doing it all on tippy toe (on one side). I just want to w comfortable and not worry about fatigue and legs that hurt like a b**** after 5 minutes while I'm learning. I'll probably put her back at stock once I'm comfortable.
Old March 7th, 2014, 10:27 AM   #33
408junglist
You'll be happy with the roaring toyz kit
I'm 5'0" with shoes/boots. I put the 1" roaring toyz blocks up front and the lowering links for rear. Be careful which holes you pick for the lowering links, the wrong hole will make a significant amount of height difference. I did 1" rear and the stability of the bike while cornering is barely changed at all. I am only 110lbs though.
408junglist is offline   Reply With Quote
Old March 7th, 2014, 05:23 PM   #34
LilMiss
LilMiss's Avatar
I'm 90lbs. :-) I'm going to keep the front and rear lowered at the same level. I want to change as little as possible.
Old March 7th, 2014, 05:35 PM   #35
rasta
Your face
rasta's Avatar
Motorcycle(s): 2014 Honda CBR650f
Damn, I thought I was short. You're oompa loompa short
"even a proper fitting helmet can 'get loose'" -csmith
rasta is offline   Reply With Quote
Old March 7th, 2014, 05:42 PM   #36
LilMiss
LilMiss's Avatar
Yeah I know. At 4'10 and 90lbs it's not easy finding gear that fits either. Lol.
Old March 7th, 2014, 05:57 PM   #37
Aerio
Enter Title Here
Aerio's Avatar
Motorcycle(s): 2010 Ninja 250
That is tiny tiny.
Aerio is offline   Reply With Quote
Old March 7th, 2014, 07:39 PM   #38
408junglist
Yup I've had the same problem too. This may sound funny but most of my gear is women's gear lol but it's all black so you can't tell. My alpinestars jacket, racing boots, and full leather suit is women's. Haha
Old March 8th, 2014, 04:31 AM   #39
LittleRedNinjette
You're as tiny as one of my best frends. Carful you don't get blown off!!
Raven's Rejuvenation
Old March 8th, 2014, 04:55 AM   #40
LilMiss
LilMiss's Avatar
All my gear is A*s too for the most part. I have the Stryker Vest and Airframe helmet from Icon. And i had to buy elbow armor and take the armour out of my jacket. The elbow armor that was in my jacket covered just below my wrost to an inch below my elbow haha.
Short but heavy trugracie 2008 - 2012 Ninja 250R Tech Talk 10 February 18th, 2014 10:03 PM
Short film Alex Off-Topic 3 February 10th, 2013 10:00 PM
First (very short) trip!! 250rr Ride Reports 21 December 4th, 2011 11:59 PM
too short to ride... mz_twee New Members 30 July 5th, 2011 06:56 AM
For The Short Riders... Majik General Motorcycling Discussion 22 October 16th, 2009 03:19 PM
