Old October 20th, 2014, 07:58 AM   #6201
CZroe
CZroe's Avatar
Originally Posted by tfkrocks View Post
Finally put in a rear brake light pressure switch. Rear brake hasn't turned on the brake light since I got woodcraft rearsets. Also did a rear brake reservoir delete because the damn thing didn't really fit well with all the crap I got going on in that spot.
I have the Yoshimura exhaust hanger for the J-bike but it doesn't have that hold for mounting the reservoir. They should both for both bikes!
Old October 20th, 2014, 09:37 AM   #6202
Finally unloaded it from the trailer yesterday. lol Needs a bath and various new bolts & bits.
Old October 20th, 2014, 09:08 PM   #6203
Clacquam
Motorcycle(s): None yet
put a new windshield on it and some swingarm spools!
Midwest Instiute Massage Therapy Certification
Clacquam is offline   Reply With Quote
Old October 23rd, 2014, 08:14 PM   #6204
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Changed to a 42T rear sprocket and got me some decent (hopefully) running shoes!
<-- Linky
Old October 25th, 2014, 04:58 PM   #6205
jenkem
jenkem's Avatar
Motorcycle(s): 2007 ninja 250
Spark plugs and a bit of a wipe down. I park on dirt that's been getting looser every time I even think about using the throttle on it, so I'm growing to accept that dirty look/vibe.
jenkem is offline   Reply With Quote
Old October 26th, 2014, 08:45 AM   #6206
allanoue
allanoue's Avatar
MOTM - Sep '14
K&N air filter installed.
Kerry said no ecu map change needed.
Old October 26th, 2014, 08:48 AM   #6207
allanoue
allanoue's Avatar
MOTM - Sep '14
What are you initial thoughts on the running shoes?
Old October 26th, 2014, 11:08 AM   #6208
NevadaWolf
NevadaWolf's Avatar
Love them! After 1100 miles yesterday, they show almost no sign of being ridden at all (solid interstate yesterday and the DRIIs previously had begun to square off under similar conditions). Also I rode through heavy rains and intense winds and they stayed glued to the road regardless.
I feel very confident on these. So glad of all the reviews showing them to be solid tires.
<-- Linky
Old October 27th, 2014, 07:14 AM   #6209
zhuuka
Turtle Dancer
zhuuka's Avatar
Motorcycle(s): 2014 Ninja 300 SE
Got out the trusty Honda cleaner, cleaned all fairings and various parts and scubbed the seat clean. Put air in the tires. She was getting dusty from all the dead leaves.
Videos!
Twitterthingermajigger
zhuuka is offline   Reply With Quote
Old October 29th, 2014, 09:03 AM   #6210
allanoue
allanoue's Avatar
MOTM - Sep '14
Took it off the road until I get the chain tightened. More likely it will need replaced which means a couple of weeks stuck in the barn.
Old October 29th, 2014, 10:08 PM   #6211
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
This arrived today: http://admorelighting.com/store/inde...product_id=176
I was ready to install it right after opening the package but found that they only sent me one led strip so now I have to wait
My Ninja 300
Old October 29th, 2014, 10:46 PM   #6212
Aimed my new garage security camera at it.
Old October 30th, 2014, 09:28 AM   #6213
allanoue
allanoue's Avatar
MOTM - Sep '14
Tighten the chain and loosed up the tight spot that I think caused the extra slake. I do have a new chain and sprockets on the way, but I do not think I need to swap it out just jet. I am over 20,000 miles so soon
Should I change the sprockets when I change the chain even if they look OK?
Old October 30th, 2014, 09:35 AM   #6214
LittleRedNinjette
Certified Troublemaker
LittleRedNinjette's Avatar
I always heard you change them together so they wear down the same or don't prematurely wear the new chain...
Raven's Rejuvenation
Old October 30th, 2014, 09:48 AM   #6215
allanoue
allanoue's Avatar
MOTM - Sep '14
I have read folks say every other time.
Old October 30th, 2014, 10:10 AM   #6216
tfkrocks
tfkrocks's Avatar
I've always heard every time as well and that's what I go by. Chains are expensive.
My Ninja 300
Old October 30th, 2014, 03:39 PM   #6217
jenkem
jenkem's Avatar
Almost died on it. Hit one of those things while changing lanes on the freeway in such a way that it sent me into the gnarliest wobble. The whole time I just kept thinking, man, I wish I had the power to drive out of this but I was already doing 80ish so I had almost zero left over torque. Sort of just rode it out, slammed my weight on the pegs a bit, tried to loosen up, but it definitely caught me off guard. Bit of a wake up call to brush up on my emergency techniques.
Old October 30th, 2014, 03:44 PM   #6218
This year has been bad for wobbles like that. I have seen some of the worst slappers this year than any other year. Dunno why, it just is what it is. Glad yours was uneventful as many others.
Old October 30th, 2014, 03:48 PM   #6219
NevadaWolf
NevadaWolf's Avatar
Nope, found a place selling some for $10-$20! If you are brave that is....
<-- Linky
Old November 4th, 2014, 03:36 AM   #6220
tfkrocks
tfkrocks's Avatar
Installed the admore lighting LED kit in my Givi topcase. Works as running lights, brake lights, and turn signals. The brake light will also flash 3 times. Super easy install.
Video to come whenever youtube wants to stop being a piece of ****.
ETA: Youtube refuses to process my video
ETA2: Finally worked. I posted it in my thread
https://www.ninjette.org/forums/show...&postcount=227
My Ninja 300
Old November 4th, 2014, 06:39 PM   #6221
Geezer-60
Geezer-60's Avatar
Motorcycle(s): 2007 BMW F800s, Former 2011 Ninja 250r
Routine pre-ride safety check found burnt out left rear turn signal bulb. MSF BRC really drilled the need to do that, glad I did.
Geezer-60 is offline   Reply With Quote
Old November 5th, 2014, 06:28 AM   #6222
LittleRedNinjette
Installed some new saddle bags. Loving the extra cargo space and no backpack.
Old November 7th, 2014, 06:04 PM   #6223
cbinker
cbinker's Avatar
Drained the radiator, now need to pick up some coolant before the freeze sunday night.
TEAM ALFALFA
www.apexassassins.com
Old November 8th, 2014, 08:23 PM   #6224
NevadaWolf
NevadaWolf's Avatar
<-- Linky
Old November 12th, 2014, 12:19 AM   #6225
jenkem
jenkem's Avatar
twisties with a 300
I got a little overzealous with the pictures
Old November 12th, 2014, 04:16 PM   #6226
cuong-nutz
cuong-nutz's Avatar
Had my helmet and gloves stolen off my bike while I was at work. I guess My seat latch didin't lock down all the way and the thief made off with my gear. It was a cold, sniffly, and not so loud ride home. Lucky for me I had one ear plug. The luck. Going to lube up the chain since it's all dry and gritty from all the rainy excursions.
HalfFast Racing Team
Old November 12th, 2014, 05:26 PM   #6227
LittleRedNinjette
Man, that sucks! What the f is wrong with people.
Old November 13th, 2014, 07:25 AM   #6228
cbinker
cbinker's Avatar
added more coolant to the radiator, its been <10* all week.
TEAM ALFALFA
Old November 13th, 2014, 10:06 AM   #6229
Rogue
Hooligan
Rogue's Avatar
Motorcycle(s): 2013 Ninja EX300
That is beyond impressive!
I'm trying not to think about the fact that mine is sitting outside with less than a half tank of gas and no Seafoam in the tank. I really should have filled up when I finished riding on Monday and made space for it in the garage.
Qui patiens est, teres. Teres est, ieiunare. | Twitter: @Rogue_300
Rogue is offline   Reply With Quote
Old November 13th, 2014, 10:22 AM   #6230
allanoue
allanoue's Avatar
MOTM - Sep '14
What is the temp there now? 250* kelvin
Old November 13th, 2014, 12:12 PM   #6231
Rogue
Hooligan
Rogue's Avatar
We have warmed up to a balmy 25* F, which sadly, is about 10* warmer than yesterday.
Old November 13th, 2014, 07:44 PM   #6232
cuong-nutz
cuong-nutz's Avatar
Oil change. I need to rejet back to stock.
Old November 13th, 2014, 07:54 PM   #6233
Flying
Motorcycle(s): 2010 Ninja 250
Rode it through the first snow of the season.
Old November 13th, 2014, 10:44 PM   #6234
cbinker
cbinker's Avatar
we broke the kelvin scale here...
TEAM ALFALFA
Old November 14th, 2014, 10:26 AM   #6235
LittleRedNinjette
You rode in that? At least it wasn't sticking to the roads. Not by me anyway.
Not that it was a blizzard or anything but hell no, not for me.
Old November 14th, 2014, 05:17 PM   #6236
takumidesh
Motorcycle(s): ex250r '07
got the front fairing primed and ready to go for the last of the blue paint! I'm so excited!!
takumidesh is offline   Reply With Quote
Old November 16th, 2014, 07:27 PM   #6237
Unloaded it from the trailer to the garage, a sad day indeed. She will lie in wait until next season.
Old November 17th, 2014, 06:30 PM   #6238
CZroe
CZroe's Avatar
"Seat" or solo sport cowl? The solo sport cowl doesn't actually secure at all and it's super easy to take it off without a key (sometimes you pull out a rubber damper or two).
Old November 17th, 2014, 10:46 PM   #6239
cuong-nutz
cuong-nutz's Avatar
Yeah pillion seat.
Good news. Found the thief today. He posted on craigslist and on Facebook trying to sell my stolen gear. Cops have been notified and the guy will be in for a rude awakening when he loses his job and I make his life a living hell. I love my moto friends!
Old November 18th, 2014, 06:56 AM   #6240
CZroe
CZroe's Avatar
Yeah pillion seat.
Awesome! Got a link? Is he a coworker? I'm curious. I'm sure that none of us are stupid enough to contact him and interfere with a police investigation. I wonder why he didn't take the seat too.
