Old January 7th, 2017, 09:46 AM   #1
Mikemsc21
Motorcycle(s): rieju tango
My flasher is buzzing why
My bike was working fine nothing wrong with it atall i locked it up covered it up and went to bed woke up and went to ride my bike first when i turned the key there was no power. The batterie is fully charged. So i kicked started it and it turned on i got to the end of my road went to indercate and it wasnt working. I tried both sides neither worked. When i looked at the flasher it was buzzing when i turned them on and stopped when i turned them off. Also buzzes when i push the ignition. Please help its my only way of getting to work.
Mikemsc21 is offline   Reply With Quote
Old January 7th, 2017, 09:58 AM   #2
Welcome Miky!
The very first thing to check would be your battery connections. Clean and tight sir. Hopefully it is as simple as that.
Old January 7th, 2017, 10:01 AM   #3
Mikemsc21
Ive tried that
Ive cleaned connectors its a brand new batterie too.
Old January 7th, 2017, 10:05 AM   #4
ducatiman
ducatiman's Avatar
failed or defective flasher relay? Fully seated (plugged in) to its housing or socket?
I'd also suggest to confirm the output of the charging system (voltmeter)
What year/model bike?
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old January 7th, 2017, 10:06 AM   #5
Mikemsc21
Thanks for the reply
Thanks for the reply. I think im going to replace both and hope for the best..
Old January 7th, 2017, 10:08 AM   #6
Don't just throw parts at it man, most bits can be fully tested. Divide and conquer here, let's focus on your starting problem first.
I know you said the battery was new, but have you tested it via a meter under load? It would suck to have it read 12v just sitting there and then dip to 10v ish volts under load.
Is it the solenoid buzzing? Have you tried jumping the poles?
Old January 7th, 2017, 10:13 AM   #7
Also, I know it's the colder season and many batteries will bite the dust this time of year, but when a battery goes bad, I always suspect a possible stator or regulator problem as well. Especially if I have a dead battery "all of a sudden" for no good reason. Again, this can be tested with a meter while the bike is running. Greater than 12v, but under 15v while idle says all is good with your charging system.
Old January 8th, 2017, 04:50 AM   #8
Mikemsc21
Bridged relay
I bridge the relay and it turns everything on i havent chnaged anything to the bike atallso i dont no why its doing this
Old January 8th, 2017, 08:04 AM   #9
Either the relay is deffective (bad internal contactors) or the voltage reaching its connectors is much less than 12 volts.
I would use a cheap voltmeter to verify the voltage before start replacing things.
The problem may be bigger than a bad relay if your bike was electrically dead having a new battery.
As mentioned above, either the battery is deffective, it is being drained down by a short while in storage, or the charging system is not working properly.
Check these applicable links out:
http://faq.ninja250.org/wiki/Electrical_%26_Lighting
Old January 8th, 2017, 08:30 AM   #10
Mikemsc21
Resolved
I was putting in broken 10 amp fuses that i had in my tool box. Thought ill go down the to halfords and get some and it worked stright away.
Thanks to everyone for the fast responces will always use this site and will recommened it to all my fellow bikers.
Old January 8th, 2017, 08:48 AM   #11
Old January 8th, 2017, 09:28 AM   #12
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Glad it's fixed.
Old January 29th, 2017, 07:59 AM   #13
Snake
Snake's Avatar
Hello and welcome!
Old January 31st, 2017, 07:19 AM   #14
taz
taz's Avatar
MOTM - May '17
welcome
Right turn signal dead and buzzing Noobman 2008 - 2012 Ninja 250R Tech Talk 3 September 3rd, 2013 05:38 PM
Fuse removal and buzzing Jiggles 2013 - 2017 Ninja 300 Tech Talk 13 April 3rd, 2013 09:38 PM
Buzzing Noise on Ignition Avenged7Fold 1986 - 2007 Ninja 250R Tech Talk 14 October 5th, 2012 02:21 PM
flasher relay buzzing? rawbert625 2008 - 2012 Ninja 250R Tech Talk 9 July 17th, 2012 12:21 AM
Hearing loss and buzzing with earplugs!? what to do? 5evenz General Motorcycling Discussion 13 October 29th, 2011 10:38 AM
