May 10th, 2013, 08:39 PM | #1 |
"scandal!"
Preparations for an 800 mile trip?
Wanted to ask if you guys insist on any pre-trip preperations. Details below.
The trip is to be from one tip of Texas to the other, that is El Paso to Brownsville. I'm very likely to mail all my clothes and living stuff there as I will be there for two months to do research. Feel free to go ahead and post now or continue reading what the gurus have suggested for me below. 1- tire fix kit; sheet metal screws, tire hole sealant compound, pump, stock toolkit, bike prop for raising the read tire if need be replaced. (just realized I don't quite get why the prop yet if I won't have a spare tire. 2- rain suit 3- check and maintain chain, brakes, cables, valves, spark plugs.i 4- food and water. I think that's all I got for now. They suggested I take the trip at 60mph the whole way to reduce wear and tear considering the 250 runs high revs at 80mph, take a break every hour, and to make it a 2 day trip. Look forward to your responses. |
May 10th, 2013, 08:42 PM | #2 |
From our sticky thread at the top of the Riding Skills area:
Riding Long Distances: Thread 1, Thread 2, Thread 3, Thread 4, Thread 5
May 10th, 2013, 08:44 PM | #3 |
No need to keep the bike at 60, at least not for longetivity's sake. It will happily run at 80+ forever as long as there is oil in it. Some of the older gen ninjettes were prone to losing oil out the airbox if at very high revs for sustained periods, but it won't be an issue for your bike.
May 10th, 2013, 09:02 PM | #4 |
Join Date: Jan 2011 Motorcycle(s): 06 yzf r6r previously: 09 ninja 250r, black 07 zx6r Posts: A lot.
I'd recommend a butt cushion for long rides. the 250's seat isn't the softest and no one likes a sore bum... Also, a "cramp buster" type deal is helpful on the wrist (most local shops seem to carry these). Maybe some saddle bags or a tail bag or tank bag. If you wear a backpack, try to either reduce the weight of it, or adjust the straps to allow it to rest on the passenger seat, effectively taking the weight off your back. Waterproof shielding for not only you and your bike but also your bags if the weather takes an unexpected turn. I always hook up a cigarete lighter style power socket (with in-line fuse and switch) to charge phones / gps / ipod or whatever. Also, don't forget, if you pass through tolls, some only accept exact change so be ready for that.
May 10th, 2013, 09:07 PM | #5 |
Que Buenos Son!!!
MOTM - Nov '14
Looks like you've got the basics covered. If your bike is in good mechanical condition then it should have no problem making the trip.
I'd start looking at things that would make the trip more comfortable for you, cause 800 miles on a ninja can get pretty tiring. When I take long trips I usually try to pull over once an hour to stretch and take a break. You might want to consider a sprocket change also to lower the rpm's at high speed, but like Alex said a stock 250 can be run all day at 80 mph no problem.
May 10th, 2013, 09:15 PM | #6 |
Some sort of pain reliever.
May 10th, 2013, 11:58 PM | #7 |
Towster ['__'`,-,
Join Date: Jan 2012 Motorcycle(s): 2010 Green Ninja 250 SE Posts: 379
Honestly, I did 90 miles today, half freeway and I was getting super sore. Wind was relentless, so I tucked mostly. But tucking aint comfortable either. Good luck man!
May 11th, 2013, 06:17 AM | #8 |
Join Date: Oct 2012 Motorcycle(s): 2012 red 250 ninja Posts: 740
I wouldn't worry about taking a break every three hours. I would take a break every three hours, because that's when you run out of gas.
Other than that it depends on the road, like someone said be prepared for tolls, if you are going in hot weather have a jacket that can handle the heat, maybe a cooling vest beneath it. If you are going to be doing it at all at night make sure you have layers. No reason you can't do it in one day, but if you can't handle riding the bike for that long (no shame, just depends on what you are used to) then l would try to get the longest part done during day one. At least 500 miles. Make it easier on you the second day. After one long day the second day will be worse, so it might as well be shorter. If you make it to 600,650 or so, and you are sore but not exhausted, I would suggest just finishing, it will be easier than starting out sore and in pain. You will want a hydration system that fits in a tank bag too. And bring some snacks, protein and complex carbs are good. |
May 11th, 2013, 09:55 AM | #9 | |
Noise, hard seat and vibrations: It can affect you more than anything else. Wind: It will dry your skin out, you will need water + salts. You will need to stop to drain some of that (frequency depends on age). Sun: Protect your eyes and your neck. Insects: Since it is spring, they will splash on your visor (you will need abundant soft tissue with some enzymes) and on your radiator (old toothbrush?) and some may sting (some anti-inch ointment will be handy). Road debris: They may puncture and even cut any of both tires, as well as hit your shins and hands (you may need more than a sheet-metal screw and a rear stand). Locate repair shops, gas stations and tow services along the way. Thieves: Make your luggage hard to be removed and opened when you are away from the bike (remember stops for leaks?). If you stop for the night, consider extra locks and alarm for the bike. Some pepper spray may be very convincing at the right moment. Police: Carry all your papers and documents. Light: Carry spare light bulbs (especially the headlight) and fuses. Flashlight + batteries. Fluids: Your chain will need re-lube (I do every 200 miles, less miles if raining hard), your engine may need some oil (check it at each stop) and some distilled water, and even some gas if the distance between gas stations is more than 200 miles. Clean all your fuel and air filters. Miscellaneous: You never know when you may need soft wire, fuel hose, clutch cable, throttle cables, spare keys, nylon zip-ties and duct tape. As for strategy: Cruising speed of 75~80 indicated mph will reduce the suffering time for your butt and back with the only downside of less fuel economy (I keep my old-gen at 80~85 mph (~10K rpm) on highway for around 1 hour, every working day, with no problem and verified mileage of 55). Splitting your first long trip in two days and a motel night may make it much more enjoyable and safe. Consider as well that unexpected traffic, flat tires and weather problems are common occurrences that take huge chunks of Sunlight time. If you stop for a 10 minutes break after each hour of riding and keep rolling at 75 mph, it will take you a total of around 6 hours of uneventful traveling to complete half of your journey (400 miles). Sorry for the long list: I am old because I am cautions..........., I mean, the other way around.
May 11th, 2013, 01:48 PM | #10 |
"scandal!"
Thanks guys!
And as fir Alex, I suppose I didn't use the right keywords in the search. I couldn't find anything |
How to take a 1,500-mile road trip on a Ninja 250 | Motofool | General Motorcycling Discussion | 3 | March 1st, 2015 12:46 PM |
1000 mile trip | jesse4b11 | General Motorcycling Discussion | 95 | August 28th, 2014 11:40 AM |
buying a used 2,000 mile ninja 300 SE for $3,800.00 | noname | 2013 - 2017 Ninja 300 General Discussion | 8 | September 21st, 2013 07:02 AM |
[topix.net] - 1,000-mile motorcycle trip earns recognition for two Gilmer men | Ninjette Newsbot | Motorcycling News | 0 | February 24th, 2013 01:50 PM |
700 Mile Trip to Come... | jarnar591 | Ride Reports | 26 | April 27th, 2012 03:20 PM |
