October 8th, 2013, 08:56 PM | #1 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
My bike has too many gears:/
So someone got to at least 80mph in second or third, what are the other three or four gears for? Yes they redlined it, yes sadly he or she was speeding, and no they dunno what the other gears are for if they only get 20 or so more mph.
This is def technical
October 9th, 2013, 05:46 AM | #2 |
October 9th, 2013, 06:15 AM | #3 |
I'm crazy,your excuse is?
To have something to do and not get bored at high speeds?
October 9th, 2013, 06:52 AM | #4 |
What's wrong with Jackie chan?
Ill accept that as a good answer I'm kinda glad that I don't have the power to loop the speedo around to 200 or so
October 9th, 2013, 08:41 AM | #5 | |
I am scared of 70mph still.. |
October 9th, 2013, 08:54 AM | #6 |
I'm getin comfortable with 70, little by little. I wanna ride a track soon! I couldn't ride much in Florida, but I moved back here and ride like crazy
Got more Carolina miles in a short time than I ever got Florida miles Ain't many places you need to go 70 or over, ride your rode
October 9th, 2013, 09:16 AM | #7 |
Join Date: Jan 2013 Motorcycle(s): 08 Ninja 250 Posts: 108
There are more gears so that the engine will stay in its optimal range. It will lower engine RPM therefore reducing wear (increasing longevity) and improving fuel economy.
This is taken from Wikipedia. I know, I know, not always the best but it puts what I wanted to say into a coherent statement. "The need for a transmission in an automobile is a consequence of the characteristics of the internal combustion engine. Engines typically operate over a range of 600 to about 7000 revolutions per minute (though this varies, and is typically less for diesel engines), while the car's wheels rotate between 0 rpm and around 1800 rpm. Furthermore, the engine provides its highest torque and power outputs unevenly across the rev range resulting in a torque band and a power band. Often the greatest torque is required when the vehicle is moving from rest or traveling slowly, while maximum power is needed at high speed. Therefore, a system that transforms the engine's output so that it can supply high torque at low speeds, but also operate at highway speeds with the motor still operating within its limits, is required. Transmissions perform this transformation."
October 9th, 2013, 09:26 AM | #8 |
The power output of combustion engines is far from linear respect to the rpms; it gets reduced after certain range of rpms. If your engine is so strong that turns above that critical range of rpms, it very well can slowed down some via a gear switch, giving it a chance to push even harder. On the other hand, if you want a quick acceleration while at low speeds, more torque can be achieved by using the lower gears which speed up the engine up to that sweet range of rpms. Having an electrical motor with linear power and huge torque at low rpms, e-bikes need no gear box.
October 9th, 2013, 09:27 AM | #9 | |
October 9th, 2013, 09:44 AM | #10 |
Well your not doin 140 with a cage to protect you on the ninja... I ride the roads faster in my cage to I ain't ever felt like the wind could jerk me out of a cage, I can see the wind jerking a person off a bike :/
October 9th, 2013, 09:52 AM | #11 | |
Electric bikes??? Hmmm jet bikes sound more fun, an less bad for the environment... Do they come in solar?
October 9th, 2013, 10:23 AM | #12 | |
dirty boy
MOTM - Apr '14
is this some one you?
October 9th, 2013, 10:26 AM | #13 | |
I never redlined my bike before so yup I had to , I don't remember if it was second or third, what a rush!!
October 9th, 2013, 01:16 PM | #15 |
They're so you don't over-brapppp and use up all your brappppp's in the boring straight parts.
Better save those brappppps for the fun parts where they come in handy; the turns |
October 9th, 2013, 01:52 PM | #16 |
Brapps are a non-renewable resource and should be conserved.
You think the Ninjette don't need moar gearz... just wait til you try a big bike. On my 750, I can break the speed limit on the highway in first and never even come close to redline. On a typical back road ride I just put it in third and leave it there. Torque monster.... I reset the shift light so it fires at only 8k rpm and it almost never goes off. The power and speed are so effortless, and the chassis is so stable, that I've found myself doing a plain, garden variety, no-drama pass of a car on the parkway, only to look down and see three digits pop up on the speedo. This is AFTER installing the speedo healer so it's accurate.... OOOOOOppppssss..... (sheepish roll off). Once you start going faster, speed feels slow. That's what makes it dangerous.
October 9th, 2013, 03:07 PM | #17 |
i typically keep the 600 above 8k... suspension feels better with the wheel in the air :P
seriously though i brap brap everywhere. y u no brap brap all the time? you can brap brap in 6 too. just not so brap brapy. more like... breeeeeep.
October 9th, 2013, 03:33 PM | #18 |
Avid Kitteh Poster
Join Date: Sep 2011 Motorcycle(s): 2006 Yamaha TTR 50 SUCK IT Posts: A lot.
you cannot braap with an inline 4... only yut ugh... come on guys.
I powdercoat stuff Help me pay for my addiction I say funny stuff. http://twitter.com/JustinPWNSyou sometimes... I write like a 12 year old too, http://justinpwnsyou.wordpress.com/ |
October 9th, 2013, 04:19 PM | #19 | ||||
The twisties are fun, but I def braaaaap more on the straights
October 9th, 2013, 05:00 PM | #20 |
Dude, even the 250 is too fast for my maturity level
But really |
October 9th, 2013, 05:24 PM | #21 |
I don't see how anyone gets past a ninjette on maturity level... You didn't misplace A Douglas's post did ya??? I think I realize why my dad is against bikes for me and why he sold his without another one, kinda... Stupid step monster
( I need a lil smiley tapping his foot )
October 10th, 2013, 07:51 AM | #22 |
Avid Kitteh Poster
October 10th, 2013, 09:43 AM | #23 |
Just for fun when I was riding home last night I ran my 750 up to 60 mph in first gear and held it there for awhile.
It howled like a banshee. It was turning only 11k (redline on the 750 is, IIRC, 13.5 k). BzzgrrowwoooaahhhooooaaooooaaaaaaaaaaaOOOOAAAAAAAOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!!!!!
October 10th, 2013, 09:48 AM | #24 |
October 10th, 2013, 12:04 PM | #25 |
I'm going to have to request that you check your spelling on that onomatopoeia, Andrew.
October 10th, 2013, 01:19 PM | #26 | |
Join Date: Jun 2012 Motorcycle(s): 12' Ninja 250 Posts: 831
October 10th, 2013, 04:20 PM | #27 | |
Avid Kitteh Poster
October 10th, 2013, 04:32 PM | #28 | |
October 10th, 2013, 05:30 PM | #29 |
Join Date: Jul 2010 Motorcycle(s): 2014 Honda CRF250L, 2010 ninja 250r Posts: 413
I could just imagine pinning a zx10r in 1st or second.
October 11th, 2013, 02:32 PM | #30 |
Haha right... Or a zx14
October 11th, 2013, 05:39 PM | #31 |
Join Date: Sep 2012 Motorcycle(s): Suzuki GSX650F! Past: Kawasaki Ninja 300 (Sold); Triumph Street Triple (Sold); Kawasaki Ninja 250 (Sold) Posts: 664
I did that on an R1 last month. It literally gave me vertigo. Like, something funky happened with my brain, and I got the roller coaster, stomach-up feeling. And when I just easily 'rolled on' through 1st gear on the next straight, the front wheel hovered in the air from like 30-80 mph. I hit 155 on a 3000' straight without trying.
I probably never need a liter bike, lol. |
October 11th, 2013, 07:06 PM | #32 |
Liter bikes are nuts!!!
November 11th, 2013, 04:38 AM | #33 | |
Last futzed with by SeanMarshall; November 12th, 2013 at 09:23 AM. |
November 11th, 2013, 05:12 AM | #34 |
Idk you can probly hook it to your solar panels, idk
January 23rd, 2014, 09:14 AM | #35 |
Ninja Parts Master
Join Date: Aug 2013 Motorcycle(s): 2011 Ducati Streetfighter 1098, 2014 Honda CB1100 Cafe, 2007 SV1000S, Quite a few 2008-2012 Ninja 250s Posts: 366
Add me on Instagram: @d_jalb Or follow me on eBay: PartsNinja |
[motorcycle-usa.com] - Gettysburg Bike Week Gears Up For 14th Year | Ninjette Newsbot | Motorcycling News | 0 | March 2nd, 2015 11:23 PM |
How the gears of your bike were made | Motofool | Videos | 13 | July 17th, 2014 07:08 AM |
My bike sorta has 12 gears. | arnoldc6 | 2008 - 2012 Ninja 250R Tech Talk | 7 | October 10th, 2013 03:42 AM |
What's up with my bike? Dropping gears | Trailerboy531 | 2008 - 2012 Ninja 250R Tech Talk | 15 | June 25th, 2011 12:06 PM |
[topix.net] - Charity Bike Ride Gears Up For Good Cause | Ninjette Newsbot | Motorcycling News | 0 | August 7th, 2010 08:30 PM |
