Old June 23rd, 2015, 04:32 PM   #1
jhey42.1
Motorcycle(s): 2007 Ninja 250R
Hello, from Asheville.
https://www.facebook.com/photo.php?f...type=1&theater
Hello Everyone!
I have just purchased a 2007 Ninja with only 1,400 miles on it for the unbelievable price of 500 dollars! This is my second one. The first was a 2000 model and I loved it. Bought that one new.
Anyway I am well aware that there is no such thing as a "free" bike. That being said I have strong suspicions that this is a theft recovery. It is on it's second engine, there are two keys, ignition key is different. Has an oil leak, needs a turn signal replaced, the brake pedal appears to be pointing at the sky, the brake light is always on. right rear body panel is held on with zip ties, seat latch return springs are gone, and tail light cover is also missing.
THAT is what I noticed so far.
Still it has good bones and runs, so this will be a fun project bike.
Last futzed with by jhey42.1; June 23rd, 2015 at 08:11 PM. Reason: add image
jhey42.1 is offline   Reply With Quote
Old June 23rd, 2015, 04:48 PM   #2
"A"
vampire
Motorcycle(s): 2 many 2 list
Nice score! Can't see your pics though.
"A" is offline   Reply With Quote
Old June 23rd, 2015, 04:52 PM   #3
snapshot
Fogwalker
snapshot's Avatar
Motorcycle(s): '09 Ninja 250 "Matilda"
Welcome, John! Sounds like you've acquired an excellent set of opportunities for personal growth.
Throw a rock in the French Broad for me. I should be back there by the end of summer.
Ride on,
J~
Take care of new riders, for we were them, and they will be us. Y. Hong 2004
snapshot is offline   Reply With Quote
Old June 23rd, 2015, 04:54 PM   #4
Welcome John!
5 bills!!!! Lucky dawg you....
Old June 23rd, 2015, 05:11 PM   #5
Ghostt
Ghostt's Avatar
Welcome, and I'm one for projects, my Ninjette was poorly maintained to say the least, but after some long hours, it's now better than, so good luck, and there's always hope,
Back in May 2014, I picked up a 98 with 27k miles on it for a great price. The P.O. did nothing except put gas in it, and changed the oil, I think, he did this for about 20k of the total miles.
Needless to say it needed a lot of TLC. I am no stranger to rebuilding bikes, I did my 91 EX500 which was a basket case for sure to say the least, here is the link to see that build:
https://picasaweb.google.com/1006527...JCB6ffS-973wgE
With that said I went through the bike, repairing, replacing, & modifying as I went, with the exception of the engine/transmission that seems solid no noises or smoke.
Here is a link to the evolution as told by pictures.
https://picasaweb.google.com/1006527...IDXyZXyoe2m0QE
Work performed :
Cut and set sag front fork springs(springs from a Ninja 500 1st generation, rate is .85kg/mm )
Replace fork oil 15wt synthetic
Install new fork seals and dust caps
Replace rear shock(zx600c)
Replace shock oil 15wt synthetic
Change gears +1/-2 (15/43)
Rebuild/tune carbs, adjust idle mixture
K&N air filter
New brake pads F&R EBC extreme HH
New Wave front rotor
Used OEM rear rotor
Modified OEM seat(gel/foam insert, Custom Seat Creation cover solo line cf silver/cf metal, heated kit
Extra heavy bar stainless steel ends(3"/23oz)
Heated grips w/ foam covers
Touring windscreen(7 JuRock 18" 73%tint w/flip)
Shorter bar risers(ZX600c lower bars about 1 1/2")
Removed paint from rims, bare aluminum
Bridgestone BT-45s w/ Dynabeads
Stainless steel allen head fasteners
Stainless steel braided brake lines
Shorty adjustable levers
HD clutch springs
Charge/voltage LED indicator
LED clock
HID headlight(55w 6k)
Replaced all other bulbs with CREE LEDs
DIY integrated tail light kit w/clear lens
DIY rear fender elimination
DIY licence plate mount(LEDs to illuminate the plate/red LEDs tied into brake light)
Brake light modulator
Maintenance free gel battery
Compact air horn
2007 Complete OEM fairing set silver
Genuine imitation carbon fiber wrap misc parts
Reflective custom graphics ZX-2R silver
Reflective custom graphic NINJA red(taillight lens)
Reflective rim tape silver
Electronic turn indicator relay
Replace front side reflectors with flush mount turn indicators LEDs
Installed rearview camera system
Installed oil cooler
Strip paint off grab handle, bare aluminum alloy.*
Custom reflective graphic "SERENITY" for windscreen silver
Aluminum chain guard from Suzuki Bandit 1200
Swing arm plugs from 08 Ninja 250
Mad Hornets Turn Signal Indicators w/duel color Cree LEDs(amber/white)
FH010 R/R modification
Digital gear indicator
Carbon Fiber wrap miscellaneous parts
Installed Universal Rear View Side Mirror Rain Board Sun Visor Shade Shield, genuine imitation carbon fiber wrap with non- visible clear coat applied.
All this and full maintenance and rebuild everything else except the motor. I'm sure I'm forget some stuff, but you get the idea.
SERENITY now has 33k + miles, so I've put 6k on it with no problems whatsoever, all is well.
violente et ignorantia
ZX-2R BLOG
Old June 23rd, 2015, 06:34 PM   #6
verboten1
verboten1's Avatar
MOTM - June '15
Welcome! You haave some great roads down there!
Ride more, worry less.
Old June 23rd, 2015, 06:39 PM   #7
snot
sammich maker
snot's Avatar
MOTM - Apr '15
welcome
Old June 23rd, 2015, 07:09 PM   #8
The Red Scourge
The Red Scourge's Avatar
Motorcycle(s): '76 Yamaha RD400, '71 Kawasaki G3SS, '88 Honda CBR400RR, '90 Yamaha FZR400/600 hybrid
Welcome! I'm in Asheville too! We should ride sometime when it's roadworthy.
"When in doubt, gas it!"
The Red Scourge is offline   Reply With Quote
Old June 23rd, 2015, 08:13 PM   #9
jhey42.1
It runs now
It is road worthy now. Here is a link to a pic. https://www.facebook.com/photo.php?f...type=1&theater
Old June 23rd, 2015, 09:57 PM   #10
KJohnson21
KJohnson21's Avatar
Motorcycle(s): '08 Kawasaki EX250 "Yoshi", '99 Kawasaki Concours "Grace", '06 Concours "Belle", '06 Yamaha YZF600R "Slick"
HEY!! Unregistered!! Does your bike have a name?
KJohnson21 is offline   Reply With Quote
Old June 23rd, 2015, 10:25 PM   #11
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
Welcome! It's a steal at $500!!! Good luck with it. Hopefully there won't be too many gremlins.
Riding it like I financed it.
Old June 23rd, 2015, 10:28 PM   #12
TnNinjaGirl
Ms. Personality
TnNinjaGirl's Avatar
Welcome! It's good to have another person nearish
Old June 24th, 2015, 05:04 AM   #13
DEFY
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
DEFY's Avatar
Welcome!!!
Spoiler for topic:
It might just be the [you] tag
Old June 26th, 2015, 07:21 PM   #14
Snake
Snake's Avatar
Hello and welcome.
WNC/Asheville area riders The Red Scourge Group Rides and Local Events 13 May 1st, 2016 06:44 AM
Blue Ridge Parkway - Asheville, NC salcuta88 Pictures 7 July 16th, 2014 07:33 AM
Bike Night at MR Motorcycle -Asheville, NC DaBlue1 Ride Reports 4 August 5th, 2012 07:28 PM
2008 250 Ninja for sale - Asheville, NC bikeguy57 Motorcycle-related 8 May 18th, 2011 12:00 AM
Newbie, Asheville NC area gamma500 New Members 17 August 25th, 2009 07:22 AM
