Old June 10th, 2012, 07:25 PM   #1
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
Help identifying bolts
I have two bolts left over from putting the bike back together that have me baffled. I believe they go on either the front fairing or bracket as that is the pile they were in.
They are the same as the regular fairing bolts but without the plastic washers on them. Can't find them in the service manual.
Old June 10th, 2012, 07:33 PM   #2
Boom King
So, where's the reverse?
Boom King's Avatar
Sounds like they are the ones from the inner side of the fairings. Go through the DIY and see if you missed anything.
Old June 10th, 2012, 08:33 PM   #3
Yea, sounds like the ones that are recessed, right behind the front wheel.
Old June 11th, 2012, 12:22 AM   #4
weight savings. leave em off
Old June 11th, 2012, 02:57 AM   #5
psych0hans
psych0hans's Avatar
Yep, those are the only ones without washers...
Old June 11th, 2012, 03:55 AM   #6
sharky nrk
sharky nrk's Avatar
Exact same fasteners as the ones that hold the lower part of the radiator shroud in place but they are not those as I have them in and accounted for.
Old June 11th, 2012, 09:02 AM   #7
Make sure the ones you installed don't have the nylon washer because then we know they belong elsewhere and these belong there.
Old June 11th, 2012, 10:18 AM   #8
sharky nrk
sharky nrk's Avatar
positive they don't and never did, all nylon equipped fasteners accounted for and in place. Anywhere else on the bike these things may go? I mean the entire bike was disassembled so they could go anywhere but I was pretty careful keeping like part assemblies together and in baggies.
Old June 11th, 2012, 11:04 AM   #9
The two by the seat lock have metal washers. Do the two installed in your shroud have metal washers?
Old June 11th, 2012, 12:49 PM   #10
dubojr1
dubojr1's Avatar
What about the ones just behind the rear-sets that hold the left and right tail fairings to the under-tail. Are they supposed to have washers?
Old June 11th, 2012, 01:07 PM   #11
sharky nrk
sharky nrk's Avatar
The ones by the seat lock have metal bushings and are in the correct location, the ones on the undertail flat are short and have nylon washers. They are freakin mystery fasteners
Old June 11th, 2012, 02:54 PM   #12
dubojr1
dubojr1's Avatar
Did you remove the air box?
Old June 11th, 2012, 05:20 PM   #13
sharky nrk
sharky nrk's Avatar
I did remove the airbox, can't remember if there were fasteners like these in there, anyone know?
Old June 11th, 2012, 08:06 PM   #14
dubojr1
dubojr1's Avatar
I'm pretty sure there is one on each side.
Old June 12th, 2012, 03:45 AM   #15
sharky nrk
sharky nrk's Avatar
Time to pull the service manual back out and see if I can tell, thanks.
Old June 12th, 2012, 04:49 AM   #16
dubojr1
dubojr1's Avatar
Look here: http://www.ninjette.org/forums/showthread.php?t=11899
I'm thinking the screws he speaks of in step #7. A bit blurry in the pic however...
Old June 12th, 2012, 11:34 AM   #17
sharky nrk
sharky nrk's Avatar
I will look, I think I put those back in already as they were for the splash guard not the airbox but will definately look when I get home.
Old June 12th, 2012, 11:37 AM   #18
dubojr1
dubojr1's Avatar
If I remember correctly they serve 2 purposes and the 2nd is to secure the airbox. Either way let me know. This one had me puzzled and I was mentally disassembling the bike piece by piece trying to figure out where they came from. LOL
Old June 13th, 2012, 04:28 AM   #19
sharky nrk
sharky nrk's Avatar
Found them, or at least I am pretty sure I did. They are on the backside of the front fairing, above and to the outside of the lower fairing stay mount.
Old June 13th, 2012, 04:30 AM   #20
dubojr1
dubojr1's Avatar
2009 Ninja 250R: Need help identifying this part RecklessWabbit 2008 - 2012 Ninja 250R Tech Talk 14 March 24th, 2014 11:38 PM
Help identifying turn signal brand? Also, need help soldering. sirlayon 2008 - 2012 Ninja 250R Tech Talk 8 August 7th, 2012 11:29 PM
Need help identifying carburetor gunk and removing pilot Monkeytofu 1986 - 2007 Ninja 250R Tech Talk 15 August 4th, 2012 07:45 PM
Need help identifying a back protector!!! MKlein3004 Motorcycle Gear 3 April 25th, 2012 02:44 PM
Any dog identifying experts out there? pilotgeorge747 Off-Topic 42 April 16th, 2012 04:10 AM
