April 3rd, 2015, 04:40 PM | #41 |
Captain 2 Sexy
Join Date: Apr 2014 Motorcycle(s): Kwaka EX250 Posts: 241
April 3rd, 2015, 07:58 PM | #42 |
I'm crazy,your excuse is?
Shock is around $30 at ebay.
April 4th, 2015, 12:07 PM | #43 |
Captain 2 Sexy
April 4th, 2015, 12:12 PM | #44 |
Captain 2 Sexy
Carb Sync
http://faq.ninja250.org/wiki/How_do_...carburetors%3F
I did use the above method. I had the tank off for access so I used a turkey blaster to keep the carbs full of fuel. I wound up turning up my idle to just over 1500 rpm. The engine seems to like that better. Notes on the sync: 1. The next time I do this I will mount the tank above the frame and lump the tank to the carbs. This will be rather easy to do with hose barb nipples and allow me to take my own sweet time to get things just right. 2. Have plenty of fuel and take your own sweet time. If you think this will be a short and cute process for your first time think again. 3. Learn how your engine is supposed to sound while idling, make tiny adjustments, and then let it run a minute or two. Keep the fuel coming. 4. I found that 1/32nd or 1/64th adjustments worked well for me and this bike. Seriously. Last futzed with by N-m; April 14th, 2015 at 03:12 PM. |
April 4th, 2015, 12:13 PM | #45 |
Captain 2 Sexy
Chain & Sprockets.
I have ordered a Motion Pro chain tool set, an RK O-ring or X-Ring chain and new steel JT sprockets in the factory spec'ed 14/45 combo. I decided too many variables are already changing to switch the numbers up or down. I am dying to see how well it runs after all this stuff is operating as it should be.
Last futzed with by N-m; April 14th, 2015 at 03:15 PM. |
April 4th, 2015, 12:14 PM | #46 |
Captain 2 Sexy
Spark Plugs.
http://faq.ninja250.org/wiki/Changin...rands_to_avoid
I have changed out the NGK plugs for the same. Both plugs looked good with no fouling. Neither plug was seized. I currently own 4 engines that take some type of NGK plug. At subaruoutback.org we have discussed the torque and no grease vs. no torque and grease method at length. I have ran these plugs for quite a few miles and can only recommend one follow the NGK approved method. Ideally this is a cold engine, clean the area as best you can so there is no soot or dirt, use their crush washer, use no grease or anti seize and use a torque wrench. I have zero issues with this method. I think people are throwing plugs in a hot engine, over torquing and then leaving the things alone for a long time. I can see this resulting in a plug that does not want to turn loose. Take the time to do it right and you have not only installed the plugs properly, you have eliminated a few possible causes of a bike not running in tip top shape. Of course, you are more than welcome to set fire to your own bike if you so desire. It makes no difference to me. Last futzed with by N-m; April 8th, 2015 at 03:44 AM. |
April 4th, 2015, 01:24 PM | #47 |
A NewGen shock has a spring more suited to your weight, and should be a direct bolt-in. It will raise the rear a tad, which will make the steering a bit quicker. Most people prefer it (it makes it feel a bit sportier), but just be aware when you get back on that it will handle a little differently. I'm sure the GSXR shock is better, but it also requires more work to install. I've had a Penske to install on my 500 for over a year, but I've been happy enough with the NewGen shock that I haven't done it yet.
You need ~76% stiffer fork springs. Probably .75kg/mm, maybe .70kg/mm, should be good for you. It sounds backwards, but the firmer springs will do a much better job of controlling the wheels under the bike, resulting in a more comfortable ride. Intiminators will help tame bumps too, but they're more expensive and more work to put in. Definitely do the springs first.
April 5th, 2015, 05:30 AM | #48 |
Captain 2 Sexy
Cylinders 1 & 2.
Traditionally this bike when cold begins getting hot on head number 1 first, and then head number 2. Initially I thought I was running on a single cylinder but that is not the case. i have what I feel is a very strong engine.
Exhaust numbers 1 & 2 both have similar levels of power or compression and after the bike warms up both heads and exhausts feel like they are the same temperature. The replaced plugs had equal appearances. Yesterday I finished with the valve adjustment, carb sync, and spark plug replacement. There were numerous issues corrected with these procedures in valve clearances and there was no synchronization. 1. Is this indicative of a real issue or normal for a multicylinder bike. 2. If an issue will it be gone this morning? 3. If an issue is this being caused by something else? |
April 5th, 2015, 05:35 AM | #49 | |
Captain 2 Sexy
I know fork oil weight options are 5, 10 and 15. What type, etc.? I have more reading to do about that yet. |
April 5th, 2015, 05:51 AM | #50 | |
Captain 2 Sexy
Front Suspension
Answers to all my questions. Especially note the below since I saw someone around here say they are riding on 5 weight. I had thought 5 weight was the factory spec but I will have to look at that again.
04/14/15 - I found some 15 weight oil and will change that and the level to begin with. Pulled forks from bike and have them completely apart. Fairly easy job, just time consuming. Oil in each leg was drastically different in viscosity, color and volume. Imagine that. Replacements for all the consumables are being ordered. Last futzed with by N-m; April 14th, 2015 at 03:19 PM. |
April 5th, 2015, 05:44 PM | #51 | |||
Especially if your forks are stock and need to be removed to drain the old oil, a spring change is much easier to do. You basically just remove the bar riser, pop the fork cap off, pull out the old spring, and drop in the new one. They do cost more than a bottle of oil though. If you can afford them, just get the new springs. If you up the fork oil to add a bunch of damping to compensate for weak springs, you'll have to undo that and re-determine proper settings once you get the right springs anyway. I installed ~55% stiffer fork springs, which were still a bit low for my weight, without changing the oil or anything else in my suspension. It was the single best change I've made to the bike. Seriously, these little Ninjas have insanely undersprung forks, especially for us big guys.
April 6th, 2015, 05:11 PM | #52 |
Captain 2 Sexy
A Short Ride.
Wow. Jump into your bike and make these adjustments. It definitely runs better. There is a smoother/easier start up although I do have to use about 50% choke where I was using about 25% before. Once warmed up the rpm gauge will still bounce around periodically but the range of motion is much less.
Vibrations - talk about a subjective topic. In the lower gears I was running a much higher RPM than usual, even using more of the higher range of first gear. Could it be described as a broader range of power in each gear? Decrease in RPM - I have similar power at a slightly lower RPM. When I hit the four lane with a limit of 65 I was using fifth at only 8,000. Throttle performance - By far the largest improvement. Changes to the throttle resulted in a faster response on the part of the engine both up and down. Shifting - am I just getting better at shifting or were up shifts smoother and a downshift into first at a higher RPM not as jolting? Tank is nearly empty so that is next. Then the entire front end comes off. There are some loud squeaks up there. Probably about that same time the chain and sprockets will have to go. I think the chain has had it. It now stays bent when you pinch the links. |
April 6th, 2015, 05:16 PM | #53 |
Captain 2 Sexy
Wrench on that Bike.
I don't care what you know or how much money you have, do something with your bike mechanically. If you don't have the times or tools find the time and someone that would be willing to help with your endeavor.
This will help you become more intimate with your machine and it definitely makes a difference in the confidence you have as you ride. I absolutely love tearing it all apart, getting it back together w/o any bolts left over and then hitting that starter, only to have her fire right up once gas is back in the carbs. If you are around here let me know if you need help. I will make the time. |
April 6th, 2015, 05:21 PM | #54 | |
Captain 2 Sexy
Ex250F forks 2006 | xbox3bob | Items Wanted | 1 | July 26th, 2011 01:23 PM |
