Old April 24th, 2015, 03:19 PM   #1
johncrist1988
johncrist1988's Avatar
Motorcycle(s): 2006 EX250-F "Sheldon" (Sold), 2010 Ninja 250R "Zeke"
New Biker, New EX250-F, and a video!
Hey there everyone!
My name is John and I'm both a new biker and a new EX250-F owner. I'm 27 and biking is something I've wanted to do for a while. My primary motivation for getting my EX250-F dealt with the fact that my job is 6 miles away and I can save a lot in gas and insurance by using a bike as my daily driver. Secondarily, it's just been a dream of mine to master bike riding at some point in my life. I'll always be a student, but what better time than now in my life to start riding.
I did post a YouTube video detailing my first little bit of ownership. I purchased the bike used for $700 from a friend of mine who upgraded to a '15 650 ABS. I took my permit test (I work at the MVD here in Avondale, AZ) and brought the bike in for and possible inspections and for title transfer and registration, and because I could. I had been practicing a whole day prior (which wasn't 100% smart) and felt confident about taking it to and from work.
Unfortunately, on the way home I took a turn at an intersection a little too hard and put the bike down at around 20mph. The damage wasn't major but enough that I lost the left side fairing, chipped up my upper fairing and windscreen, gauge cluster and lost a turn signal and headlight glass.
In the video I start working on the bike and getting her patched up. My MSF is scheduled for next weekend and I'm looking forward to it!
Last futzed with by johncrist1988; April 24th, 2015 at 06:40 PM.
johncrist1988 is offline   Reply With Quote
Old April 24th, 2015, 03:23 PM   #2
Welcome John!
Old April 24th, 2015, 03:51 PM   #3
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
Sorry to hear you went down. Went in too hot and hit the front brakes?
Riding it like I financed it.
Old April 24th, 2015, 03:52 PM   #4
johncrist1988
Exactly, I freaked and pulled the front brake, wobbled out and went down. I feel like I went down pretty soft, all things considered.
Old April 24th, 2015, 04:02 PM   #5
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
At least it's an old bike. So no worries...and you'll learn a lot while wrenching on it.
You'll have a lot of fun at the MSF. Enjoy!
Old April 24th, 2015, 05:04 PM   #6
johncrist1988
Absolutely. There's a lot I want to do to it right off the bat as just general maintenance things (or at least I feel are general maintenance things).
- Flush the cooling system (doing that tomorrow)
- New tires (bought the Kenda K671s front and back, now I just need to find a place to get them mounted when they come in)
- New brake pads, rotors are smooth so now worries there
- Clean the carb
- Soak the chain for a night to clean it, then lube it up
- Valve adjustment
- Cam chain maintenance, although I don't know exactly what that entails yet.
Long term I'm looking at finishing the upper fairing repair and repainting it a baby blue. I'd love to look into finding an analogue to digital converter for the speedometer and designing an interface for an Android tablet to run a full digital setup.
Old April 24th, 2015, 05:46 PM   #7
johncrist1988
I posted here about a click I'm hearing, with an attached video. Not sure what it is, but it's what's mostly leading me to want to look at a timing chain adjustment in my prior post.
Old April 24th, 2015, 06:29 PM   #8
allanoue
allanoue's Avatar
MOTM - Sep '14
Welcome John
[YOUTUBE ]zPdiX_5Ls6I[/YOUTUBE]
quote me to see how to post vid
Old April 24th, 2015, 06:39 PM   #9
johncrist1988
Thanks! Hopefully now I'll stop breaking things :P
Old April 24th, 2015, 08:53 PM   #10
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
- Clean the carb
- Valve adjustment
Coolant is easy (at least for the 08 & up bikes. I've never had a pregen). But for the 08 bikes, there's a drain plug on the left side of the bike by the shifter. You just loosen that plug and coolant will come rushing out (and I'm not kidding when I say rushing out). After that, just empty the plastic reservoir on the right side of the bike. Then fill up the radiator with new coolant. I just go for the normal green stuff. I mix it 50/50 with distilled water (not tap water). Just make sure whatever coolant you get, it is compatible with aluminum radiators.
Brake pads are pretty easy as well. There's a DIY somewhere on this site. And I'm sure you can find some youtube vids as well. If you're going to work on the pads, I think you may actually need to take off the rear wheel (it was for the 300). Once you get the wheels off, just carry them into the shop with the new tires. Much less expensive that way when you mount new tires (vs riding the bike in).
For the chain, make sure you clean it with something that's O-ring safe. I'm pretty sure all motorcycle specific chain cleaners are O-ring safe. But it can be costly. What I use is kerosene. It is O-ring safe and works better than most aerosol motorcycle specific chain cleaner in my opinion. The crap just melts right off with kerosene. Just make sure you're not smoking or near any flames when using it.
Valves - I've never attempted. But looks complicated. Shims involved. I'm just not as patient! But good luck! There's a DIY written up as well if you do some searching on the site.
Carbs - I don't know about the pregens. But the 08 bikes are a bitch to work on just because it's frustrating taking them off the bike with the stock airbox in place. But there are plenty of DIYs on carbs as well.
Enjoyu getting to know your bike! Take your time. Have fun wrenching!
Old April 25th, 2015, 01:53 AM   #11
Hello and welcome.
Old April 25th, 2015, 05:52 AM   #12
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Welcome.
Old April 25th, 2015, 07:20 AM   #13
Suki2003
Ninjette Lurker
Motorcycle(s): 2003 Ninja EX250 (Cafe, Naked, Wreckurrected)
Welcome.
I dont think anyone mentioned it yet,
That extra cable in the video you are confused about: it's a extra clutch cable the previous owner must have added incase the current clutch cable breaks while riding.
you would disconnect the broken line on the bike and attach the 2 ends on the extra cable up to the lever and transmission down below.
Hope that all makes sense!
Suki2003 is offline   Reply With Quote
Old May 4th, 2015, 10:41 PM   #14
KJohnson21
KJohnson21's Avatar
Motorcycle(s): '08 Kawasaki EX250 "Yoshi", '99 Kawasaki Concours "Grace", '06 Concours "Belle", '06 Yamaha YZF600R "Slick"
HEY!! Unregistered!! Does your bike have a name?
KJohnson21 is offline   Reply With Quote
Old May 5th, 2015, 04:06 AM   #15
cbinker
cbinker's Avatar
TEAM ALFALFA
www.apexassassins.com
Old May 5th, 2015, 06:16 AM   #16
johncrist1988
Originally Posted by Suki2003 View Post
Welcome.
Oh sweet, thank you I had no idea, though that makes perfect sense.
Old May 5th, 2015, 11:40 AM   #17
RitzykicksHQ
RitzykicksHQ's Avatar
Motorcycle(s): 11 Ninja 250R se
welcomeee
A little rebellion now and then ... is a medicine necessary for the sound health of government.
-Thomas Jefferson
RitzykicksHQ is offline   Reply With Quote
[visordown.com] - Video Not your stereotypical biker gang Ninjette Newsbot Motorcycling News 0 July 8th, 2014 04:50 AM
[visordown.com] - Video biker gang cuts off street in Manhattan Ninjette Newsbot Motorcycling News 0 January 16th, 2014 03:00 PM
The Ultimate Biker Dance Video! ;P 808yewtube Videos 2 March 9th, 2013 06:58 PM
[visordown.com] - VIDEO: Speeding biker identified by his kit Ninjette Newsbot Motorcycling News 0 October 1st, 2008 06:20 AM
[visordown.com] - VIDEO: Police footage of 140mph biker Ninjette Newsbot Motorcycling News 0 September 30th, 2008 02:57 PM
