Old May 19th, 2012, 02:37 PM   #1
sleepless
Motorcycle(s): '11 250 SE
2011 SE going to pieces
On purpose
Just picked up this 2011 a week ago and its already in pieces in my garage. It had 900 miles when I bought it and I got a solid deal. Only problem is, the owner decided all those factory recommendations were bullshit and NEVER CHANGED THE OIL..
Hopefully, the damage isn't too severe. I've got a new filter and some 20W-50 oil (preparing for that Texas heat) that I'll put in before it goes a another mile.
Spent entirely too much ordering mods already just to get it to where I like it. My room:
Hooked up the new LED turn signals, installed a new flasher relay and a couple of diodes, and rewired the integrated taillight that was already there. (Had to remove the old bulb that the previous owner had simply wrapped in wax paper and electrical tape and left in-line ) Also redid the diy fender elimination to remove the plate light. Still need to pickup some LED bolts..
Also finished the shogun crash kit install. I had to pick up a torque wrench and some larger hex key socket wrench bits to finish the install, but that just means my tool kit is bigger!
There seem to be a half dozen different kawi ninja forums, but the wiki here and some of the diy tutorials really helped on all the installs. I appreciate all the hard work people have already done to make my life easier, so I figured I should join and show the results! You guys rock
sleepless is offline   Reply With Quote
Old May 19th, 2012, 03:03 PM   #2
cuz
cuz
cuz's Avatar
Motorcycle(s): 09 ninja 250r
Welcome to the 250 party.
FYI u spelled Houston wrong idk if you did it on purpose
THE GOOD LIFE
cuz is offline   Reply With Quote
Old May 20th, 2012, 02:14 PM   #3
Snake
Snake's Avatar
Hello and welcome.
Old May 21st, 2012, 12:25 PM   #4
sleepless
Thanks guys. Changed the oil yesterday - it was black! With a few shiny bits of metal flakes at the bottom.
Not what I wanted to see, but I expected it. At least it's got fresh dino oil in it now!
Old May 21st, 2012, 12:57 PM   #5
EthioKnight
Super Noob
EthioKnight's Avatar
Motorcycle(s): '09 Kawasaki Ninja 250R, '84 Honda Spree 50cc
Welcome aboard! Kudos to you for doing all that needs to be done yourself. As long as you have the bike stripped, check your coolant levels and flush and refill as needed. If you're not itching to hit the road, I'd also recommend shimming your needles for a much better performance (just one more step - remove gas tank ).Good luck and happy trails.
EthioKnight is offline   Reply With Quote
Old June 1st, 2012, 08:58 PM   #6
KJohnson21
KJohnson21's Avatar
Motorcycle(s): '08 Kawasaki EX250 "Yoshi", '99 Kawasaki Concours "Grace", '06 Concours "Belle", '06 Yamaha YZF600R "Slick"
HEY!! Unregistered!! Does your bike have a name?
KJohnson21 is offline   Reply With Quote
Old June 13th, 2012, 11:45 AM   #7
sleepless
Proton Install
Extended wires, added oem connectors, and have since added a bead of black silicon sealant to protect the fairing paint.
per Momaru's great diy: http://www.ninjette.org/forums/showthread.php?t=36477
Last futzed with by sleepless; June 13th, 2012 at 01:26 PM.
Old June 13th, 2012, 12:24 PM   #8
sleepless
License Plate LEDs (after fender elimination)
Picked up on Amazon, for ~$18: http://www.amazon.com/Bright-Black-L...cmu_pg__header
Out of the box:
Rigged up some y-connectors with ~3 inches of 22 gauge wire and two female quick-disconnect bullet connectors on each:
Installed into license plate. This required slightly enlarging the holes in the license plate AND the bracket:
Pulled the wires up through a hole in the tail (for extra protection against the elements):
LEDs connected to Y-splitters and Y-splitters permanently soldered to original plate light wires: (The blue taps are for my always-on red LED strips under the tail)
Done!
This way, the quick disconnect bullet connectors allow me to take the license plate off without cutting anything if I ever need to.
Last futzed with by sleepless; June 13th, 2012 at 02:14 PM.
Old June 13th, 2012, 01:04 PM   #9
sleepless
Fairing Repair
The previous owner dropped my baby
Time to do some work!
I used this DIY as a guide: http://faq.ninja250.org/wiki/Plastic...ith_ABS_cement
Tools required:
ABS Cement (http://www.amazon.com/gp/product/B00...ls_o06_s00_i00)
Spare ABS Plastic - 12" X 12" X 1/8" (http://www.amazon.com/gp/product/B00...ls_o01_s00_i00)
Soldering iron (and hopefully extra tips, as this one will be useless afterwards)
Dremel (not shown)
Dremel/sand the paint out of the cracked area. I had to chop a good bit off as it was warped outwards. Create a shallow V to later fill in with ABS cement:
Backside can be much rougher where no one will see:
Cut spare ABS to shape of chunk missing:
Weld the cracks closed and the spare ABS to the fairing with the soldering iron, being careful not to get things too hot:
"Run the hot iron down the length ... with your finger on the [other] side, moving gingerly up and down the surface. The idea is to keep the feeler fingertip from getting too hot... If your finger can't take the heat, neither can the paint."
Backside:
Here, I did some minimal sanding to reduce the surface roughness. Then use the ABS cement in a well-ventilated area to finishing healing the wound.
In the future - painting! Maybe..
Old June 13th, 2012, 01:25 PM   #10
sleepless
Brake Light Flasher Install (No cut)
Safety mods FTW!
37 Mode Flasher sourced for the bargain price of $20 here: http://www.3rdbrakeflasher.com/index...baee5c39c0c6f5
I had prepared myself to weatherproof the circuit board somehow, but was pleasantly surprised to discover it was already 100% covered! I'm very impressed with the tight tolerances on whatever coating they used - they even covered the connections to the wires. Nice.
This is the OEM connector for the taillight we plug into (Taillight side to the right, battery power side to the left):
Attached some OEM connectors, following the included wiring diagram (*This is the correct wiring configuration. Red = power in, Yellow = power out, Green = through-wire for running lights, Black = ground):
Check the internal LED to make sure the power and ground are hooked up:
Installed! I also bundled and wrapped the white 'change-mode' wires in electrical tape after settling on my desired flasher pattern. The tail is becoming very full with wiring and connectors. Still neatly organized, more or less..
*IMPORTANT
The RED wire is NOT the power wire for the taillight. The BLUE/BLACK wire IS. The red wire is for the "running lights" in the taillight that are dimly light at all times. I had this wrong when I first hooked it up. Luckily, with the aid of a small eyeglasses screwdriver, it is easy to reorder the tines in the connectors. It is not as easy if you decide to hardwire
Old June 13th, 2012, 01:29 PM   #11
sleepless
I'm throwing all the mods I've been doing into this thread. Most of these have been covered on the forums, but if anyone finds these useful and wants further explanation/pictures, just ask.
Old June 13th, 2012, 01:39 PM   #12
sleepless
ModMy250 LED Rear Turn Signals
Rear turn signals installed in stock locations:
Plug and play!
Rear LED turns + Integrated taillight + LED Plate lights + Proton connection test:
LEDs FOR EVERYONE!
Old June 13th, 2012, 02:09 PM   #13
sleepless
Integrated LED Turn Signal Mirrors Install
Picked up a pair of integrated mirrors from the2wheels for ~$40: http://shop.the2wheels.com/Integrate...-085B-pair.htm
Upon arrival from Hong Kong. Actually pretty quick shipping, considering the distance:
This diy was a nice resource: http://www.ninjette.org/forums/showthread.php?t=77788
Remove your front fairing and headlight assembly to access the mirrors. Headless
The hexnut you need to loosen to remove the stock mirror from its base is hidden under a felt pad:
Integrated mirror assembly:
Stock mirror assembly:
If you notice, the base and rubber boot that comes with the "universal" integrated mirror is huge and unsightly. It extends way beyond the bolt holes. No way I'm installing that beast on my sleek machine!
Additionally, the stock base feels like a hardened steel alloy vs the plastic integrated mirror base.
In order to reuse the stock base and not have to fit the "universal" base, we'll need to remove both bases from their mirrors and slim down the integrated mirror attachment point.
The stock mirror attachment point is skinnier than the integrated attachment point:
I used the dremel w/ sanding attachment to slowly shave off layers of plastic, checking regularly for fit:
Reusing the stock hardware - two washers, lock washer, nut, and bolt - test fit the integrated mirrors to the bike:
From the front (not necessarily angled correctly):
TO BE CONTINUED...
Still have to reinstall the front fairing / headlights and find a way to route the power wire. I really don't want to put more holes in the fairings, so I'm considering just routing it underneath the wind shield and down. Hmmm..
Old June 13th, 2012, 05:37 PM   #14
Countersteer
Countersteer's Avatar
Motorcycle(s): <2008 250R> Past Bikes:06 GSXR600 89 CBR1000 78 Hawk 400 86 Ninja 600R 86 & 87 FZ600 81 GPZ550 71 CB360T
Hey, Sleepless! Looks like you're well on your way making that thing your own! I was looking through your posts and thought you might be able to help me out. I'm looking for a newgen mirror to attempt an integrated turn signal self install and am hoping to find an unwanted donor to experiment on. Here is the thread I created just the other day trying to find one;
http://www.ninjette.org/forums/showthread.php?t=106238
Anyway, if you think you could help me out let me know. I really just need the mirror part to determine how to integrate a turn signal into it.
Thanks!
Have you ever read the King James Bible?
To say speed kills is akin to saying guns kill, neither of which is true.
Countersteer is offline   Reply With Quote
Old June 20th, 2012, 10:54 PM   #15
sleepless
Replied
Last futzed with by sleepless; June 21st, 2012 at 08:16 AM.
Old June 20th, 2012, 10:55 PM   #16
sleepless
RE: Integrated LED Turn Signal Mirrors Install
TO BE CONTINUED...
Reattached to headlight fairing:
Extended the cable and added OEM male connector:
Old June 20th, 2012, 11:04 PM   #17
sleepless
Service Manual
Picked up the (500 page) Kawasaki Service Manual today for $6, wOOT!
Old June 21st, 2012, 06:43 PM   #18
Renner
Ignoring Jiggles
Renner's Avatar
Motorcycle(s): '09 Ninja 250R, '06 Ninja 250R (Sold)
Were did you find it for $6??
YouTube And Facebook
http://www.youtube.com/RennerVlogs
http://www.facebook.com/RennerVlogs
Renner is offline   Reply With Quote
Old June 21st, 2012, 09:26 PM   #19
sleepless
printer at work + FedexKinkos binding!
Old June 23rd, 2012, 06:09 PM   #20
sleepless
Now with 9000% MOAR BRIGHTNESS!
Upgraded the Shoei with 3M Scotchlite Reflective Tape:
Old June 23rd, 2012, 07:20 PM   #21
tsdexter
Motorcycle(s): 2008 Ninja 250R - Kawi Green
Originally Posted by sleepless View Post
That's awesome dude, love the squared off skull and cross bones on the back
tsdexter is offline   Reply With Quote
Old June 23rd, 2012, 07:39 PM   #22
sousuke86
sousuke86's Avatar
Motorcycle(s): 2011 Ninja 250R SE
Do you have red LEDs behind the license plate too? thats a lot of red light onto the wheel. awesome
sousuke86 is offline   Reply With Quote
Old June 24th, 2012, 10:49 AM   #23
sleepless
Yep. Two strips of red LEDs under the tail. I've been thinking about turning them into 3 strips - two to blink as turn signals and one always-on... but I already have 4 sets of turn signals so that may be a bit overkill
Old June 25th, 2012, 02:08 PM   #24
Stingray1000
Stingray1000's Avatar
Motorcycle(s): 2003 Kawasaki Ninja 250R
Welcome!
http://www.facebook.com/groups/DeMdNjPagrouprides/
I live my life a quarter mile at a time!
Who is affraid of the big bad jiggles???? LOL
Stingray1000 is offline   Reply With Quote
Need help finding these pieces !!! Jsc561 Items Wanted 3 October 16th, 2013 03:49 PM
