Old December 11th, 2015, 03:47 PM   #1
HoneyBadgerRy
HoneyBadgerRy's Avatar
Trail Tech Vapor and the stock Speedo Cable
Obviously when installing the trailtech vapor you don't need the stock speedo anymore, but as I recall the stock speed cable was used as a wheel spacer. What did you guys do about the absence of a wheel spacer? Or am I remembering this incorrectly and the speed cable can be completely removed and the from wheel stay in place.
Old December 11th, 2015, 08:22 PM   #2
Yamahawk
Chaplain
Yamahawk's Avatar
Motorcycle(s): 75 RD350 race bike, 82 XZ550RJ Vision, 81 XV920RH, 89 VTR250 Interceptor race bike, 06 Concours, 86 EX250E1
Ryan,
The cable unscrews from each end, one from the instrument cluster, the other from the speedometer drive that mounts on the wheel. You can leave the speedometer drive installed as the spacer, and just use the TrailTech magnetic bolt in the rotor. Then mount the TrailTech cable on your fork leg, at the proper spot to pick up the magnet pulse. Read the instructions carefully, and make sure the mounting doesn't interfere with the wheel or rotor/bolts.
Charlie
God chose what the world thinks foolish to shame the wise,what the world thinks as weak to shame the strong,what is despised in the world,what is nothing,to set aside what is regarded as something
Yamahawk is offline   Reply With Quote
Old December 11th, 2015, 08:24 PM   #3
Old December 11th, 2015, 08:27 PM   #4
Yamahawk
Chaplain
Yamahawk's Avatar
I <3 Morgan Freeman! He was being interviewed by Morley Safer I think, from 60 minutes.... hehe he was so cool!
Old December 11th, 2015, 08:30 PM   #5
HoneyBadgerRy
Although I can do that, it looks tacky, and I'm going to take the drive off. If anybody had actually made a proper spacer its easier to copy then to reinvent the wheel, but I don't want to leave the drive.
Last futzed with by HoneyBadgerRy; December 12th, 2015 at 07:40 AM.
Old December 12th, 2015, 03:23 AM   #6
MrAtom
MOTM - July '15
Take off the part and take it to a machine shop telling them that you want just a plain spacer. I don't think anyone else has had a problem with it just being there, so this is almost surely your best option, and I don't think it'll be cheap.
Old December 13th, 2015, 07:23 PM   #7
Yamahawk
Chaplain
Yamahawk's Avatar
An alternative to a high $$ machining job, would be to remove the knurled nut at the bottom of your speedo cable (which you're not using anymore) and re-install it on those 'tacky' threads that you don't like. Then it is a little more elegant, AND you don't have that unsightly cable down there either! I personally think I would leave it alone, and find a way to seal off the end, with the knurled nut, and a small disk of plastic inside it to act as a cap. Then no water can get in there to give you problems. Just my 2 cents worth
Old February 2nd, 2016, 08:20 AM   #8
UFOmoplata
UFOmoplata's Avatar
Motorcycle(s): 2007 Hoodrat 250
Off tangent here:
How would one swap out to a Vapor while retaining the front fairing?
It seems like the stock cluster is involved with mounting the fairing.
"Brah, you can't be looking like that on a 250, brah. You gotta mod a 250, brah. It's like the hachi-roku of bikes."
UFOmoplata is offline   Reply With Quote
Old February 2nd, 2016, 08:28 AM   #9
HoneyBadgerRy
Originally Posted by UFOmoplata View Post
Off tangent here:
It is not, the metal headlight bracket is, but you can take the stock gauges and replace them with the vapor for a clean finish.
Old February 2nd, 2016, 08:29 AM   #10
HoneyBadgerRy
I should mention for future people swapping to the trailtech vapor, a fellow forum member @DCMoney does make a aluminium spacer to replace the stock wheel spacer.
Old February 2nd, 2016, 08:33 AM   #11
UFOmoplata
UFOmoplata's Avatar
Muy excellente.
Do you know the weight difference?
Old February 2nd, 2016, 08:43 AM   #12
HoneyBadgerRy
Muy excellente.
I didn't measure it, but I would say its a couple pounds... Actually, I know in ninja250faq somewhere, they did measure the weight of the stock speedo and speedo cable. I didn't see it, but they mentioned that the speedo cable is .5 lbs. the actual gauges feel pretty hefty to me.
Old February 2nd, 2016, 09:16 AM   #13
UFOmoplata
UFOmoplata's Avatar
Yeah, I'd say it would take at least a couple lbs off the front end.
Old February 2nd, 2016, 09:39 AM   #14
HoneyBadgerRy
Couple lbs off, lower center of gravity, cleaner look, accurate speedo, clock, other goodies. It's a win win.
Old February 3rd, 2016, 05:10 PM   #15
VaFish
VaFish's Avatar
MOTM - Jan '16
Even more of a win if you are making a naked or cafe racer.
Which reminds me I need finish mine one of these days.
Ninja 250 Vapor Trail Tech skilletmo 2008 - 2012 Ninja 250R Tech Talk 35 October 1st, 2017 04:10 PM
Trail Tech Vapor MAZ 80 General Motorcycling Discussion 2 October 19th, 2015 04:10 AM
Trail Tech Vapor Review Kruse08 1986 - 2007 Ninja 250R Tech Talk 7 August 19th, 2014 02:55 AM
Trail Tech Vapor and mount rugbert 1986 - 2007 Ninja 250R Farkles 12 September 2nd, 2013 11:36 AM
Vapor Trail Tech Question/Help skilletmo 2008 - 2012 Ninja 250R Tech Talk 41 May 12th, 2013 02:40 PM
