Old June 21st, 2015, 12:02 PM   #1
Mike K
Mike K's Avatar
Motorcycle(s): 2014 Ninja 300 track bike, 2007 Suzuki GSXR 750 track bike, 2002 Yamaha R6, 1995 CBR600RR f3 track bike
Pre-Gen Track Bike Conversion Pics
So I did one track day and now I'm taking my 250 off the streets and making it a dedicated track day bike. This is what I've done so far:
Pirelli Diablo scooter tires
Lithium Ion light weight battery
Galfer front and rear coated stainlness steel braided teflon brake lines
Motul 600 brake fluid
EBC HH pads front and rear
Headlight removed (have to fabricate a block off plate to replace the headlight)
Directional signals removed
Brake light disconnected
Oil and filter changed, screen cleaned
Woodcraft rearsets
Woodcraft lowered risers
Muzzy exhaust (already on bike when I bought it)
Track, track, track
Mike K is offline   Reply With Quote
Old June 21st, 2015, 12:05 PM   #2
Hero Danny
Inline 4!!!
Hero Danny's Avatar
Nice!
Be careful. Remember you are
invisible
Old July 7th, 2015, 02:06 PM   #3
Mike K
Mike K's Avatar
I installed the folding levers today. It took about 30 to do and test. They seem to be of good quality and went in easily. I also removed the gauge cluster housing to give more room for handlebars and levers at full lock.
I need to find something to cover the hole left when I removed the head light.
Track, track, track
Old July 8th, 2015, 06:55 AM   #4
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
looks good
Old July 8th, 2015, 08:13 AM   #5
trident
Motorcycle(s): 1999 Ninja 250
Nice! Looking good
Just wanted to say thank you for posting the pre-gen stuff. Got myself a '99 not too long ago that came with a ton of spares & I'm looking to get it on track in the near future as well. I am a total beginner when it comes to this stuff and having your pictures to reference, etc. is great.
trident is offline   Reply With Quote
Old July 8th, 2015, 08:16 AM   #6
Welcome Trident!
Where in KY are you? If you're close to me, I can give ya lots of help along the way. Heck, maybe even catch a ride with me to the track.
Old July 8th, 2015, 08:17 AM   #7
Nice work Mike!
Old July 8th, 2015, 08:45 AM   #8
trident
Thanks Chris!
oh, I'm way down in the western part of KY near Kentucky Lake....big metropolitan area, hehe. I really, really appreciate the offer of help as I'm almost surely gonna need some to get this ball rolling. My initial thoughts were to have this thing ready for WERA @ NCM in August but I'm pretty certain they pulled it off the calendar.
sorry Mike K, not meaning to threadjack
Old July 8th, 2015, 04:05 PM   #9
oh!! also, if it's purely a track bike:
- ditch the radiator fan
- ditch the rear pegs
- strip down the wiring harness (will take some serious time)
- ditch the ignition, replace with resistor. Not sure of resistance value, check on wiring diagram, it says there.
- ditch left hand controls. ain'y nobody got time for that.
- ditch rear grab handle
- take off tail light
- ditch horn
- emulators/intiminators
any other quick ones I missed?
Old July 8th, 2015, 11:00 PM   #10
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
Old July 12th, 2015, 06:37 PM   #11
Mike K
Mike K's Avatar
Love the changes to the Ninja!! I did a track day with TPM at Millville, NJ. Awesome day.
Track, track, track
Old July 12th, 2015, 08:12 PM   #12
Hey, something you might be interested in. I finally had some time to play with my brakes and get them bedded well. I recently switched to a Ninja 650 master. It's a 5/8" cylinder instead of a 1/2". The size is marked on the unit. Identical externally to the 250 MC, mounts the same, uses the same fittings and hoses, even uses the same lever. It's a straight swap.
Makes the brake lever more firm, but the brakes have some ass on them with not nearly as much effort as before. So if you get comfortable braking and find yourself squeezing the lever way further than you like, to the point of cramping your hand up like I did and/or bottoming out the lever, make the Ninja 650 MC swap. It's cheap and easy and two finger braking is finally possible for me, finesse on the lever is still easy as well.
Old July 13th, 2015, 04:46 AM   #13
Mike K
Mike K's Avatar
I'll check that out. I'm doing two-finger braking now. I actually started doing it on the GSX R750 because the throttle spring is so light that just correcting hand position or hitting a bump would burp the throttle. I keep two fingers on the brake to stabilize my wrist. On the track I've only used brake to ease strain on the engine when I do clutchless down shifts. We ran Lightning in reverse yesterday. After the first lap I was using only 5th and 6th gear.
Track, track, track
Old July 22nd, 2015, 09:19 PM   #14
Mike K
Mike K's Avatar
I did more work on the Ninja the other day to make it faster. I painted it red, got it to make 100hp, and put some R6 stickers on it.
Tee hee
Track, track, track
Old October 19th, 2015, 07:32 PM   #15
Harpman28
Motorcycle(s): 2004 ex250, vfr800, klr650, drz400s
Thanks for the pics and thread. They really helped me get my bike together this year.
Harpman28 is offline   Reply With Quote
Old October 19th, 2015, 07:34 PM   #16
Nice D! And welcome!
Old October 20th, 2015, 05:26 AM   #17
Digging the RAM mount for a camera on the mirror base. Never thought about that. but you don't need the mirrors anyway, do you!??!!
Old October 20th, 2015, 04:59 PM   #18
Harpman28
No mirrors anymore but a surprisingly stable mount for the gopro.
Old October 23rd, 2015, 06:38 AM   #19
AchyGrappler
Motorbike Obsessed
AchyGrappler's Avatar
Motorcycle(s): 2004 Kawasaki EX250, 2004 Yamaha FZ1, 2006 Honda CRF 450 Flat Track Race Bike
Nice, I'll be checking back with this thread to steal some ideas. I love seeing examples of the rear sets and lowered risers and I will be going with them when the time comes.
For the front number plate check here http://www.airtech-streamlining.com/...2501988-06.htm
What are you doing for a belly pan? I just finished up one for my race ninja that I fashioned out of a cake pan mounted up to the stock lower fairing mounts.
My race Ninja build and more motorcycle content. My Motorbike Obsessions
AchyGrappler is offline   Reply With Quote
Old October 23rd, 2015, 07:38 AM   #20
xXecuterXx2
ChocolateMilk Addict
xXecuterXx2's Avatar
Motorcycle(s): '05 EX-250 "Kallie" 85 KLT 110 ATC "Murdock"
Pics or it didn't happen
Burn Rubber, not your Soul.
xXecuterXx2 is offline   Reply With Quote
Old October 23rd, 2015, 12:23 PM   #21
AchyGrappler
Motorbike Obsessed
Sorry, usually only get time in the morning to post up stuff. Today I was rushing and blanked on how to get pics in my posts.
Here are the results (thread jack in progress)
Old October 23rd, 2015, 09:20 PM   #22
^^^^ GTFOtta here....
That is the most pro install of a turkey pan I have ever seen.
2005 Pre-Gen Ninja 250 Track/Race Bike - $1350 OBO stimpee Motorcycle-related 0 February 10th, 2015 07:39 PM
Pre Gen vs New Gen for a track bike Rollingmenace Ninjettes At Speed 17 October 5th, 2013 09:14 PM
Clean black/green pre gen (many pics) A7xschecter6661 Pictures 15 August 19th, 2011 12:06 AM
Does anyone have pics of a Pre-Gen without the front fender? Zim Pictures 8 March 4th, 2011 11:44 AM
HID Conversion for Pre-Gen on Ebay/Link.. cnichols79us 1986 - 2007 Ninja 250R Tech Talk 4 March 13th, 2010 07:25 PM
