Old March 16th, 2014, 08:58 PM   #201
So you're adjusting values in the throttle vs fuel table. And that throttle vs fuel map is being run through the ecu's programming. In order to deliver the fuel mixture you want, it's also considering other variables like engine parameters and atmospheric conditions (some listed above). There's more than one table of numbers that your ecu is functioning off of. There's actually lots of them. It's a computerized control system running a real life thing. The thing (engine in this case) and environment has to be defined by equations and tables and sensors and lots of data.
Go read a little about control systems and how different types of inputs affect system response. Not only is there a physical side to throttle response (the engine physically revving up), there's an electrical side (control system response). To speed up the overall response, the control system response can be improved or slowed by adjusting the input.
But we're really OT here. We're getting into control systems in a thread about Yamaha
Old March 16th, 2014, 10:37 PM   #202
mania
mania's Avatar
Motorcycle(s): 2013 250
Yes I guess OT but its all good.
Maybe someone will open another thread & discuss this?
I find all of these things interesting & even if not available on the Ninja 250/300? I would be interested in reading more about such systems
Of course I am aware of the system I tinker heavily with as previously mentioned & also aware of ignition advance systems
but would be interesting reading about these other electrical response systems you mentioned.
Thanks
mania is offline   Reply With Quote
Old March 17th, 2014, 05:06 AM   #203
Google "control systems". There's entire textbooks written on controls. Its 2 semesters worth of classes for most engineers.
Yes, any fuel injected bike is run by a control system. That's what I'm telling you. Ecu is the controller. There's inputs and outputs. There's a control system running the anti locks. There's a control system running the cruise control in your car.
Old March 17th, 2014, 06:53 PM   #204
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
@Whiskey, here I have some links for you where you can see that it's possible to reduce the power down to at least 13 kw (18 hp) - its all in German, maybe use a translator.
http://www.alphatechnik.de/produkte/...gen/25-kw.html
http://www.alphatechnik.de/produkte/...-kw-48-ps.html
http://www.alphatechnik.de/produkte/...n/7072-kw.html
@mania - maybe this is interesting for you: http://ecuhacking.activeboard.com/t5...-reflash-done/
and here's the software for it: http://www.evc.de/en/download/down_winols.asp - download the manual and take a look how it's done, you can see it's all in Hexdump, so not easy to understand and the price for the software is 30,000 Euro.
Old March 17th, 2014, 07:21 PM   #205
mania
mania's Avatar
Thanks! Very interesting & Nice specific site as I see he has done my bike.
Old March 18th, 2014, 06:39 AM   #206
Whiskey
[MENTIO117]Whiskey, here I have some links for you where you can see that it's possible to reduce the power down to at least 13 kw (18 hp) - its all in German, maybe use a translator.
Technically it's possible, legally it's not. You would need the full A licence to ride one even at 13 bhp, as the stock bike makes over double the A2's power limit.
A learner can't start with the restricted supersport after the new laws were introduced.
I know one mechanic that dialed a FJR or Busa (I don't remember which) down to 33bhp by FI washers & a throttle stop... It had 1.4mm throttle movement.
The new laws eliminate that kind of nonsense.
@mania Europe got FI bikes from the start. My 08 is FI, it's down to other EU laws on emissions
Old March 18th, 2014, 09:55 AM   #207
akima
Nooblet
akima's Avatar
MOTM - Oct '13
Do you mean mm? Or cm? If you mean mm... that's frickin' mental! What if you sneezed while riding that thing?
Old March 18th, 2014, 03:49 PM   #208
Xtina
Xtina's Avatar
Motorcycle(s): 2013 Ninja 300, 2007 Gsxr 600, R6-sold :(
New R3 revealed in as little as a week.
http://global.yamaha-motor.com/showr.../teaser_en.php
Xtina is offline   Reply With Quote
Old March 18th, 2014, 04:32 PM   #209
Whiskey
millimetres. one point four millimetres, looked it up on the other forum, it was an R1 & after the owner's licence expired (10 year licence in ROI), it had to be renewed within 5 or back to the drawing board, the bloke forgot about it completely.
Apparently same was done on a 05 fireblade, valves on the throttle bodies barely move.
Old March 18th, 2014, 07:13 PM   #210
Somchai
Freedom for Germany
Do I have to understand this as you're thinking you stand above the german law?
Old March 18th, 2014, 07:18 PM   #211
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
most people break laws at some point or another anyway.
Old March 18th, 2014, 10:35 PM   #212
ninja250r81
ninja250r81's Avatar
Motorcycle(s): 2012 ninja 250r se
Originally Posted by Aufitt View Post
In Oz we have LAMS,
basically 150kw/tonne including 90kg rider and limit of 660cc.
So all the cbr250rr, zxr, fzr etc are included along with the 400's and boring heavy restricted 600's & 650's
Excludes RGV, NSR TZR 250 which were allowed under the old 250 system that LAMS replaced.
Europe has the 125's , that's why the manufacturers make them.
Because of lams we get the 390's and a lot of other small bikes that come downunder.
Stops noobs buying 600 & 1000cc supersports for the first year an the associated carnage.
Im with Aufitt.
My view, a perfect all round bike with highway capable, around town, and can beat 600's with the right rider etc is the ZXR400.
http://en.wikipedia.org/wiki/Kawasaki_ZXR400
If the YZF-R125 is $6999 aud
http://www.bikesales.com.au/showroom...0237FD5&Nne=15
If the yamaha went on sale in aussie it would be around 10k - 12k aud
Not at all affordable for the learner rider
ninja250r81 is offline   Reply With Quote
Old March 19th, 2014, 03:13 AM   #213
Aufitt
The A Team
Aufitt's Avatar
Motorcycle(s): Z50, CB125, RZ500, MC22, R3.
The 250/300 is much lower spec than the 2014 125.
It will be cheaper, but hopefully better than the 20 year old Ninja commuter design)
Aufitt is offline   Reply With Quote
Old March 19th, 2014, 06:08 AM   #214
sidekick10121
Motorcycle(s): 250 ex
Another r25/3 post haha
http://www.indiancarsbikes.in/auto-n...ch-25th-86994/
According to this the countdown clock is getting close to 0 an it's supposed to be the release of the two in India an the USA.
My question is regarding design (being new to
Motorcycles)
Why would the 300 be a one cylinder and the 250 be a two cylinder design. Does the dual offer more performance and higher torque? And do they use a single to keep over heads down hence a lower msrp?
sidekick10121 is offline   Reply With Quote
Old March 19th, 2014, 06:19 AM   #215
GHill762
GHill762's Avatar
Motorcycle(s): ZX-3R (ok, ex300)
any speculation at this point is just that - speculation..
I personally doubt yam will put a single cylinder in a 300, but we'll see.. we don't know for sure yet they are even making an r3..
my guess is that the 250 and 300 will be identical other than CCs, longer stroke or bigger bore 250 for the markets that aren't restricted to 249cc.. that way they can compete with kawasaki and still get into markets with cc restrictions..
and it's possible it won't matter at all to us in the US because they've talked like they have no interest in bringing little bikes to the states..
GHill762 is offline   Reply With Quote
Old March 19th, 2014, 06:21 AM   #216
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
They answered your question in the article a bit but I'll go into it a bit more because why not.
I personally think that a parallel twin engine layout is the way yamaha should go with their 300 if they bring it stateside as a 250cc parallel twin is more fun than a 300cc thumper. However, it is a move that would make sense. A single cylinder engine costs less to make, is easier to service, makes more sense to a beginner rider, has more torque for everyday riding and with 300ccs honda has proven that a single cylinder engine does have adequate power (cbr300rr has roughly the same hp as the ninja 250 and more torque) despite losing out to the ninja 300 in power due to it's parallel twin layout. Furthermore single cylinders get better gas mileage, which is a huge reason for people to invest in a smaller cc bike with commuting in mind.
Hell what would blow everyone's mind is that off chance that the R3 turns out to be a triple engine! that would be pretty awesome even though it's probably not happening.
Old March 19th, 2014, 08:58 AM   #217
Ducati999
Motorcycle(s): Ducati 999 2012 Ninja 250r Ducati748 Yellow finally running 2003 SV650 S (SOLD)
What Sirref said Exactly! the only thing to add is the Tripple Cyl motor is the least likely configuration but he is right it would be incredible. 300cc single, 300cc twin and a 300cc triple= small cc buffett
Ducati999 is offline   Reply With Quote
Old March 19th, 2014, 09:15 AM   #218
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
I'd be tempted to trade in for the Yamaha if they did that...tempted
Old March 19th, 2014, 02:10 PM   #219
Whiskey
I don't get what you're asking.
Is English your main language?
It's an EU directive, think of it like a federal law, it superceeds national laws, and must be transcribed into each member state's law. It changed the law in my home country, the country I live in now, Germany's law & every one of the 27 EU states laws.
Technically it is possible to restrict the airflow, throttle movement, or fuel injector's map to reduce the power output of a 2014 GSXR600 from 92.5kW to 35kW (48 bhp).
To ride that bike legally anywhere in Europe (including in Germany) you must posses a full "A" class licence, you may not ride it on an "A2" class licence, which has the restriction of 35kW and can not be derived from a vehicle of more than double it's power. Both conditions must be met.
If you get a Gixxer 600, dial it down to 48 bhp & ride it on an A2 licence or learner's permit in Germany and happen to get pulled over for any reason the German police will impound the bike & leave you standing at the side of the road.
I have a full "A" class licence, I can ride whatever bike I like, completely legally, as long as it's insured.
If that's not clear to you please pick the specific point you do not understand, highlight it in BOLD and I will try to explain it to you another way.
If you've been out of the country for a few years you may not be aware of the new rules, they were changed in January 2013
Wikipedia link
Old March 19th, 2014, 02:43 PM   #220
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
The 650 is an ugly bike!!! It doesn't matter what you say, it's ugly
Old March 19th, 2014, 06:54 PM   #221
Somchai
Freedom for Germany
Wikipedia link
To answer your question, I'm German and I also have been working in the Automotive business, so I know about the rules and clearly understand what the German law is talking about and in this case you better forget about the EU-Dictatorship.
Many young german rider don't start with a small bike like the Ninja or others like this, because this would be a waste of money when they want to ride a bigger one after the 2 years of the A2-License, so they already get the big bike and mount the Kit to have 48 hp.
After the kit is mounted they have to go to the TUV to get this registered in the bikes documents and from this moment on this bike is a total legal 48 hp A2-Licensed bike.
After the two years they get the A-License, take off the kit, go to the TUV again to get the original power written back in the documents and have an i.e. 200 hp GSX-R1000 - this is the German way and never mind about the EU - THIS IS LEGAL.
Old March 19th, 2014, 10:03 PM   #222
Somchai - everything I'm seeing online contradicts your above posts. Are you sure your views are completely up to date? It may have used to work that way, but if Germany is using the A2 license structure, there is clear wording in what A2 means that does not allow the bike to be downtuned by more than half of its original power.
Old March 19th, 2014, 10:48 PM   #223
ChrisMKV
Motorcycle(s): 2010 Ninja 250, 2015 F800R
I was looking into the same topic some time ago, so I can perhaps provide some insight.
The EU law does state that for the A2 License, if the bike is more powerful than 35kw it must be restricted to 35kw. The restriction is not allowed to be more than 50% of the bike's total power. (So you cannot get an R1 and restrict it on A2).
There are two notable countries with exceptions to this law:
- France: All bikes are restricted to 106hp anyways (poor guys)
- Germany: In Germany, the 50% rule is not applied! meaning that R1 could theoretically be ridden on an A2 if successfully restricted to 35kw.
Source:
Die EU-Regelung, wonach das zu drosselnde Motorrad nicht um mehr als 50% gedrosselt werden darf, wird von Deutschland nicht umgesetzt. Somit ist die 35-kW-Drosselung auch gültig für Motorräder, die mit mehr als 70 kW angeboten werden.
http://www.adac.de/_mmm/pdf/neuer%20...0KB_161409.pdf
EDIT: However, there is also a max power-to-weight ratio so that R1 may after all not be possible.
ChrisMKV is offline   Reply With Quote
Old March 20th, 2014, 08:03 AM   #224
Whiskey
I'll take your word for it, but I've not seen a single English language source mentioning a German exception to the new licencing rules.
How many Panzer divisions on their way to Brussels did it take to get that exception
Old March 20th, 2014, 06:28 PM   #225
Somchai
Freedom for Germany
Thank you @Alex for reminding me that I'd stop on the half way with my description.
Special Thanks to @ChrisMKV for bringing up the link, here's another one: http://www.haensle.de/news/172
@Whiskey the Panzer is Merkel...
I don't know what country you're from, but please remember the language in the free country Germany is german and not english, so you must never find anything in english. That's why I'd ask you about your german knowledge. I also with my little english knowledge would not talk about american or british laws.
Old May 20th, 2014, 01:00 AM   #226
[visordown.com] - Production Yamaha R25 finally unveiled
YAMAHA has finally pulled the covers of the production version of the YZF-R25.
The quarter-litre sports bike makes 35.5hp and 16.7lbft from a parallel-twin 249cc engine.
It's got a steel frame and weighs 166kg.
It's just been unveiled in Indonesia, where Yamaha is billing it as the 'baby YZR-M1', after the factory's MotoGP bike.
The R25 was first unveiled as a concept with no lights at the Tokyo Motor Show in November, but this is the first time official images of a production version have been seen.
The Indonesian-built R25 will go on sale in Asia in July. A 300cc R3 version is expected to follow for Europe, although Yamaha is staying tight-lipped on the subject.
Over here it will go up against Kawasaki's Ninja 300 and Honda's forthcoming CBR300R, and on paper it looks competitive. Even without the extra 50cc, it's not far behind the Ninja 300, which makes 29hp and 19.9lbft.
Honda's CBR300, production of which has been postponed, makes a claimed 30.4hp with 19.9lbft.
The R25 will go on sale in Indonesia for 53million Rupiah (£2,756), slightly more than the local price of the CBR250R but less than the Ninja 250R.
Related Content
Yamaha YZF-R3 on the way
Production-ready Yamaha R25 spy shots
Better Yam R25 shots
Yamaha R25 spied?
Yamaha YZF-R25 launch date confirmed
Click here for full story...
Old May 20th, 2014, 06:28 AM   #227
SMman
SMman's Avatar
Motorcycle(s): 15 CBR300R, 14 BWS50, 09 FZ1, 09 Ninja 250, 06 CRF450R Motard, 03 ZX-6R
I am thinking about selling my Suzuki DR-Z400SM and was planning to get a KTM Duke 390, which never showed up in Canada this year like I hoped. I have been looking at some very cheap leftover 2013 CBR250Rs but this Yamaha has me second guessing the Honda purchase. Question still remains when it will make it to North America, but maybe it will be worth the wait.
15 CBR300R, 14 BWS50, 09 FZ1, 09 Ninja 250, 06 CRF450R Motard, 03 ZX-6R 636
SMman is offline   Reply With Quote
Old May 20th, 2014, 06:44 AM   #228
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
Hmm, I think Mom Kawasaki may have to drop her going rate for a 250/300.
My Cafe Racer Build
My intro post
Old May 20th, 2014, 07:17 AM   #229
SMman
SMman's Avatar
More info and pics here:
http://indianautosblog.com/2014/05/y...aunched-130723
Old May 20th, 2014, 07:23 AM   #230
WOOOOO!!! daddy needs a new small sporty motorcycle next summer. Let's get this R3 show on the road in the good 'ole USA.
Old May 20th, 2014, 07:24 AM   #231
psych0hans
psych0hans's Avatar
This should be a fun little bike... Don't much care for the front looks tho...
Old May 20th, 2014, 07:55 AM   #232
/merged a few R25 threads
Old May 20th, 2014, 08:20 AM   #233
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
35 hp from a 250 twin budget bike... ill believe it when i see it.
Even if numbers are legit it will be some what comparable to ninja300 output with less torque.
^this is where price points come into play for me.
Old May 20th, 2014, 08:21 AM   #234
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
mmm, I like it. looks aggressive enough to be mistaken for a bigger bike and it seems to be competitive in the class. I like how our quarter liter class is shaping up yamaha
@subxero there's also the suspension part of the equation, it was advertised before with high end suspension and braking bits but I don't really see those now. If I'm just blind then it's not a big deal but if it has comparative (albeit less) power than the N300 with better suspension and brakes out of the box then it will definitely be a great package.
Old May 20th, 2014, 08:23 AM   #235
I'm betting on that as the power at the crank, not the wheel. I'd bet the wheel's more like 29. Remember that asian dyno's are always hopeful.
Old May 20th, 2014, 08:25 AM   #236
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
I'd be willing to bet that it still has more power than the ninja 250 at the wheel
Old May 20th, 2014, 08:55 AM   #237
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
Too much power for me. Whoever needs that much HP is asking for trouble.
Old May 20th, 2014, 09:05 AM   #238
Jono
Jono's Avatar
I believe it. Just look at their specs for the WR250X.
Yamaha made their single cylinder pump out 27 HP and 16.7 Ft/lbs of torque. I have no doubts that they will not get close to 35.5 HP and 16.7 ft/lbs out of a "budget" parallel twin. And I'd be willing to bet it will have valve clearance checks every 20k-ish like their WR250R/X which is every 26,600 mi. I at least hope so!
Old May 20th, 2014, 09:28 AM   #239
crazymadbastard
I am pretty sure the starter motor on your bike has more hp/tq than our ninjettes.
My Cafe Racer Build
My intro post
Old May 20th, 2014, 09:39 AM   #240
psych0hans
psych0hans's Avatar
Am I the only one who's disappointed at how different it is from the prototype?
[visordown.com] - Yamaha R25 reaches almost 110mph Ninjette Newsbot Motorcycling News 0 June 20th, 2014 06:50 AM
[motorcycle.com] - 2015 Yamaha YZF-R25 Revealed for Indonesian Market Ninjette Newsbot Motorcycling News 0 May 20th, 2014 08:40 AM
[visordown.com] - Yamaha R25 spied Ninjette Newsbot Motorcycling News 0 April 28th, 2014 06:30 AM
[motorcyclistonline] - Concept: Yamaha R25 | Up To Speed Ninjette Newsbot Motorcycling News 0 March 4th, 2014 11:00 PM
[visordown.com] - Yamaha R25 revealed at last Ninjette Newsbot Motorcycling News 0 November 20th, 2013 02:20 AM
