June 16th, 2015, 10:49 AM | #1 |
2003 250EX lowering
Hi everyone. I was looking for a posting on lowering Ninjas and have found some. But would like some direct help if you could!
I just bought a 2003 Ninja 250EX and have been researching either getting lowering links or even different tires, to a different seat. My inseam is about 27.5 inches (4ft 10.5 inches tall). I have been referred to different sites such as roaringtoyz, saw soupys performance, etc. Any recommendations of what site to look at and the best options for me? Thank you everyone for your help! Phuong |
June 16th, 2015, 11:05 AM | #2 |
Welcome Phuong!
I am sure you know you're after lowering links, but just wanted to remind you of the front. Lowering the rear without making adjustments to the front is doable, but doesn't set up the bike for best results. Just a friendly reminder for your searches. Best!
June 16th, 2015, 11:09 AM | #3 |
Yup, I know I was told gotta do both - front and rear! =)
June 16th, 2015, 11:11 AM | #4 |
Nice! There are many riders here that have lowered their bike. I am sure they will be around shortly to comment their experience. Stay tuned!
June 16th, 2015, 12:27 PM | #5 |
Certified Troublemaker
I have used Roaring Toyz kits on both my newgen and my 300. The links (rear) and blocks (front) are great, i would highly recommend them if they make them for you bike, i don't know if the links are the same from the pregens to the newgens. Just not the lowered kickstand the make. Go with an adjustable one.
June 16th, 2015, 03:42 PM | #6 |
Join Date: Jun 2013 Motorcycle(s): N650 (and others) Posts: 408
I don't know about the Ninja for the next trick, but on some bikes you can swap the tires for slightly smaller ones, and gain a fraction of an inch. Every bit helps, I know. I'm all sorts of flat foot with my Ninja 250, but a 600 ate my lunch, combination of height and seat width pushing my legs out at an angle.
Oh yeah, and don't forget you may need to shorten the kickstand, and a center stand may be difficult to use or drag too early. |
June 22nd, 2015, 10:40 AM | #7 |
I called Roaring toyz and they only sell the lowering links for 2008 and newer models.
Called went to a few local shops in town and everything is on back order... I saw this on Ebay http://www.ebay.com/itm/Ninja-250-Lo...eb4894&vxp=mtr which is a bit confusing as I went to a local shop and they could only order 1 1/2 or 2 in links for me. Idk the adjustable seems sketchy to me so curious if anyone has heard or use them... Thanks |
June 22nd, 2015, 10:47 AM | #8 |
They should be fine as long as you adjust them the same. They look beefy enough. I really don't see any issue with them.
June 22nd, 2015, 08:53 PM | #9 |
You could shave the seat. Actually I know someone who got a 250 with a shaved seat and probably wants a normal seat. Could be an opportunity to trade.
June 23rd, 2015, 04:41 AM | #10 |
^^ That's a good thing to look into as well. I've had low seats on both my bikes with the lowering kit.
October 8th, 2017, 07:52 AM | #11 |
Join Date: Oct 2017 Motorcycle(s): 2007 Yamaha YZF600R (me), 2005 Kawasaki Ninja 250R (wife) Posts: 11
Sorry for resurrecting such an old thread but what did you end up doing here? I'm looking for the same for my wife's Ninja.
October 10th, 2017, 07:12 AM | #12 | |
Join Date: May 2012 Motorcycle(s): 1981 Honda CB125S, 2006 Ninja 250 Posts: 65
When I bought my 2006, it had been lowered but I didn't know it! Scraped the first time I went around a corner. (I had been very gentle when I went on a test drive.) That was a huge disappointment; I'd been riding a 1981 Honda CB125S; I buy a "sport bike" (with 2X the CC's), and apparently I have to be careful going around corners?! I immediately went back to the dealer I bought it from. The person who sold me the bike didn't know it had been lowered, but the person I asked about it when I went back did know. I was easy on them; I bought the links and side stand on Ebay, and got them to do the work of putting it back to original without charge. I found out the previous owner was a girl, had it lowered at 900 miles; I bought at 1040 miles. I guess she wasn't meant for riding. Only the back of mine was lowered. If someone feels uncomfortable without lowering the bike, I wonder about putting it back to normal after they get comfortable with it (providing of course they can at least reach on toes). Scraping in corners must be dangerous, and being that careful around corners defeats what riding is all about. I am not that aggressive a rider. I am about 5'81/2". As far as reaching the ground, I would rather be a bit higher! As others have said, the center stand becomes unusable; actually, since you don't need it except for servicing (like chain maintenance), you can either use an assistant to help lift it on the stand, or perhaps rolling the bike up on 2X4's would allow you to get it on the stand solo.
isuoboe |
October 10th, 2017, 07:35 AM | #13 | |
That said, I'm definitely looking for a shortening option if that fails. I've already got a front and rear stand from doing maintenance on my own bike so don't really see any value in the center stand anyways. My wife is actually pretty comfortable when she gets going.. the real concern is just stopping and getting the feet down, especially on a hill or anything of the sort where sure footing is a bit more important. If I do end up lowering the Ninjette.. I'll take many photos and share my experiences. Regardless.. expect to see details on how the seat height reduction goes! |
October 10th, 2017, 11:26 AM | #14 |
When shaving seat, taper the shave and remove A LOT from the front sides of where it narrows. Shave down to bare plastic really at edges. This makes front narrower and easier to straight-leg stand when stopped.
You can also lower front forks by taking out factory spacer above spring and cutting two sections off to reduce spring-preload. Slice off a 1/2" and a 1" section. Use hacksaw or thin cuttter to remove minimal amount of metal. Then you can mix-and-match the three pieces for 1/2" removed, or 1" or 1.5" removed. This will allow you to lower front-end 1/4", 1/2" or 3/4". You can add extra washer 92022B in between if ends of cut segments don't line up precisely. |
October 10th, 2017, 11:39 AM | #15 |
My daughter has to be careful at stops, particularly on a side slope where she has to remember to lean toward the uphill side. Irregular ground can be a problem too. But she has no trouble dragging the peg feelers on the Dragon, so she prefers to put up with the nuisance than reduce cornering clearance.
October 10th, 2017, 07:24 PM | #16 | |
October 10th, 2017, 07:27 PM | #17 | |
October 11th, 2017, 03:47 PM | #18 | |
Take it out of the fork, cut some rings off the end and put it back together. |
October 11th, 2017, 05:13 PM | #19 |
MOTM - Jan '16
I put a set like these on my daughters bike when she first started riding.
http://www.ebay.com/itm/ninja-250-lo...hZ1U7u&vxp=mtr We didn't drop the front at all. She was much more comfortable at stops, but quickly was scraping hard parts in sharp corners. When she upgraded to a Harley Sportster she wouldn't let me lower it even though she was on tip toes when she stopped. |
Pregen Exhaust 250EX | Ish | Items Wanted | 3 | March 25th, 2015 12:17 AM |
2010 Ninja 250EX | wyciwug | 2008 - 2012 Ninja 250R Tech Talk | 5 | October 6th, 2013 12:06 PM |
DIY: Lowering the back with Roaring Toyz lowering links | noche_caliente | 2008 - 2012 Ninja 250R Tech Talk | 49 | July 26th, 2010 12:22 PM |
