June 28th, 2013, 05:14 PM | #1 |
Join Date: Aug 2012 Motorcycle(s): '13 Ninja 300, '99 SV650 tracked Posts: 378
Dropped Bolt in Gas Tank? Major or Minor Issue?
I think I just dropped a bolt to the gas cap INTO the gas tank. I can't see it with a flashlight, and I don't have one of those magnet-thingies. . . .Should I be concerned, or just like when you eat dirt or your girlfriend's keys, do you just wait to sh*t it out again?
June 28th, 2013, 06:13 PM | #2 |
MOTM - Mar '13, Jun '14
Depends on what the bolt goes to. If it isn't a necessity you are fine. Just get a magnet when you can and get it out. If it is important, just turn the bike upside down an shake it until the bolt pops out.
If everything seems under control; you're just not going fast enough! Last futzed with by CC Cowboy; July 1st, 2013 at 01:32 PM. |
June 28th, 2013, 07:48 PM | #3 |
Join Date: Aug 2012 Motorcycle(s): 2007 Ninja 250 Posts: 181
Be sure to drain the gas firt.
Shhhhh, don't tell Jiggles I am using the [ you ] tag. |
June 28th, 2013, 08:14 PM | #4 | |
Join Date: Apr 2013 Motorcycle(s): 250/300 Posts: A lot.
Hey Unregistered never go faster than your brakes can be applied... |
June 29th, 2013, 06:48 AM | #5 |
What's that? A hot girl who hangs at gas stations?
You still have to turn the bike upside to see in the tank with a lighter.
June 29th, 2013, 02:44 PM | #6 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
Is it a big one or a little one? If its big you will be safe to wait till ya get a magnet thingy, if its small enough to get into the gas tube you won't blow it up, but you could screw yourself mid ride...
June 29th, 2013, 02:48 PM | #7 |
Join Date: Aug 2011 Motorcycle(s): 2009 Ninja 250r (Sold), 2009 FZ6, 2015 Honda Grom Posts: 898
Turn the bike upside down? The gas tank on the 250s (and hopefully 300s) are INCREDIBLY easy to remove. Just pull the gas line and drain the gas into a container first and the flip the tank over. Shouldn't take more than 30-45 minutes.
June 29th, 2013, 11:47 PM | #8 |
Simple kind of man
Join Date: Apr 2013 Motorcycle(s): 2013 Ninja 300 Posts: 133
IIRC, the pump has a filter on it so it won't make it into the pump.
It could short or damage the level sender. It could start to rust. As others have said, removing the tank is easy, siphon the fuel and turn the tank over.
June 30th, 2013, 12:13 AM | #9 |
Gear crash test dummy
Join Date: May 2011 Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r Posts: A lot.
Hahah people here will never understand CC Cowboy.
Joel - I'd just pull the tank off, remove the petcock and drain the gas and let the thing fall out. No use in having to worry about it.
CVMA #531 |
June 30th, 2013, 12:25 AM | #10 |
ninjette.org *********
Join Date: Jul 2011 Motorcycle(s): 2008 Kawasaki Ninja 250r (忍者 250r; sold!) 2001 zx6r Posts: 347
cycle gear sells led flachlights with retractable magnets that will work to be able to see inside of the tank, and grab the bolt(assuming that it is some sort of iron/steel alloy type bolt. if not, just do like cc cowboy said and flip the (empty) gas tank upside down and shake away until it plops out.
July 1st, 2013, 01:12 AM | #11 |
Simple kind of man
Unless he's referring to a bike not listed in his details then the 300 he has does not use a petcock. He would need to remove the fuel pump assembly if he's unable to fish it out through the cap.
July 1st, 2013, 11:18 AM | #12 |
Oh yeahhhhhhhhhhhhh.
Eh. Still easy to do. GET THAT BOLT
CVMA #531 |
July 1st, 2013, 11:55 AM | #13 | |
...........does he know how to swim?
July 1st, 2013, 11:59 AM | #14 |
Fast-Guy wannabe
MOTM - Jan '13
Just dump some coca cola in there and let it sit for a couple days. That stuff can dissolve a bolt no problem.
July 1st, 2013, 12:07 PM | #15 |
As long as the screw was clean shouldn't be a urgent issue, but you should get a magnet to get it out when you can.
July 1st, 2013, 12:20 PM | #16 |
if you leave it in there it will scratch away the inner coating and the tank will start rusting inside out
July 1st, 2013, 01:21 PM | #17 |
July 1st, 2013, 01:36 PM | #18 |
Join Date: Apr 2013 Motorcycle(s): 2013 Kawi Ninja 300 Posts: 109
This thread made me ROFL I must have a dirty mind
July 2nd, 2013, 01:34 AM | #19 |
Simple kind of man
Good luck with a magnet stick, it's going to be 'sticking' to the inner tank walls every time it gets close.
July 15th, 2013, 08:48 PM | #20 |
Thought I posted a follow-up, but I took the tank off last weekend, and the fuel pump, and rattled it out. Took about a 1/2 hr, no worries. I was just being lazy, I guess. Thanx for the input.
Gas Tank Lock stuck? Maintenance for gas cap with pics! | Skippii | 1986 - 2007 Ninja 250R Tech Talk | 35 | May 6th, 2021 09:03 PM |
Handle bar hits gas tank on left side after dropped | ruby1025 | 1986 - 2007 Ninja 250R Tech Talk | 6 | June 25th, 2014 08:34 AM |
gas tank pet cock issue!! help! | ac9im11 | 2008 - 2012 Ninja 250R Tech Talk | 8 | May 14th, 2014 08:41 AM |
93 EX250 ..Gas tank issue w/fairing bolt | rockstarcordova | 1986 - 2007 Ninja 250R Tech Talk | 6 | July 23rd, 2011 12:04 AM |
