July 21st, 2015, 12:17 PM | #1 |
semi naked/streetfighter build
So i finally got my bike looking good enough to post what I've done. This is my first bike, so I didn't have much in the way of know how when i started taking things apart. I don't have much in the way of tools, or a shop... or money...... or time, so this ended up taking almost a year with periods of not doing much. My bike is my daily driver, so I couldn't have it just sitting in my carport unless I wanted to beg for rides to work.
Let me know what you do or don't like, or if you have any suggestions. I'm 90% (more or less) finished. I want to work on the exhaust, but I'm not quite decided on what to do. In a few years i'll probably buy something bigger and turn this one into a track bike. These are the pics from before i did anything. I had more, but idk where they went.
I just keep taking it apart. I can't help myself! Last futzed with by RogerPapaMike; July 21st, 2015 at 03:43 PM. |
July 21st, 2015, 12:23 PM | #2 |
Starting to take it apart, still a bit of an ugly duckling. After I pulled some of the fairings off I went out and crashed it, so the right pipe is pretty banged up.
I just keep taking it apart. I can't help myself! |
July 21st, 2015, 12:31 PM | #3 |
Finishing up...
July 21st, 2015, 12:35 PM | #4 |
Had to move some of the guts around when I cut off to read fender, this is where I put them.
July 25th, 2015, 11:32 PM | #5 |
July 27th, 2015, 07:24 PM | #6 |
Join Date: Aug 2014 Motorcycle(s): 2007 Ninjette Posts: 809
Man it looks good!!
Have ye any more plans for it?
"That's what" -she |
August 7th, 2015, 10:44 AM | #7 |
Join Date: Aug 2015 Motorcycle(s): '06 250 Ninja, '15 DR200S Posts: 5
a question
So why did you end up keeping the front lower fairing on? Just preference or is there a mechanical reason? I've been toying with this idea myself and am just curious as to why you left it.
August 7th, 2015, 11:43 AM | #8 |
Daily Ninjette Rider
Join Date: Jul 2014 Motorcycle(s): 2012 Ninja 250R, 2015 Vespa GTS 300 IE Super, 1989 Honda Elite 80 (SOLD) Posts: 402
This looks great!
Check out my music at http://www.proteusmusic.com |
August 15th, 2015, 07:39 AM | #9 |
I just liked the way it looked, and I thought it might be a good place for new graphics.
August 15th, 2015, 07:44 AM | #10 |
Maybe a new color scheme. I live in az, so I was thinking white with kawi-green accents to keep the surface from getting super hot in the sun.
August 18th, 2015, 01:19 PM | #11 |
What headlights/bracket are you using?
August 19th, 2015, 05:11 PM | #12 |
Join Date: Jul 2015 Motorcycle(s): 07 Ninja 01 Sportster Posts: 56
What are the mirrors from?
August 20th, 2015, 06:59 PM | #13 |
which tailight too?
August 23rd, 2015, 03:06 PM | #14 |
These are the headlights, the brackets are from the same site. http://www.speedmotoco.com/mobile/Pr...de=hltwinblack
This is the tail light. It's not as bright as i would like though. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 The mirrors are also from amazon.https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
August 23rd, 2015, 03:29 PM | #15 |
Thanks.
Is the mirror glass flat or concave? |
August 23rd, 2015, 03:41 PM | #16 |
It's flat. Although the shape give it an adequate field of view.
August 23rd, 2015, 06:50 PM | #17 | |
EX500 full of EX250 parts
Join Date: Jul 2012 Motorcycle(s): '18 Ninja 400 '09 Ninja 500R (selling) '98 VFR800 (project) '85 Vulcan VN700 (sold) Posts: A lot.
It's probably not a bad idea to add a relay kit and just bypass the stock wiring completely if you're switching to dual lights like this. That will also have the benefit of reducing voltage drop, giving you more light output.
August 23rd, 2015, 06:58 PM | #18 |
That makes a lot of sense. I haven't done any of that. The light output is much better than stock, but the battery does die quickly if I accidentally leave the light on.
August 23rd, 2015, 07:47 PM | #19 | |
August 23rd, 2015, 08:16 PM | #20 |
I'm crazy,your excuse is?
Looking good!
I like the bug eye look. |
August 23rd, 2015, 08:42 PM | #21 | |
My signature
August 23rd, 2015, 08:57 PM | #22 | |
With the stock setup, power is actually fed to the headlight from the left control, which is fed from the fusebox, which is fed from the ignition switch. There are a lot of switches, connectors, and small wires in that circuit, which leads to a decent bit of loss by the time the power actually gets to the bulb. After installing a relay kit, that circuit only uses a tiny bit of power to trigger the relay, then the bulb gets power through a big dedicated power wire directly to the battery with only the relay inline. You get better power to the light, and less stress on the factory wiring (especially if you're installing a bigger/additional light).
Project T00Fiddy (Streetfighter/Naked build) | Turism0remix | 1986 - 2007 Ninja 250R Farkles | 19 | June 8th, 2015 01:27 PM |
Another 250 streetfighter build | cuong-nutz | 2008 - 2012 Ninja 250R Farkles | 19 | April 11th, 2015 08:58 PM |
Ninja 250 Streetfighter Build | Proteus | 2008 - 2012 Ninja 250R Tech Talk | 13 | April 2nd, 2015 09:41 AM |
My streetfighter build. | nickadolph | 2008 - 2012 Ninja 250R Farkles | 38 | September 28th, 2012 05:55 AM |
Ninja 250 naked / streetfighter | glenjamin1982 | General Motorcycling Discussion | 3 | May 20th, 2010 01:40 PM |
