Old June 9th, 2013, 09:36 AM   #1
Arrow E10 + water = gasoline + ?
http://www.mcnews.com/mcn/technical/2012DecEthanol.pdf
Old June 9th, 2013, 09:49 AM   #2
Joshorilla
Bass Master General
Joshorilla's Avatar
Ethanol is hydrophillic, petrol is hydrophobic, you can seperate the two quite easilly that way I guess by decanting the junk, if you went on the evaporate the ethanol from the water you'd have yourself some moon shine!
Old June 9th, 2013, 09:57 AM   #3
lgk
Im lucky enough to still be able to get pure gas from an airport nearby.
The bike runs a lot better with it, so does the lawnmower and weed eater.
Using phase separation to purify gasoline is genius.
A good way to get the octane back is to add toluene.
When add oxygenators then its gas+.
Ethanol pump gas is gas-.
Old June 9th, 2013, 10:18 AM   #4
Joshorilla
Bass Master General
Joshorilla's Avatar
It's all E5 here, which nobody seems to have a problem with.
I certainly don't mind E5
Since I am a boat owner I can buy duty free petrol and diesel for my "boat" which are both pure uncut dinosaur distillate jungle juice.
Old June 9th, 2013, 11:19 AM   #5
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
This is very cool and if I can figure out how to do it with 15 gals a shot it may be worth while. Do you think DOT will have a problem with me towing a 15gal VP racing can behind the Ninjette for a few miles so I don't have to use my truck?
I'd love to see some do a Dyno comparison between E10, race gas and pure gas using this method. Since you lose octane and we use 87 anyways we should be able to use 91 for this and avoid needing an octane booster right?
Old June 9th, 2013, 11:25 AM   #6
Snake
Snake's Avatar
All my vehicles and equipment now run terrible with E10. I hate to see what's going to happen when E15 comes out.
Old June 12th, 2013, 08:33 AM   #7
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Ok so I'm going to use an old plastic 5 gal gas can for this and I'm currently ordering all the nessisary parts to complete the rid. We're going to be running pure fuel this weekend. Ill be sure to post pics of what I end up with.
Old June 12th, 2013, 08:57 AM   #8
Panda
not an actual panda
So quick napkin math if you use E10 91 octane and you separate out the ethanol. Assuming ethanol has a 113 octane rating after separating you'd end up with an octane rating of 88.6.
Old June 12th, 2013, 09:00 AM   #9
Joshorilla
Bass Master General
Joshorilla's Avatar
You could mix the pure petrolium distilate with the e10 in a 50 / 50 blend to get a compromise of e5 which runs great in my ninja.
Old June 12th, 2013, 09:14 AM   #10
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Um where do you buy pure petrolium distilate?
Haha forget I asked this
Old June 12th, 2013, 09:19 AM   #11
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
And if I start with 89 ill end up with 86.3
I love math
Old June 12th, 2013, 09:31 AM   #12
Joshorilla
Bass Master General
Joshorilla's Avatar
Ha, no.
Petrolium being the stuff they get out the ground to make "gas", diesel, kerosene, all extracted by distillation.
Hence petroleum distilate, since the only petroleum distilate available to buy for automotive gas was what you'd call "gas" it got shortened to petrol, which is why british people say petrol, americans seem to like calling it gas, despite the fact that it isn't a gas, it's a liquid
Old June 12th, 2013, 09:40 AM   #13
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Motorcycle(s): All of them
Ha, no.
LOL
This post me made laugh.
Old June 13th, 2013, 03:01 PM   #14
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Ha, no.
I knew petrol is basically gasoline but I wasn't sure where to get pure petrol. Then I remembers this cool article discribing how to use water and pump gas to render pure petrol
Old June 13th, 2013, 03:16 PM   #15
Brother Michigan
Motorcycle(s): 2013 Ninja 300
http://pure-gas.org/
Ethanol-free gas listings!
Old June 13th, 2013, 03:49 PM   #16
lgk
I love math
You going to mix back some toluene?
Old June 13th, 2013, 04:11 PM   #17
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
I shouldn't have to since we run such low compression.
Old June 13th, 2013, 04:22 PM   #18
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
This is a 400cc test with 20cc of water added. So if the fuel really is E10 then I should end up with 60cc at the bottom of separation. After 10 minutes I've only got 45 so we'll see what it looks like in the morning.
Old June 15th, 2013, 01:33 PM   #19
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Alright so now I'm working with 4 gals of 91 from shell.
I added 1000cc of water shook it a lot, then an hour later I drained out 2200cc of water/ethanol mix. So you subtract the 1000cc of water and your left with 1200cc of ethanol. 1200cc of 4gals is 7.9%
I'd say that was a successful test, now I just have to find some dummy willing to pour this stuff into his tank
Old June 15th, 2013, 02:09 PM   #20
lgk
if i was closer i would try it, lol.
Old June 20th, 2013, 08:48 PM   #21
five10
five10's Avatar
Motorcycle(s): 2013 Ebony Ninja 300
What're the results of this?
-Need tips/have tips to give on buying a new bike? Visit my thread. Add your input! http://www.ninjette.org/forums/showthread.php?t=122975
five10 is offline   Reply With Quote
Old June 24th, 2013, 08:16 AM   #22
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Ok so I dumped in the 4 gals minus the 1200cc of removed ethanol I had made last week and went for a ride on Saturday. As expected there were no changes in performance and it just ran like normal. I didn't have enough fuel to top off the tank so I can't give you an MPG estimate but I will tell you I used every last drop I put in. When I filled the tank the next time on the ride I put in over 4.8 gals so I know I was on fumes. I'd be curious to see how much it change my jetting but without a dyno it'd be hard to messure.
If I was a weekend rider then I would give this a better shot and continue doing it since I could probably get away with one batch a month. But since I fill my bike of once or twice a week its just not worth it.
I read that there was talk about the new e-15 regulations may require a seperate E0-E10 pump just for motorcycles. If this is the case then maybe we could get E0 more readily available. My guess is we'd have to pay a premium price and I bet the best we'd get in CA would be E10
Old June 26th, 2013, 11:56 AM   #23
..........I read that there was talk about the new e-15 regulations may require a seperate E0-E10 pump just for motorcycles............
http://www.ninjette.org/forums/showt...676#post705676
Old June 27th, 2013, 10:36 AM   #24
lgk
i wonder if you could freeze concentrate the ethanol you extract from this
Old June 27th, 2013, 10:41 AM   #25
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Not sure but it seems to make a great base for moonshine so far
Old June 27th, 2013, 10:47 AM   #26
lgk
you drank it!!!1!11!
Old June 27th, 2013, 10:55 AM   #27
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Not strait
You have to distill it first
Old June 27th, 2013, 11:18 AM   #28
Lychee
sail away
Lychee's Avatar
Not strait
hilarious!
Old June 27th, 2013, 02:36 PM   #29
GlassAnkles
GlassAnkles's Avatar
Motorcycle(s): 02 zx-12r, 13 zx-10r abs
+1 this should be a sticky on ALL motorcycle forums.
GlassAnkles is offline   Reply With Quote
Old June 27th, 2013, 03:00 PM   #30
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Works for everywhere but Ca
Old June 29th, 2013, 09:25 PM   #31
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Pulled 1400cc of Ethanol out of 5 gals today which is 7.3%
I can't seem to get that last 2 or so % or maybe the E10 is slightly shy I'm going to do the whole process again tomorrow with the pure fuel I mad today and see if I can get even more out.
Also my new setup is much easier to use
Old June 29th, 2013, 09:41 PM   #32
lgk
At first i figured it could be 10% by weight, but it still doesnt add up.
Add 20% more water see what happens.
Old June 29th, 2013, 09:50 PM   #33
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
I'm already at adding 5% water which is more then double the recommended 2% but that's why I'll add 5% again tomorrow and see what happens.
Old June 29th, 2013, 10:21 PM   #34
lgk
If you cant extract any more,
im guessing either its just the blend of the distributor, or the moisture inside the gas station storage tank absorbed 2%.
Old June 30th, 2013, 06:11 AM   #35
The stickers at the pumps state: "Contains up to 10% Ethanol".
Old June 30th, 2013, 06:53 AM   #36
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
I'm aware it's up to 10% but I figure they would have that stuff dial in to within 1/2 a % if it's a way for them to make more money.
Also I've been looking the last couple weeks and can find anything on any of the pumps stating there is ethanol in the mix, maybe CA doesn't require labeling
Maybe I'm looking in the wrong place, someone take a picture of where the label is located please.
Old June 30th, 2013, 02:31 PM   #37
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
So I was able to get another 150cc out of the same 5 gals from yesterday so now that's 8.1% ethanol removed. I'm starting to think the mix needs to be agitated several times every few minutes at least a couple times to get full absorption and separation to happen. It's like the ethanol content in the petrol is not constant and unless the water directly comes in contact with it it won't seperate it. It seem total osmosis doesn't occur naturally.
Old June 30th, 2013, 06:28 PM   #38
Panda
not an actual panda
If you're judging percentage by volume it's not going to be completely accurate. When the water and ethanol mixes I think you are going to lose some volume. Also not sure this is an osmotic process.
Old February 3rd, 2015, 09:22 PM   #39
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
How is this working out? I've noticed if I leave out my lawnmower uncovered in the rain I have to drain the carb bowls to get it working again...
My Cafe Racer Build
My intro post
Old February 4th, 2015, 02:17 PM   #40
Bubba
Motorcycle(s): 300
In parts of Europe, bike shops are starting to sell drums of ethanol free gas, as all pump gas will have ethanol this year. It's really expensive.
old bikes and engines will get ruined with ethanol gas.
Bubba is offline   Reply With Quote
Choosing a Gas Additive for E10 Gasoline DaBlue1 General Motorcycling Discussion 12 April 19th, 2014 08:45 AM
[superbikeplanet.com] - As The Water Buffalo Turns: Suzuki Won't Dip Toe Into Water I Ninjette Newsbot Motorcycling News 0 September 10th, 2013 09:10 AM
[topix.net] - EPA Wants Seperate E10 Pumps at Stations Ninjette Newsbot Motorcycling News 0 February 13th, 2013 03:51 AM
Water lovely water rusninja Off-Topic 28 November 7th, 2012 02:02 PM
