Old November 7th, 2013, 01:30 PM   #1
Southeastjames
Guest
Posts: n/a
Unhappy My Ninja be dead, so I joined this forum!
Hey guys and gals. First to introduce myself. I'm in the Charlotte area, just south of the border actually in SC. Been riding since about '63 when I was but a wee lad on a Honda 55 Trail.
Big green sure made a nice little bike in the Ninjette. My wife got her MC license on it and I rode the thing a lot motor pacing and SAG support for bikes.
Well, I killed it dead. Did a long run on the interstate at shall we say, 'elevated' speeds and that was that. Nice long run on the interstate, then pulled off and did some stop and go traffic. Rode it through my neighborhood, pulled into my driveway. I put it in neutral, turned off the key. No indications of any problems. I opened the garage door and went to start it and it wouldn't turn over, just a click. Whatever, I pushed it in the garage.
Couple days later I come out to see what was up. Something seized up. It will go into 1st, but I can't get the wheel to turn. It won't go into second. Pushing it back and forth in first to try to get it to go into second does nothing.
That was maybe 2 years ago. I figured oh well, now it's a project bike. But really, I don't know what to do with it. Fix it, part it out, sell it as is... What do you think?
Old November 7th, 2013, 01:37 PM   #2
the first problem was caused by a dead battery or a blown VRR that wasn't charging the battery.
the not going into 2nd is by design, its called the kawi "positive neutral finder". the transmission output shaft has to be spinning in order to push the ball bearings inside toward the outside of the shaft to "unlock" from neutral to slide over into 2nd gear... this means the wheel has to be going like 5 mph to get into second, or you have to be really lucky.
and when its cold it can definitely be a bitch to move even with the clutch in.
now after sitting for 2 years, the gas is bad and it needs the carbs and fuel lines cleaned
Old November 7th, 2013, 01:39 PM   #3
Welcome James!
Have you tried turning it via the front sprocket nut? Maybe it's just the starter. Check the kickstand switch too, jump the wires to bypass.
Old November 7th, 2013, 01:41 PM   #4
I am making an assumption that you had oil in it the entire time. Another chap just lost his engine due to a leak at pace. Hope you fair better.
Old November 7th, 2013, 03:35 PM   #5
TonyKZ1
TonyKZ1's Avatar
Motorcycle(s): 1975 Kawasaki KZ400D (Sold), 1989 Kawasaki Ninja 250 (sold), 1997 Yamaha XJ600s Seca II
Welcome to the Site, James.
Tony
1997 Yamaha Seca II - mostly stock, Racetech upgraded forks, FZ6R rear shock, Oxford Heated Grips, Barkbusters Blizzard Handguards, a Scottoiler vSystem chain oiler. My Mileage Tracker Page.
TonyKZ1 is offline   Reply With Quote
Old November 7th, 2013, 11:34 PM   #6
KJohnson21
KJohnson21's Avatar
Motorcycle(s): '08 Kawasaki EX250 "Yoshi", '99 Kawasaki Concours "Grace", '06 Concours "Belle", '06 Yamaha YZF600R "Slick"
^^ yeah, what alex.s said ^^
...and it doesn't matter what speeds you were doing on the highway. That's what it's made for. If it wasn't making weird ugly sounds when you parked it, the engine should be basically okay. But at this point the carbs need a good cleaning.
HEY!! Unregistered!! Does your bike have a name?
KJohnson21 is offline   Reply With Quote
Old November 8th, 2013, 05:02 AM   #7
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Charge the battery and try again. If its a strong click the turn the key so you get lights and all. Put it in neutral. Remove the plastic plug in the side cover on the left side. Use a big washer or something. There is a 14 mom nut on the end of the crank. Try to turn it counter clockwise.
Worlds fastest 250 ninja
Old November 8th, 2013, 10:18 AM   #8
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Welcome to the forum... Ya got plenty of good help round this place, best of luck
Old November 8th, 2013, 01:33 PM   #9
RedPepper64
Kawi Girl
RedPepper64's Avatar
Motorcycle(s): '10 Ninja 250R Green SE, '13 Ninja 636 Pearl White
Welcome and best of luck with the little biddie!
Perspective: Everything looks better from the inside of a motorcycle helmet
RedPepper64 is offline   Reply With Quote
Old November 8th, 2013, 01:43 PM   #10
RedPepper64
Kawi Girl
Old November 9th, 2013, 02:41 PM   #11
Snake
Snake's Avatar
Hello and welcome.
Old November 9th, 2013, 03:07 PM   #12
Originally Posted by Southeastjames View Post
Hey guys and gals. First to introduce myself. I'm in the Charlotte area, just south of the border actually in SC. Been riding since about '63 when I was but a wee lad on a Honda 55 Trail. ............But really, I don't know what to do with it. Fix it, part it out, sell it as is... What do you think?
Welcome to our site, James !!!
Have you worked on bikes during all those years?
I would buy a used engine and replace the seized one.
Old November 26th, 2013, 02:01 PM   #13
NinjaDucky
NinjaDucky's Avatar
Motorcycle(s): 2003 Kawasaki Ninja EX250r
Welcome! And yes motorcycle batteries are small and if yours is older it may just need replacing, especially if its sat dead for a couple years. See if you can turn it manually from the front sprocket nut. If you can your bike likely is fine. Flush and replace the fluids, clean everything, get a new battery and maybe a new spark plug while you're at it, I bet she starts right up
NinjaDucky is offline   Reply With Quote
Old November 26th, 2013, 02:04 PM   #14
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
Holy crap, someone on the site even older than I am.
Welcome!
Old November 26th, 2013, 02:41 PM   #15
allanoue
allanoue's Avatar
MOTM - Sep '14
James
fix it
Old May 11th, 2014, 08:56 AM   #16
Southeastjames
Guest
Posts: n/a
Well, it's been a while. Been busy getting getting the new house in order and with life in general.
Through research I found that Kawas have a 'positive neutral' and I couldn't get it into second because the bike had to be running and moving. Duh.. never heard of it. Anyway, a good carb soak in Berrymans, new battery and tappet adjustment and it's doing it's thing again.
Where do you guys think a good place to sell it is? I hate to resort to Craigslist, I put up at ADVRider. http://advrider.com/forums/showthread.php?t=977206
I don't want to be one of 'those' guys that join and post a bike for sale so I'll refrain from spamming your forum. If you have any ideas let me know.
Thanks,
James
Old May 11th, 2014, 09:03 AM   #17
Joshua763
Motorcycle(s): five honda's one harley one ninja most have sold all where fun.(one honda was a moped)
whats up James, I am just a newb here but it wouldn't hurt to put it up for sale you just need twenty five posts If it is a nice bike some one from the area you are in might like what they see. I think (tell me if I am wrong site people)
Joshua763 is offline   Reply With Quote
New to the forum, new to the Ninja desrik New Members 9 March 20th, 2013 11:41 AM
[urgent] my bike is dead. Very dead. Now what? arnoldc6 Riding Skills 15 September 8th, 2012 08:04 AM
Won my Ninja in last Summer's sweepstakes, just joined the forum! D. Dubya New Members 11 July 14th, 2012 02:11 AM
just joined! ninjer New Members 10 October 28th, 2011 11:47 AM
R1-Forum/R6-Forum Memorial Trackday at Jennings GP, March 2010 HKr1 Ninjettes At Speed 0 November 30th, 2009 05:42 PM
