Old August 21st, 2013, 03:51 PM   #1
dimeified
Motorcycle(s): '09 Blue 250R
Where dispose bad gas in North NJ?
My bike wont start after i left it in several rain storms. I tried draining the carbs, then priming them, that didnt do it. I threw in seafoam, that didn't do it either. I picked up a can of starter fluid, i will try that as well, but im starting to think i'll likely need to drain the tank. It had stuttered like it wanted to start before i had drained the carbs but now it wont even do that, just cranks, so i recharged the battery to be prepared for the starter fluid, tank drain test. Where can i drop this old gas off that probably has water in it? I looked all over, and found town sponsored recycling events, but the next one near me isnt until october, and i can't have that stuff sitting around in my apartment. Anybody have any ideas?
2 thumbs up
dimeified is offline   Reply With Quote
Old August 21st, 2013, 04:30 PM   #2
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
I hear it is flammable.
Old August 21st, 2013, 04:37 PM   #3
Joshorilla
Bass Master General
Joshorilla's Avatar
Put it in plastic bottles, if it has water in it you'll see it seperate.
Simply decant the water out, and add the remaining gas to top up your tank after you fill up in about a 1/20 ratio, till you've gone throu about ten tanks you'll have gotten rid of all the fuel.
Be sure to pass it through a filter first, a fuel line filter will cost about $1 and the same for some tube.
Alternately, know anybody with a petrol lawnmower? Perfect for the lawnmower or other less fussy / expensive engines.
Old August 21st, 2013, 04:42 PM   #4
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
chain saw, just add oil
Old August 21st, 2013, 05:18 PM   #5
Originally Posted by dimeified View Post
...........Where can i drop this old gas off that probably has water in it?.......
Inquire here:
http://www.nj.gov/dep/dshw/recycling/
http://www.state.nj.us/nj/green/recycling/
Call also local AutoParts; I know they collect oil contaminated with gasoline.
Old August 21st, 2013, 05:47 PM   #6
Asspire
Fix It Till Ya Break It
Asspire's Avatar
Motorcycle(s): 08 250RRrrrr
jersey shore
Old August 21st, 2013, 06:01 PM   #7
dimeified
Originally Posted by Motofool View Post
Inquire here:
i tried the county lookup, and mine only does october, and you must be a resident of that specific nj county to take advantage of their collection day, other counties wont take out of county residents. i hadn't thought about the autoparts stores though, thanks
2 thumbs up
Old August 21st, 2013, 06:08 PM   #8
Thorgrim
War Hippie
Thorgrim's Avatar
Motorcycle(s): CB500F
Dumping some rubbing alcohol in the tank usually takes care of it unless its horribly contaminated.
Thorgrim is offline   Reply With Quote
Old August 21st, 2013, 07:14 PM   #9
tc.young
Motorcycle(s): '89 klr 650, '00 250r
A car. They run on anything
tc.young is offline   Reply With Quote
Old August 22nd, 2013, 06:12 AM   #10
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
I have the same issue w/ my lawnmower, I simply drain the carbs until clean gas comes out instead of water.Water is heavier and will drain out first.
My Cafe Racer Build
My intro post
[American Motorcyclist Association] - Geoff Aaron signs with Gas Gas Motos North Amer Ninjette Newsbot Motorcycling News 0 January 7th, 2015 09:00 AM
[hell for leather] - A bad day at the gas station Ninjette Newsbot Motorcycling News 0 October 17th, 2012 05:50 PM
She had some pretty bad gas EvilPooMonkey General Motorcycling Discussion 3 June 17th, 2012 07:17 AM
Bad Gas Suave 2008 - 2012 Ninja 250R Tech Talk 4 July 25th, 2011 05:43 PM
Bad gas?!?You be the judge! amodea1 2008 - 2012 Ninja 250R Tech Talk 14 May 5th, 2010 08:46 PM
