Old March 20th, 2015, 11:57 AM   #1
Mrudloff
Motorcycle(s): 2007 Kawasaki Ninja EX250-F
Engine Oil
Coming up on my first oil change. What is the best engine oil to use? And where do you purchase it? Please and thank you.
Mrudloff is offline   Reply With Quote
Old March 20th, 2015, 12:14 PM   #2
fishdip
fishdip's Avatar
Motorcycle(s): 250/300
https://www.ninjette.org/forums/sear...archid=1945580
Old March 20th, 2015, 12:15 PM   #3
@fishdip, you know that link doesn't work right?
Old March 20th, 2015, 12:18 PM   #4
fishdip
fishdip's Avatar
WTF all I did was copy the link for the search (oil)....
Old March 20th, 2015, 12:18 PM   #5
rotella t6. it's a jaso-ma2 spec oil that has a much higher last-layer lube content than most others. 'round here people love it. i used to use v300 but now i just use t6.
Old March 20th, 2015, 12:25 PM   #6
fishdip
fishdip's Avatar
yep diesel oil works well.
Old March 20th, 2015, 01:35 PM   #7
Ghostt
Ghostt's Avatar
Shell Rotella T6 synthetic, As long as it's not the first time
violente et ignorantia
ZX-2R BLOG
Old March 20th, 2015, 01:56 PM   #8
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
Any oil that's motorcycle specific. Anywhere that sells motorcycle specific oil (Walmart, Autozone, Pepboys, etc). You're welcome.
PS - what filter will you be using?
Old March 20th, 2015, 02:07 PM   #9
you would think this is true but its actually not. there are lots of oils that are branded as moto oils but don't meet jaso-ma2 or other moto standards and can actually cause harm to the clutch.
get one that is jaso-ma2 compliant.
Old March 20th, 2015, 05:07 PM   #10
Ghostt
Ghostt's Avatar
no bias
any 10w-40 to 20w50 rated JASO-MA/MA2 oil will do just fine.
you loose oil through the normal combustive process. as oil atomizes in the crank case, it is pulled through the intake via the crank case breather vent and burned with the gasoline.
ZX-2R BLOG
Old March 20th, 2015, 06:12 PM   #11
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
Never knew that!!!! I always assumed that any oil that's labeled for motorcycle use is always going to be compatible with a wet clutch!
I'm really curious now.....have you guys ever seen a motorcycle oil that is not compatible with wet clutches? I personally never bothered to check. I've always used Rotella T6 or Mobil1 motorcycle oil.
Old March 20th, 2015, 07:20 PM   #12
MrAtom
MOTM - July '15
Didn't you recommend against using that stuff before and to just use what the owners manual says?
Old March 20th, 2015, 08:16 PM   #13
probably
Old March 20th, 2015, 08:17 PM   #14
Originally Posted by Ghostt View Post
no bias
buying expensive oil is like sacrificing money to the moto gods. it doesn't actually do anything. BUT IT DOES.
Old March 20th, 2015, 11:44 PM   #15
BoBO
BoBO's Avatar
Motorcycle(s): SC28 Fireblade
Rotella t6 is cheap and it's legit. However, there are many good oil brands out there like Motul 5100,7100, or their 300v for track. There's also Mobil 1, Repsol, and Amsoil. It's whatever you like.
94 900RR
04 BMW Z4 2.5 M Package
01 R170 AMG Sport Package
BoBO is offline   Reply With Quote
Old March 21st, 2015, 01:04 AM   #16
liberpolly
Motorcycle(s): 1999 Triumph Legend "Arwen", 2006 Ninja 650 "Matsuo Hotaru". 2010 Ninja 250 "Firefly" - sold.
When in doubt, ask MOM.
Screw the inscrutable, eff the ineffable.
liberpolly is offline   Reply With Quote
Old March 21st, 2015, 01:52 AM   #17
Singh2jz
Singh2jz's Avatar
Motorcycle(s): '07 ex250-F/J
I also use Rotella t6..
The Bike | The Truck
Old March 21st, 2015, 05:02 AM   #18
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
Old March 21st, 2015, 05:17 AM   #19
Notice what grade "Energy Conserving" is in? 30 (and below).
It's not an issue if you are using any 40-grade oil (like the majority of cycles). Just one more example of "Internet myths" that won't die...
Just use Shell Rotella T6 5W-40 synthetic and call it a day. It is more than adequate for normal cycle use.
Old March 21st, 2015, 06:55 AM   #20
Mrudloff
Thanks so much people!
Old March 21st, 2015, 09:08 AM   #21
accumack
accumack's Avatar
Motorcycle(s): honda crf230l & 2013 ninja 300se wife has Honda crf230l & honda cbr250r repsol
I used to use Mobil1 4t motorcycle oil at $11 a quart from Walmart now I use Shell Rotella T6 a gallon for about $22 from Walmart. I feel it shifts smoother than the Mobil1. Rotella T6 is used in tractors. They have wet clutches and are worked harder than our engines so I have no problems using it.
accumack is offline   Reply With Quote
Old March 21st, 2015, 09:09 AM   #22
i've blown a motor and a trans on track with 5100 and 300v. but i've not yet blown one on t6... :P :P
Old March 21st, 2015, 12:53 PM   #23
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
Same here! Not one single issue with the T6. And I get my oil analyzed by Blackstone Labs. After 5,000 miles (2 years) in the same bike, the oil is still pretty much brand new according to the lab report.
Old March 21st, 2015, 02:01 PM   #24
T6 is decent, but it will shear down. It's on the light side for a 40 to start with, and shears to a high 30 - which isn't really a problem. I have noticed a change in shifting after about 1000 mi in one of my cycles with T6.
Because it's not very expensive, I would suggest changing it just as you would a conventional oil.
Most of the time the issue is contamination of the oil from acids and moisture and depletion of the additive package (from starts and short trips). In that case, synthetic and conventional both react the same. The actual oil itself doesn't really wear out, it's the additive package that does.
I don't believe in extended change intervals just because you are using synthetic. I feel oil change intervals should be based more on number of cold starts and time spent at operating temp. If you start and run for a hour before shutting off and cooling down you will be able to run your oil safely many times longer that if you do numerous 10 minute trips (and many more cold starts) that add up to the same mileage.
Old March 23rd, 2015, 08:59 AM   #25
After you hit search, the URL of the search results is a unique ID for your particular search. It is temporary, and only for that particular query. You can't copy the links like that.
Need Help Oil,engine rebuild meggyewill 1986 - 2007 Ninja 250R Tech Talk 10 July 22nd, 2014 02:39 AM
Can thinner oil cause engine ticking?? LoneRonin 2008 - 2012 Ninja 250R Tech Talk 7 June 11th, 2012 11:25 PM
Where Did My Engine Oil Go? Francis 2008 - 2012 Ninja 250R Tech Talk 12 May 1st, 2011 10:15 PM
Engine Oil Gauge gophurr 2008 - 2012 Ninja 250R Tech Talk 14 June 12th, 2010 01:37 PM
Engine Oil Treatment DmbShn41 2008 - 2012 Ninja 250R Tech Talk 14 March 25th, 2009 03:38 PM
