Old June 7th, 2012, 07:58 PM   #1
Ninja1
Ninja1's Avatar
1250 km and already problems
Ok not sure what to make out of this but essentially the bike keeps stalling. I haven't ridden the bike in 2 weeks and a half. Today I installed the mirror extender brackets and had to take out the side and front headlight assembly. Take-down and assembly went very smooth and I can't imagine that I have pulled any cables or caused any short.
So the problem is essentially when I tried to start the bike it did not start. It took me about 10 tries to get it to start (full choke, halfway choke, no choke). When it started it hit 4k rpm with the choke and when I lowered the choke and twisted the throttle it died.
I let it warm up for 2 minutes and then I twisted the throttle, the rpm picked up but with some hesitation. I let it warm up for another 2 minutes and the rpm/throttle response improved but the hesitation was slightly there in the 2k-4k rpm range.
Then as soon as I put it in 1st gear the engine shuts down ... as I'm writing this very sentence I just realized that my kick stand was down which explains why the engine shuts down... but now that I wrote all this I'd like to still open this thread
I'm still concerned by the number of tries it took me to get it to start and also the hesitation when twisting the throttle. Is this normal for a bike that has 1200 kms and had an oil change @ 400kms? I'm glad it's still under warranty and I'm planning to take it for the 1000km service. What should I ask them to check given the issue I just had?
Ninja1 is offline   Reply With Quote
Old June 9th, 2012, 07:18 AM   #2
thisisbenji
thisisbenji's Avatar
Motorcycle(s): 2009 Ninja 250r (Sold), 2009 FZ6, 2015 Honda Grom
Mine has 3500 miles on it, hasn't ever given me any trouble starting. Then again I'v never let it sit for more than a couple of days. Maybe that had something to do with the slow start?
My Old Bike
My New Bike
thisisbenji is offline   Reply With Quote
Old June 9th, 2012, 10:24 AM   #3
Since you were working with headlight assembly, the problem may be electrical.
Check the connectors of both spark coils.
Old June 9th, 2012, 10:39 PM   #4
KawiKid860
KawiKid860's Avatar
Doesn't sound related to anything you did with the electrical stuff. More like a problem from sitting, but 2.5 weeks shouldn't be enough to cause any problems but who knows
Old June 10th, 2012, 02:39 PM   #5
lamyun
Motorcycle(s): 09 Ninja 250R
Everything you just mentioned is pretty normal if you let it sit for 2.5 weeks.
One of your carbs could be slightly clogged.
The easiest and cheapest solution would be to do the following:
1) Drain gas and fill up 1/2 with only Shell 91 (the only gas in Ottawa with no Ethanol in it)
2) Go to Canadian Tire and get a bottle of SeaFoam.
3) Dump 1/4 can (or more) SeaFoam into the gas tank.
4) Rock the bike left and right a bit to mix it up.
5) Start bike and let it idle for a 20+ mins then go for a little ride.
Should clear up after that.
You must always start the bike full choke and when it climbs to 4k rpm, close the choke and let it idle for around 5 mins.
Let me know how it goes
lamyun is offline   Reply With Quote
[visordown.com] - 1250 London motorcycle toll approved Ninjette Newsbot Motorcycling News 0 March 27th, 2015 04:13 AM
[motorcycle.com] - Church Of MO 2007 Suzuki Bandit 1250 ABS Ninjette Newsbot Motorcycling News 0 March 22nd, 2015 04:41 AM
[visordown.com] - Suzuki Bandit 1250 UK price announced Ninjette Newsbot Motorcycling News 0 March 3rd, 2015 10:30 AM
[visordown.com] - Pre2007 motorcycles face 1250 London toll Ninjette Newsbot Motorcycling News 0 November 26th, 2014 09:20 AM
[roadracingworld.com] - Suzuki Introduces New GSX1250 And Bandit 1250 Models In Franc Ninjette Newsbot Motorcycling News 0 September 12th, 2009 03:55 AM
