May 14th, 2013, 06:02 PM | #1 |
Join Date: May 2013 Motorcycle(s): '07 Ninja 250 (sold), 2013 CB500F Posts: 125
Aftermarket brake/clutch lever for 07?
My hands are kinda small for the stock ones but I can't find any shorter brake/clutch lever on ebay, I'm having problem practicing the blip throttle and brake at the same time. Even the guys at motorcycle mall couldn't find anything that fit 2007 ninja 250r.
Any ideas? |
May 15th, 2013, 08:39 PM | #2 |
I'm crazy,your excuse is?
here is a recent thread:
http://www.ninjette.org/forums/showthread.php?t=125951 |
May 18th, 2013, 12:56 AM | #3 |
meh
Join Date: Apr 2013 Motorcycle(s): 2002 EX250F Cafe/Streetfighter Project Posts: 60
Yeah, if you want shorter levers you'll pretty much have to go with the adjustable lever mod. You can either use the OEM style levers or go aftermarket.
For aftermarket, I'll vouch for rideitmoto. Got a pair on mine. It is from China, but it's a lot better than the eBay ones. Comes with a warranty and free grips. Shipping was $17 and reasonably quick. It was a grand total of $89, I believe. The levers are kinda flimsy vertically, but it does not impede use in any way. Love 'em so far. Also, when you buy the perch, make sure it comes with the collar thing. Without it, the lever won't fit properly. It's the gold thingy on the OEM lever in this picture:
SoCal 626/951 instagram | youtube | modifications |
May 20th, 2013, 07:30 AM | #4 |
So I would have to install new perch?
Time to hit some how-to videos... |
May 20th, 2013, 09:45 AM | #5 |
Join Date: Oct 2011 Motorcycle(s): 2004 Ninja 250F Posts: 308
Yup! I'm the OP for that linked thread and I did this a month or so ago.
You'll need to buy the complete EX500 clutch perch in-order to get the adjustable lever. Should run you around $40-45. The brake side can take an adjustable lever as-is. |
May 20th, 2013, 05:52 PM | #6 | |
I just want to confirm before I order Clutch & Brake lever the2wheels http://www.ebay.com/itm/the2wheels-A...=mtr#vi-ilComp Ex500 perch http://www.ebay.com/itm/2001-Kawasak...2acf85&vxp=mtr These are all the parts that I'll need? And the stock brake perch on '07 250r will fit with that brake lever? because it doesn't say 07 ninja 250r in the compatible vehicle, only 08-12. |
May 20th, 2013, 08:16 PM | #7 |
I would buy the EX500 levers, not the newgen 250 levers. I have no idea if there's a difference, but if you're buying the EX500 perch it only makes sense to get that lever. Either way - that's what I did and both levers fit.
But yes - all you would need is the EX500 clutch perch to add adjustable levers to both sides. |
Front brake = left lever; Clutch = right lever | cadd | Riding Skills | 27 | October 7th, 2014 08:29 AM |
Adjustable Clutch/Brake lever advert? | NathanUc | Forum Information | 4 | April 5th, 2013 09:02 PM |
WTB: Clutch lever, handle bar end, dummy cap, and clutch lever holder. 09 250r | SwagenGTI | Items Wanted | 5 | March 4th, 2013 12:20 PM |
Slip-on/Full Exhaust - Brake Lever - Front Fairing - Aftermarket Parts | AeroXtasy | Items Wanted | 1 | August 27th, 2011 09:04 PM |
FS OEM stock clutch lever and brake lever | Shaol1n Monk | Motorcycle-related | 0 | July 17th, 2011 06:36 PM |
