Old May 25th, 2016, 07:46 PM   #1
Ninja Rob
Ninja Rob's Avatar
Motorcycle(s): 2004 Ninja 250
So how can I fix this?
Look at what the Texas heat and humidity did to my seat. How can I fix it? Is there like a replacement kit? I Googled a lot of stuff but I need a better direction.
Before life ends, Some people want to climb Mount Everest, some want to go to Disney Land, some people want to visit Paris. Me, I want to ride a motorcycle.
Ninja Rob is offline   Reply With Quote
Old May 25th, 2016, 08:13 PM   #2
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
An upholstery shop, unless your handy with a sewing machine. Probably cheaper to buy a good used one.
Old May 25th, 2016, 08:59 PM   #3
Ninja Rob
Ninja Rob's Avatar
I would rather just replace the material with something durable.
Old May 26th, 2016, 06:55 AM   #4
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
go to a a boat upholstery shop they can help.
My Cafe Racer Build
My intro post
Old May 26th, 2016, 03:32 PM   #5
Macharity
At that point you don't need an upholsterer...you need a new place to live!
No more complaining from me about how hot it is wearing full leathers in 85 degree weather
Riding is not a solo act, it takes two. You need to listen to the bike, as much as, you need the bike to listen to you!
Macharity is offline   Reply With Quote
Old May 26th, 2016, 04:33 PM   #6
Twisthem488
Twisthem488's Avatar
Motorcycle(s): 2009 Ninjette
I wouldn't think sewing is really needed. Just get something like neoprene and staple it on.
Twisthem488 is offline   Reply With Quote
Old May 27th, 2016, 04:44 PM   #7
toEleven
Slower than you.
toEleven's Avatar
Motorcycle(s): CBR600RR, CB750, EX300 (半蔵)
MOTM - May '16
A member here has a DIY on their blog. RECOVERING: A “HOW TO” OF REUPHOLSTERING A NINJA 250 MOTORCYCLE SEAT
courtesy of @wendyjboss
DISCLAIMERv1.0: There may be more info on the topic than this forum post. Conduct your own research.
If another thread is linked or quoted, go read it yourself.
toEleven is offline   Reply With Quote
Old May 27th, 2016, 05:59 PM   #8
boat vinyl + staple gun.
you probably want to redo the foam while you're at it. hot wire cutter makes the foam work about a million times easier.
Old May 27th, 2016, 06:22 PM   #9
verboten1
verboten1's Avatar
MOTM - June '15
New cover
http://www.ebay.com/itm/KAWASAKI-250...hU~jNf&vxp=mtr
New seat
http://www.ebay.com/itm/Kawasaki-198...3D191882247020
Both super cheap.
Ride more, worry less.
Old May 27th, 2016, 07:29 PM   #10
wendyjboss
wendyjboss
wendyjboss's Avatar
Motorcycle(s): 2015 Honda CBR 500RF (On its way), 2004 Kawasaki Ninja 250 (sold)
Originally Posted by verboten1 View Post
Originally Posted by toEleven View Post
It's true -- the seat can be had for about $35.00. I had a piece of good quality vinyl sitting around for another project that I never got to and so used it. It was a vinyl remnant and cost me under $10.00. I think the advice to get marine quality vinyl or naugatuck is good. You do have to really stretch the vinyl to get it tight against the foam. I used a heat gun. If you choose to do your own, make sure to get the right material and don't overheat the vinyl. Plus the staples you'll need are 1/4 inch. The 1/2 inch staples are too long. Last, but not least, the hardest part of the job is the stretching and finishing of the vinyl. You have to keep working it. It's a few hours job I think to get it right, but I only did it once and maybe someone who really knows what they're doing can do it faster.
So the tradeoff is time and save money or just pay someone $35.00 to do it.
wendyjboss is offline   Reply With Quote
Old May 29th, 2016, 09:36 AM   #11
Ninja Rob
Ninja Rob's Avatar
Where did you buy that vinyl? I don't think anyone within 75 miles repairs vinyl seats. I would have to do it myself.
Old May 29th, 2016, 08:36 PM   #12
wendyjboss
wendyjboss
wendyjboss's Avatar
I bought the vinyl at a fabric store. I had planned to use it to reupholster some bar stools ... so I figured it was reasonably good quality. Often those stores have remnants of fabrics and can be had very reasonably.
If you go that route, make sure the vinyl you buy is slightly stretchy. It will help to get it to conform to the seat.
Keep in mind that it needs to be water repellant too. I think that is generally a quality of all vinyl, but that some are more water repellant than others. I tested mine by dripping water on the seat, but I'm still going to treat it with something as soon as I get around to finding a water repellant that is rated for vinyl. A lot of the popular repellants for outdoor clothing and such is not rated for vinyl. I might just armor-all it regularly until I find what I want. It's a precaution that I'm taking just because I did not use marine grade vinyl.
I'm very happy with the way my seat turned out. It's less slippery than the stock cover, and more comfortable even though I didn't do any mods underneath to the foam.
How do I fix this karanj94 2008 - 2012 Ninja 250R Farkles 46 June 25th, 2015 05:55 PM
HELP!!! should i fix my ninja? jak.regret General Motorcycling Discussion 5 December 7th, 2012 07:03 AM
How can I fix this? the big mike 2008 - 2012 Ninja 250R Tech Talk 18 August 25th, 2011 10:23 AM
Battery fix HKr1 Off-Topic 5 June 20th, 2010 11:47 AM
