Old May 25th, 2014, 11:25 PM   #1
Noobman
Noobman's Avatar
Motorcycle(s): 2010 KTM Duke 690, Owned a 2008 Ninja 250
How do you keep your rims clean ?
My rims keep getting dusty and grimy and loose their shine every week and I'm getting a bit tired of it.
What I use is wd40 to clean them.
Does anyone know of a spray or something you can apply to the rims to prevent dirt from sticking to them so easily ?
Noobman is offline   Reply With Quote
Old May 25th, 2014, 11:34 PM   #2
when i stop to pee, i recycle and just pee on the rims
Old May 25th, 2014, 11:49 PM   #3
Noobman
Noobman's Avatar
What a fantastic idea .
Also, refer to my avatar .
Old May 25th, 2014, 11:54 PM   #4
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
I don't clean my bike to often, if it gets washed I wash the rims though!
Old May 26th, 2014, 12:27 AM   #5
Flying
Motorcycle(s): 2010 Ninja 250
You have a few options:
Clean and wax the rims and stop riding.
Strip the paint and get a chrome finish done. This will only extend the period between cleaning.
Teflon coat and bake. Take care not to scratch.
No amount of detailing or product will stop all the BS on the road for more than several days at most.
Also, take care with that WD-40 man. I don't think that belongs anywhere near the tires.
Old May 26th, 2014, 12:53 AM   #6
Noobman
Noobman's Avatar
No amount of detailing or product will stop all the BS on the road for more than a few weeks at most.
Awesome response,
Yea, im careful with that stuff
Old May 26th, 2014, 01:00 AM   #7
Singh2jz
Singh2jz's Avatar
Motorcycle(s): '07 ex250-F/J
Paint em matte black!
The Bike | The Truck
Old May 26th, 2014, 01:06 AM   #8
KawiKid860
KawiKid860's Avatar
I don't. My Ninja wheels are kind of brown now instead of black. It's custom!
Old May 26th, 2014, 02:27 AM   #9
Skullz
Skullz's Avatar
Motorcycle(s): 2012 Ninja 250
After a long winter riding in cold salty road conditions my rims were hit, i tried everything to get them to come clean the easy way and it wasn't happening. I just got down to it and scrubbed them damn things for around 45 minutes each wheel to come clean and shiny again, after that i make sure to clean them every time i wash the bike and wipe them down with lucas oils speed wax to keep them all perty, but the first time is the worst you will have to deal with if you haven't kept up with cleaning them. Another thing i did was to switch from chain oils to chain waxes so i do not get all that oil slung on the rims like i did when i used the stuff.
Old May 26th, 2014, 05:19 AM   #10
DaBlue1
DaBlue1's Avatar
Stop using WD-40. It attracts dirt.
Clean the rims real good. Then use a light spray wax/cleaner. It helps repel brake dust and some road grime. Helps dirt to be easily removed.
When you do regular chain maintenance, check your tire pressure/condition also clean the rim/wheels/brake calipers.
My rims look almost as good as new. They've got a few minor nicks and scratches from normal wear.
See this thread for more info. https://www.ninjette.org/forums/show...ust#post302256
Old May 26th, 2014, 06:16 AM   #11
capt_bugaloo
motorcycle rider
capt_bugaloo's Avatar
I spray good old Pledge furniture 'polish' (it's actually a wax) onto a rag and then wipe down the rims with the rag. The wheels still get oil and dirt on them, but the layer of wax makes road grime easy to wipe off with a rag.
Do *NOT* spray directly onto the wheel as you do not want slippery wax going onto your tires or brake discs!
Old May 26th, 2014, 06:27 AM   #12
I don't. I've adopted the attitude of worrying less and riding more.
The bodywork gets an occasional wiped own with a damp cloth through
Old May 26th, 2014, 07:01 AM   #13
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
what is cleaning? sounds like something that gets in the way of riding.
TEAM ALFALFA
www.apexassassins.com
Old May 26th, 2014, 06:18 PM   #14
My black rims were a chalky mess when I finally got powder-coated blue rims. I spent hours trying to clean them. My new blue rims eventually turned black and the stuff just would not come off with soap and water. I noticed that the rag I used to clean my chain would take the grime right off my rims, so I ended up using WD-40 to clean them.
BIG MISTAKE!
It attracts grime like nobody's business. If you use WD-40 you will be cleaning it again every three days. If you need it to get off years of grime, go ahead, but be ready to follow up with something that cuts oil and grease (Dish detergent + Simple Green?).
Old May 26th, 2014, 08:03 PM   #15
I should go take a pic of my WHITE wheels, I haven't cleaned them since Feb. Last time I cleaned them, it was with....
WD-40
But hey, use what works for you.
Old May 26th, 2014, 08:06 PM   #16
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
Simple Green?
Old May 26th, 2014, 08:38 PM   #17
^^^ that works pretty good too.
Old May 26th, 2014, 08:53 PM   #18
WD-40
Do you ride it often? Mine was a daily commuter and the effect of WD-40 on the collection of grime was obvious.
Old May 26th, 2014, 08:56 PM   #19
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
I don't clean them, the only thing I regularly clean is my chain and I let the rain do the rest. My bike could look shinier but then it would just get dirty again so I don't really care to take the time unless I'm heading to take a girl out on a ride or just road through salted roads.
Old May 26th, 2014, 09:16 PM   #20
Interesting... I wonder why your seeing such an effect.
I don't ride it daily, no. When it was in street dress, sure, I rode it often enough but it had black wheels at the time. Now my 250 only sees track miles about 2 weekends a month thus far. Maybe the r6 would be an even better pic. It also has white wheels and been even longer since I cleaned them and it's seeing it's fair amount of street time as of now.
Don't get me wrong, I aint saying it's the best, but it works for me. I am somewhat skeptical that it attracts dirt to the point that it makes cleaning them much hard then using any other product. Spray on cloth, wipe wheel area a few times and move on. If I use anything else, like simple green, it takes longer and I have to scrub more and harder to get the same level of clean in the end.
When I first got the white wheels, I used to wipe them off after every ride. It made keeping them pristine white pretty easy. After the novelty wore off, I don't clean them near as often.
Also note, the white wheels on both my bikes were originally black and have been powder coated white.
Old May 27th, 2014, 07:02 AM   #21
Dude, WD-40 is great for getting ride of grime. Then use Simple Green to get rid of the WD-40 residue.
Or just use concentrated Simple Green in the first place. That **** rocks.
Old May 27th, 2014, 08:36 AM   #22
accumack
accumack's Avatar
Motorcycle(s): honda crf230l & 2013 ninja 300se wife has Honda crf230l & honda cbr250r repsol
I mine down after every ride and use Hondabrite every couple of rides.
accumack is offline   Reply With Quote
Old May 27th, 2014, 08:45 AM   #23
Bob2010
Bob2010's Avatar
Clean using mean green from dollar tree
The use Armour all rim protectant
Then the dust thst does stick comes off with compressed air or water
2010 Red Ninja 250
2009 Black Ninja 250
Old May 27th, 2014, 01:49 PM   #24
the big mike
the big mike's Avatar
Motorcycle(s): 2008 Ninja 250r, Fazer8
I use my chain cleaner, it decreases everything really well and the job is done in a few minutes
I can not be a true player by playing around.
the big mike is offline   Reply With Quote
Old May 27th, 2014, 01:51 PM   #25
Bob2010
Bob2010's Avatar
2010 Red Ninja 250
Old May 27th, 2014, 04:54 PM   #26
misfitsailor
Ninjette Jockey
misfitsailor's Avatar
Motorcycle(s): Ninja 250R, Harley Davidson Heritage Softail, 2 Honda Monkeys, Polini & GRC mini GP
I learned a trick from motocross racers years ago. Silicone spray. You can spray it on everything except your tires. It makes it really easy to clean later.
For what shall it profit a man, if he shall gain the whole world, and lose his own soul?.
misfitsailor is offline   Reply With Quote
Old May 29th, 2014, 06:27 AM   #27
mgentz
Board Member
don't spray wd40 on them....it is a cleaning agent but it also leaves behind a residue that dirt sticks to. use plain old soap and water then wax them to help keep dirt from sticking.
Old May 29th, 2014, 06:28 AM   #28
mgentz
Board Member
I use this on my bike and my dirtbike. makes clean up much easier.
Old May 30th, 2014, 11:38 PM   #29
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
Bike cleaning...
Old June 1st, 2014, 05:11 AM   #30
Mocha Man
Blue Shell magnet
Mocha Man's Avatar
Motorcycle(s): 1997 Ninja 250
This is what I've also done my whole life. Its the easiest eay and makes them look brand new when done
Mocha Man is offline   Reply With Quote
Old June 1st, 2014, 07:50 PM   #31
geeker
geeker's Avatar
Motorcycle(s): 2022 Honda CRF300L Rally, 2015 Ninja ZX6R 636, 2014 Ninja 1000, 2013 Ninja 300 (sold), 2011 Ninja 250R (sold)
Meguiar's foaming wheel cleaner.
geeker is offline   Reply With Quote
Old June 1st, 2014, 08:51 PM   #32
Skippii
Milkshake Drinker
Skippii's Avatar
Low water crossings.
"What a sweetheart."- ninja_sleeper to me
Painting rims...?! blink General Motorcycling Discussion 6 June 9th, 2011 04:12 PM
Rims... LittleNinja Items Wanted 0 March 27th, 2010 03:04 PM
bigger rims NoobNinja General Motorcycling Discussion 9 September 2nd, 2009 07:59 AM
Looking for Rims and Tires HA-Y-N NINJA Items Wanted 3 May 5th, 2009 05:45 PM
Rims tjkamper 1986 - 2007 Ninja 250R Farkles 1 April 24th, 2009 02:43 PM
