Old May 24th, 2017, 06:47 PM   #1
skip
skip's Avatar
Motorcycle(s): 2009 250r
carburetor
Where can I get wire thin enough to clean the Jets and nooks and crannies on the carb . What gauge.
skip is offline   Reply With Quote
Old May 24th, 2017, 08:08 PM   #2
Guitar strings. I know you got a friend, but if not... I will be more than happy to send you a pack of used Ernie Ball Super Slinky's 9's.
Lemme know and good luck!
ps... a new set is about $5 on sale and will nearly last the lifespan of the bike.
Old May 24th, 2017, 08:15 PM   #3
And for reference...
Here is a set of 10's true measure.
Those gauges pretty much take care of every carb I have EVER run accross.... EVER.
Old May 24th, 2017, 09:52 PM   #4
skip
skip's Avatar
Thanks brother appreciate you
Old May 25th, 2017, 05:23 AM   #5
Its advisable to know the manufactured size of the jet you are intending to poke prior to blindly going at it.
an '09 uses 38 pilot jet
.38mm = .0149"
I'd suggest a "fourteen" string in this instance....followed by a bath in spray carb cleaner, finish with compressed air. That should clear it without hogging it out.
Note, while guitar strings work great for pilot jets, the hidden inner passages within the carbs can't possibly be cleared with strings. Like a maze...there are varying degrees of bends and curves and varying sizes of orifices within each circuit.
Don't be misled...by design, they're a little more complex inside, eliminating the possibility of simply snaking them out using strings.
Old May 25th, 2017, 06:56 AM   #6
bob706
bob706's Avatar
I used an old 8 gauge string I had followed by a soaking in pine sol for a few days. worked like a champ
http://sandollarmotorcycleclub.com/
Old May 25th, 2017, 11:27 AM   #7
skip
skip's Avatar
Thank you guys appreciate all the advice
Old May 25th, 2017, 04:06 PM   #8
Demonik
V-Twin Addict
Demonik's Avatar
Motorcycle(s): '99 Buell X1, '09 Buell 1125CR,'10 Kaw EX250 (down to one), '13 MV Agusta F3
Boiling them for about 10 minutes helps a LOT -- it almost cleans them 100%. I used stripped wire ties for bread wrappers and took my time on the slow jets that were completely blocked and it was over in about 5 minutes. You don't want to be too aggressive in there.
"I wrecked a moped once trying to pick up bitches in front of a party doing a stoppie" 14/10 would do again.
Demonik is offline   Reply With Quote
Old May 27th, 2017, 06:12 AM   #9
Coincidence....
Just yesterday encountered grossly hogged out pilot jets during an EX500 carbset refurb. I routinely index (measure) pilot jets within my service procedures....hence my discovery.
Marked as stock jet size...supposed to be .0139" were actually hogged out to .017". Intentional or "operator error"? Dunno.
Important to know what size you're dealing with....before and after cleaning.
These would have negatively affected fuel consumption to some degree.
Owner opted to replace with new (which I stock) .....all done.
Old June 5th, 2017, 12:39 PM   #10
Timpo
Motorcycle(s): 2013 Ninja 300
guitar spring isn't the only option
Timpo is offline   Reply With Quote
Carburetor Cleaning Motofool Videos 3 May 20th, 2014 08:42 PM
Carburetor - what maintenance? LemonSlice! 1986 - 2007 Ninja 250R Tech Talk 4 July 17th, 2013 09:48 AM
problem with carburetor maybe? alex.bowles 1986 - 2007 Ninja 250R Tech Talk 40 March 18th, 2013 12:58 PM
carburetor bolts james250ninja 2008 - 2012 Ninja 250R Tech Talk 3 September 2nd, 2011 01:53 PM
Carburetor Heads Up Jakester9500 1986 - 2007 Ninja 250R Tech Talk 14 March 31st, 2010 09:44 AM
