Old October 8th, 2015, 03:30 PM   #1
erbarry88
Motorcycle(s): 2011 Ninja 250R, 2007 GSX-R 600
Splicing wires
So I'm changing the engine and just realized the engine I bought has the Alternator Lead wires and Crankshaft Sensor wires cut. Can I just splice these wires together? It would be with aviation envirmontel splices.
2011 Ninja 250R
2007 GSX-R 600 (Sold)
erbarry88 is offline   Reply With Quote
Old October 8th, 2015, 04:23 PM   #2
cuong-nutz
cuong-nutz's Avatar
Yeah. you'll be fine. Just make sure you seal the splice up properly.
HalfFast Racing Team
Old October 8th, 2015, 04:32 PM   #3
Ghostt
Ghostt's Avatar
I'm old school, solder with heat shrink.
violente et ignorantia
ZX-2R BLOG
Old October 8th, 2015, 05:41 PM   #4
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
I am too, although a good crimp is better in that there is stress in a solder joint in wiring where the solder ends and vibration can sometimes break the wire there.
Old October 8th, 2015, 07:48 PM   #5
Ghostt
Ghostt's Avatar
If stress is an issue, then solder, and crimp.
With leads coming off the stator, you don't want any resistance, if you have resistance, you have heat, then you melt.
http://easternbeaver.com/Main/Elec__...p280_help.html
If your going for reliability the consider changing the OEM stator connector with a better one,3 Position HD Waterproof Connector
http://easternbeaver.com/Main/Elec__...etri-pack.html
ZX-2R BLOG
Old October 8th, 2015, 07:53 PM   #6
I like those weatherpack connectors. I should really do more of my wiring with those. Wish I'd discovered them long before I did.
Old October 8th, 2015, 09:04 PM   #7
dcj13
Participant
dcj13's Avatar
Jim Davis, owner of Eastern Beaver, is responsive, prompt, and makes great products. He gets a 5-star rating in my book.
Old October 8th, 2015, 09:59 PM   #8
Ghostt
Ghostt's Avatar
Yeah Jim is a great guy. When I did my mosfet R/R conversion I just got the ends I needed,
but I will be doing the full wiring hopefully this winter,
http://easternbeaver.com/Main/Elec__...onnectors.html
Also looking into this as well http://easternbeaver.com/Main/Wiring...3_circuit.html
ZX-2R BLOG
Old October 8th, 2015, 10:10 PM   #9
Those are nice and all, but just about every shade tree mechanic in KY can get the same result with this;
ps.... jk
Old October 9th, 2015, 05:41 AM   #10
erbarry88
Thanks everyone for all the information. These splices are pretty durable and weather resistant. We use them all over our airplanes and have no issues even when exposed to the environment like the wheelwells.
2011 Ninja 250R
Old October 9th, 2015, 08:59 AM   #11
bruce71198
bruce71198's Avatar
Attachment 38427
I think what you have there is a good choice. Keep in mind that the factory engineers found no reason to do more than crimp those connections, and the connectors don't resemble anything that is weather tight.
Old October 15th, 2015, 05:26 AM   #12
ducatiman
ducatiman's Avatar
I opted to upsize my stator output wiring *direct* to the mosfet RR.... a Shindegan FH010 (from an earlier ZX10) using a Furakawa connector at the RR.
Note puny 16ga yellow opposed to 12ga black silicone jacketed stuff.
The tiny junk 16 not long term reliable...simply could not deal with the heat...insulation hardened
Although this on my Duc...same principles apply to your ninj.
That Duc stator was rewound by Ricks, has held up remarkably, my only complaint was the
undersized wire size they chose. Prompting my tweak....with no further issues nor complaints.
Old October 15th, 2015, 05:41 AM   #13
ducatiman
ducatiman's Avatar
Attachment 38427
back to splicing wires....the non-insulated butt splices in your photo are my go-to when splicing needed. Note they can be soldered, crimped or *both*.
Of course, must heat shrink and can use additional loom (where applicable)
Old October 15th, 2015, 07:40 AM   #14
erbarry88
The splicing has been done and everything is working perfectly. The engine is finally in and working great after swapping the starter and syncing the carbs. Now just waiting on the chain and sprockets to arrive and should be rideable by the afternoon.
2011 Ninja 250R
Old October 15th, 2015, 08:44 AM   #15
crimp and then solder. trusting less is putting your faith in luck
Old October 15th, 2015, 08:45 AM   #16
Ghostt
Ghostt's Avatar
Agreed
ZX-2R BLOG
too many wires on the battery eddiekay 2013 - 2017 Ninja 300 Tech Talk 5 May 12th, 2014 08:07 PM
What are these wires for? djjontran 1986 - 2007 Ninja 250R Tech Talk 8 July 3rd, 2013 12:01 PM
help me map gauge wires into harness wires Kangxi 2008 - 2012 Ninja 250R Tech Talk 9 April 18th, 2012 06:08 PM
Unsheathed wires? arcman 2008 - 2012 Ninja 250R Tech Talk 5 November 24th, 2010 07:58 AM
Unconnected wires jola 1986 - 2007 Ninja 250R Tech Talk 12 July 10th, 2009 07:23 AM
