Old June 1st, 2013, 03:52 PM   #1
allanoue
allanoue's Avatar
MOTM - Sep '14
808 keychain cam mounted under headlights
Old June 13th, 2013, 06:57 PM   #2
I like that alot.
Old June 13th, 2013, 07:21 PM   #3
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Not bad at all! :goes off to research the 808 :
<-- Linky
Old June 13th, 2013, 07:41 PM   #4
Careful Teri, those come in like 7 or so different versions. If you buy one make sure you know what your buying. I had.... one until my kids lost it.
Old June 13th, 2013, 07:52 PM   #5
allanoue
allanoue's Avatar
MOTM - Sep '14
This is how and what I got
Originally Posted by Live2ride View Post
I would suggest an 808 keychain cam #16 with the d lens. It's super small and can record for quite some time in 720p with a 120 wide angle.
Old June 13th, 2013, 08:02 PM   #6
Can that version record while charging? My old one couldn't.
Old June 13th, 2013, 08:06 PM   #7
allanoue
allanoue's Avatar
MOTM - Sep '14
yes, the only time I need to stop recording is when the card gets full, 5 hours on 16 gigs
Old June 13th, 2013, 08:11 PM   #8
NylundHD
Motorcycle(s): None Yet
ya definitely the 808 #16v2 with the wide lens looks pretty good and can't beat the price! Nice place to mount too!
NylundHD is offline   Reply With Quote
Old June 13th, 2013, 08:13 PM   #9
Dope! Imma get one and wire a usb charger on the bike. I will have to do my homework on that version to ensure a 32gig card will work.
Old June 13th, 2013, 08:23 PM   #10
allanoue
allanoue's Avatar
MOTM - Sep '14
from the help app
Recording when directly connected to a PC
With this camera, it is possible to charge the battery and record at the same time while connected to a PC.
In order to record video while the camera is connected to a PC, the video recording must be started before the camera is connected to the PC. It is not possible to record if the camera is turned on while connected to a PC. Likewise it is not possible to take pictures while the camera is connected to the PC.
Breaking the Rules
As stated in the introductory, this camera only supports micro SD and micro SDHC Memory cards. These cards are formatted in FAT32, which is the format the camera requires. Microsoft has imposed an artificial limit on the maximum capacity of the FAT32 file system of 32GB even though, theoretically, a limit of 2 Terabytes is possible.
Large capacity micro SDXC (XC=Extended Capacity) cards start with a capacity of 64GB. It is not possible to read these cards with normal SD or SDHC card readers, which includes this camera. SDXC cards can only be read with special SDXC card readers. SDXC cards placed in a normal SD(HC) reader may be recognized by the operating system, but will be found to be unformatted, which is not correct. If formatted using Windows, they will probably be formatted with 16GB total capacity!
SDXC cards will be recognized correctly if used in an SDXC card reader and the file system will be exFAT. The maximum capacity of exFAT is 2 Terabytes.
If you use the "In-Camera Formatting" to format your SDXC cards, you do so entirely at your own risk. The Manufacturer takes no responsibility for incorrectly formatted cards and the consequences that may arise (for example destroyed cards). SDXC cards formatted with FAT32 are not supported by Microsoft and you will possibly invalidate your card's guarantee by doing so.
Using In-Camera Formatting it is possible to format SDXC cards in FAT32 Format. Doing so will turn the cards into out-of-specification SDHC cards. However, you will have the advantage of much higher card capacities. For example, a 64GB SDXC card formatted with FAT32 will give you about 20 hours of continuous video when recorded with a data rate of 7 Mb/s. After formatting with FAT32 these cards will be recognized by Windows using normal SD(HC) card readers, which includes this camera, to their full capacity. Note that the max. file size of 4GB still applies.
SDXC cards formatted with FAT32 may be converted back to exFAT by using SDFormatter but an SDXC card reader must be used.
Old June 13th, 2013, 08:45 PM   #11
NevadaWolf
NevadaWolf's Avatar
I'm thinking it'd be neat to have something small and simple to help align the different views I want for my track days. Trying to go the Jiggles route and get all the angles! LOL
<-- Linky
Old June 14th, 2013, 05:49 AM   #12
The beauty of these little guys are the mounting options. You can mount them anywhere with a bit of industrial velcro. But for the track, I would go the extra step of safety wiring them or add a zip tie to secure them.
I am not sure about simplifying things though.... with multiple cams in obscure places, I would forget to turn a few on. lol
Old June 14th, 2013, 06:24 AM   #13
allanoue
allanoue's Avatar
MOTM - Sep '14
I used a twisty tie to the usb cable. but after a few hundred miles the velcro has yet to fail.
Old June 14th, 2013, 06:34 AM   #14
allanoue
allanoue's Avatar
MOTM - Sep '14
mail run to the end of the driveway
Old June 14th, 2013, 07:28 AM   #15
Live2ride
Live2ride's Avatar
Motorcycle(s): 06 yzf r6r previously: 09 ninja 250r, black 07 zx6r
That's one hell of a driveway you have there.
Live2ride is offline   Reply With Quote
Old June 14th, 2013, 10:38 AM   #16
ai4px
ai4px's Avatar
Motorcycle(s): 650r 2009 Vulcan 800 2005
The 808 #16v2 with lens D is the way to go. I glued two small watch battery size magnets on the bottom of mine and bought a handful of some magnetic name badge holders off ebay. You can glue the name badge holders to lots of things... like your helmet and the camera just snaps on and off, easy peasy.
It's all about the curves. If you ride, you understand. If you have a stick skinny g/f and ride, you're 1/2 way there.
ai4px is offline   Reply With Quote
Old June 14th, 2013, 10:50 AM   #17
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
AFM #676
Supersports are for n00bs
Old June 14th, 2013, 11:07 AM   #18
ai4px
ai4px's Avatar
An interesting note about the 808 16v2 cameras... if you load the AVI firmware, it will record in files that are 5:00.9 seconds long.... every 5:00.0 minutes. So there will be a 0.9 second overlap between files. Makes it extremely easy to stitch together multiple videos and not miss a frame. When your memory card gets full, it is supposed to loop and overwrite the old files. I dunno, I haven't filled my 32gig card yet.
The MOV firmware seems to miss about 3 seconds of video when it changes files.
Also, if you turn off sound, it doesn't record a soundtrack at all, which saves a little memory.
Old June 14th, 2013, 11:11 AM   #19
NylundHD
I havent done all my research, but sounds like a great deal! Also nice to see another SC rider
Old June 14th, 2013, 11:19 AM   #20
fishdip
fishdip's Avatar
Motorcycle(s): 250/300
What site are you getting them from?
Old June 14th, 2013, 11:24 AM   #21
allanoue
allanoue's Avatar
MOTM - Sep '14
Got mine here I got it in 2 days
http://www.ebay.com/itm/380627482427...84.m1497.l2649
Old June 14th, 2013, 11:38 AM   #22
fishdip
fishdip's Avatar
Thanks for the link.
Old June 14th, 2013, 12:23 PM   #23
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
Finally a small all black camera I can hide on my all black bike to record incase of an insurance claim but not attract a cops attention to use as evidence against me
I just need it to loop and record as I charge it so I can just leave them on the whole time. Will this #16v2 do this?
Old June 14th, 2013, 12:41 PM   #24
allanoue
allanoue's Avatar
MOTM - Sep '14
Can you see it under my headlights? If you look right at it you can, but it will not jump out at you.
records on power
looping is an option but I have not filled a card to test
Old June 14th, 2013, 12:58 PM   #25
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
My bike is also black so it will blend in even better, plus I've got so much eye catching orange painted parts on my bike that I don't think it would be the #1 item to stand out
Old June 14th, 2013, 02:00 PM   #26
allanoue
allanoue's Avatar
MOTM - Sep '14
I will let you know if it can loop tomorrow morning.
Old June 14th, 2013, 02:56 PM   #27
hirubhaiambani
Ninjette Fanboy
Motorcycle(s): 2008 Ninja250
How do you connect the camera to the battery for continuous charging?Is the USB charger connected directly to the battery or is there some kind of relay/ switch/converter between the battery and the camera?
Does this make sense? I am a total noob with electrical things but really interested in doing this.
hirubhaiambani is offline   Reply With Quote
Old June 14th, 2013, 03:40 PM   #28
allanoue
allanoue's Avatar
MOTM - Sep '14
DIY here
http://www.ninjette.org/forums/showthread.php?t=84468
Old June 14th, 2013, 07:22 PM   #29
allanoue
allanoue's Avatar
MOTM - Sep '14
@rojoracing53 It does loop. You can set it to different time length files and I set mine to 5 minuet files. After 5 hours my card was full and it stared deleting the oldest file to make room and keep recording.
Old June 14th, 2013, 08:01 PM   #30
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Damn I like that, I've been thinking about attaching a permanent camera to do this. I get tired of messing with my gopros everytkme
AFM #676
Old June 16th, 2013, 11:07 AM   #31
iplante
I ride like a granny
iplante's Avatar
Motorcycle(s): 2003 Ninja 250R - EX250F
That's so sweet. I might have to get one. I can't afford a GoPro or Contour cam and honestly I don't care about super-omg-hd quality, I just want something that will record my mistakes and that I can look at to get better.
Would these mount easily to a helmet?
WANTED for 88-07 Ninja 250:
Corbin Gunfighter & Lady seat
iplante is offline   Reply With Quote
Old June 16th, 2013, 11:17 AM   #32
allanoue
allanoue's Avatar
MOTM - Sep '14
http://www.ninjette.org/forums/showthread.php?t=134951
Old June 16th, 2013, 04:15 PM   #33
hirubhaiambani
Ninjette Fanboy
Thank you Sir!
Old June 16th, 2013, 04:51 PM   #34
ChaoSS
Motorcycle(s): 2012 red 250 ninja
Is that camera good enough to pick out license plates and such when someone does something stupid in front of you?
ChaoSS is offline   Reply With Quote
Old June 16th, 2013, 05:17 PM   #35
allanoue
allanoue's Avatar
MOTM - Sep '14
If you get real close sure.
Old June 29th, 2013, 01:31 AM   #36
maxgohan
Motorcycle(s): 09 250r
how long does the battery last on it?
maxgohan is offline   Reply With Quote
Old June 29th, 2013, 03:40 AM   #37
allanoue
allanoue's Avatar
MOTM - Sep '14
1 Hour
Old June 29th, 2013, 05:36 AM   #38
ai4px
ai4px's Avatar
I finally got around to watching the video... can't do you tube at work and that was the last time I looked at this thread... man that's a wonderful road to ride!
Old August 2nd, 2013, 11:49 PM   #39
rasta
Your face
rasta's Avatar
So I'm interested in doing this. I imagine your 300 is similar to my 250. Where did you end up mounting the power source and route the wires?
I was hesitant about getting the 808 keychain because 1 hour of battery is kind of weak. But your method is the best I've seen!
Old August 3rd, 2013, 06:34 AM   #40
allanoue
allanoue's Avatar
MOTM - Sep '14
Thanks @rasta
Wired the port inside the fairings from the battery back to the tail then from the tail to the instrument panel and just velcro on any spot that looks good. It is a short trip for the usb cable from there to under the head light. I velcroed the camera and the usb cable.
Used 3m dual lock
808 camera mount ai4px Videos 12 June 25th, 2014 05:23 AM
replacing exhaust cam with intake cam subxero 2008 - 2012 Ninja 250R Tech Talk 2 June 1st, 2014 12:19 PM
808 Camera replacement ai4px Videos 8 October 19th, 2013 07:50 PM
808 state ninja808 New Members 5 May 7th, 2012 07:41 PM
Whats up from the 808 state! Darzee New Members 18 March 25th, 2009 07:55 PM
