Old October 18th, 2013, 10:56 AM   #1
help! my bike is falling apart! :(
what should i do?!?!
Old October 18th, 2013, 10:57 AM   #2
TheDementedDrummer
Present. Somewhat.
TheDementedDrummer's Avatar
Motorcycle(s): 2012 KTM Duke 200, 2011 Ninja 250r, 2011 Ducati Monster 796, 2014 Kawasaki ZX10r
Duct tape.
Highest speed on two wheels- 230 km/h
Beat that.
TheDementedDrummer is offline   Reply With Quote
Old October 18th, 2013, 11:02 AM   #3
i'm not sure. ducttape leaves residue
Old October 18th, 2013, 11:38 AM   #4
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
I see you have a hammer, looks like you are good to go what's the problem?
Old October 18th, 2013, 11:46 AM   #5
allanoue
allanoue's Avatar
MOTM - Sep '14
Prozac
Old October 18th, 2013, 12:14 PM   #6
massacremasses
Avid Kitteh Poster
massacremasses's Avatar
Motorcycle(s): 2006 Yamaha TTR 50 SUCK IT
semen
I powdercoat stuff Help me pay for my addiction
I say funny stuff. http://twitter.com/JustinPWNSyou sometimes...
I write like a 12 year old too, http://justinpwnsyou.wordpress.com/
massacremasses is offline   Reply With Quote
Old October 18th, 2013, 12:18 PM   #7
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Bubble gum and bailing wire, solved!
<-- Linky
Old October 18th, 2013, 12:23 PM   #8
.............what should i do?!?!
You need to find an engine and a tank !!!
......... what is the plunger for?
Old October 18th, 2013, 12:31 PM   #9
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
zip ties
Old October 18th, 2013, 12:58 PM   #10
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
you really messed it up, should look like this:
My Cafe Racer Build
My intro post
Old October 18th, 2013, 01:25 PM   #11
engine is in the mail, and the gas tank is just outside the photo
this bike will be my new dedicated race bike (other 250 served dual purpose, but no more)
todo:
straighten the frame (pull jig being built tonight, we'll see if it gets done in one night though... straightening hopefully tomorrow. the neck is twisted 2.5d clockwise and the bottom of the neck in about 1cm. once it's back in true form i will resurface the backbone (currently chipped paint from the bend causing some minor surface rust) and weld in ninja-300-style plate webbing for extra support on the backbone. once its all done its getting painted deep red with a bunch of clear on top. i'll probably swap to allballs tapered bearings just to keep up with the johnsons (current bearings are nearly shot after the last crash it seems) also theres really minor damage to the front wheel i will need to repair also.
gsxr rear shock coming in soon, which will need to be resprung and serviced
the front end is stock right now, 0.75 springs will go on with some diy preload adjusters and new oil. nothing fancy.
i have a yoshi full SS exhaust that has a crack in it that needs to be welded up, after its repaired it'll go on with cleaned out carbs. the engine in the mail is stock with only a few hundred miles but when it gets here it will get a full service along with a smaller head gasket.
the gas tank and race glass need to be resurfaced and painted. with the red frame i will go with a white body, red underbelly, with a grizzly bear on each side, rebel star above it. basically a californian flag. yellow (amateur) "256" plates front and back painted in.
levers
throttle housing
clipons
rearsets
vesrah pads
might need a new front disk
chain/sprockets
tires
Old October 18th, 2013, 01:48 PM   #12
...............the neck is twisted 2.5d clockwise and the bottom of the neck in about 1cm...................with the red frame i will go with a white body, red underbelly, with a grizzly bear on each side, rebel star above it. basically a californian flag..................
How did you measure the frame twist?
Did you measure the caster angle of the neck as well?
Old October 18th, 2013, 01:56 PM   #13
i used string to measure it all up and compare to a true frame then did the math to get degrees, this is a great video on how to do everything:
for the twist you need to level the engine mounts, then have a square that can reach the top, or a true jig.
if the frame is in a true square you can use string from top to bottom over the neck or inside the neck and measure the distances between the walls and the string at the top and bottom.
Old October 18th, 2013, 02:04 PM   #14
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Motorcycle(s): All of them
[IMG]
Stop molesting it!
Old October 18th, 2013, 03:36 PM   #15
Originally Posted by Nemesis View Post
Stop molesting it!
Old October 18th, 2013, 04:02 PM   #16
Felipe the Ant
Motorcycle(s): 2011 Ninja 250R SE GREEN!
Your rear wheel is backwards, try flipping it around and see if that helps
Trust me, I'm a banana!
Felipe the Ant is offline   Reply With Quote
Old October 18th, 2013, 07:04 PM   #17
............this is a great video on how to do everything..............
Indeed !!!
Thanks, Alex
Old October 19th, 2013, 05:35 PM   #18
this little frame is tough. after bending the box jig from the jack on the frame and only moving the head about 1mm, and then bending two steel tubes trying to bend it by hand, i've decided to cut the welds on the back bone and have my friend (expert welder) reweld it all straight with webbing support. i may have to replace the back bone all together. we'll see. its a pain in the ass.
Old October 19th, 2013, 10:13 PM   #19
Did you try some serious heat on the frame before applying force?
Pipes are very weak for that task, they bend easily.
If you anchor the steering head close to the ground, you could use the frame itself as a lever.
Just a couple of ideas, trying to avoid a cut and re-welding of those tubes of thin wall and maybe some difficult to weld alloy.
Old October 20th, 2013, 06:15 AM   #20
Asspire
Fix It Till Ya Break It
Asspire's Avatar
Motorcycle(s): 08 250RRrrrr
R6's come pre assembled..
Old October 20th, 2013, 09:33 AM   #21
You are right Hernan. I'll try with heat today. I blame the alcohol for yesterday
Old October 20th, 2013, 10:02 AM   #22
cuong-nutz
cuong-nutz's Avatar
I believe you did not have enough
HalfFast Racing Team
Old October 20th, 2013, 11:13 PM   #23
more alcohol, lots of heat, a sawsall, and plenty of swearing, and the tube is now straight with the swingarm. frame needs welding around 4 spots and im going to add gusseting
Old October 21st, 2013, 01:34 AM   #24
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Looks like your on the right track... Don't drink an drive
Old October 21st, 2013, 09:13 AM   #25
before
after cuts and bends
need to remeasure and adjust i think before welding. the top T is going to get remade
Old October 21st, 2013, 10:19 AM   #26
before
You had good 6~7 degree of twist there !!!
I wonder what kind of forces that frame felt in order to get that deformation.
Have you verified that both tracks for the head bearings are parallel respect to each other (if the head tube itself was bent)?
Old October 21st, 2013, 10:28 AM   #27
the tube itself is true though the races are going to get replaced anyway. theres a small ding on the top (my fault) that i'll need to tap back into shape before installing the new race. still not sure whether to completely replace the back bone or to try to rebend and lay down W's and just rejoin it. decisions decisions
Old October 22nd, 2013, 09:25 AM   #28
we welded the frame last night.
some of the smaller inner tube is pretty thin walled and melts very easily. extra steel was added under the welds. tonight i'll be adding in a little bit of gusseting before i scrub it and paint it red with lots and lots of gloss
Old October 22nd, 2013, 03:50 PM   #29
massacremasses
Avid Kitteh Poster
too bad you dont live closer. Id trade you some work for work getting that frame and everything powder coated.
Old October 22nd, 2013, 04:07 PM   #30
rasta
Your face
rasta's Avatar
Garage seems like a strange place for a plunger..
Old October 22nd, 2013, 04:58 PM   #31
you say plunger, i say dent puller.
Old October 22nd, 2013, 05:25 PM   #32
rasta
Your face
rasta's Avatar
Ooooh yea duh
Old October 23rd, 2013, 10:15 AM   #33
so all the welding is done. i added 1/8" plate webbing and a top brace around the aft of the backbone where it T's out to the side beams. i tried jumping on it and it seems good enough for government. i guess i'm colorblind or stupid, but the frame is now mostly yellow. i didn't notice until it was half way done and my brother mentioned it wasn't red. i was thinking about the welds and sealing them properly and didn't even think about color until i was through a can of yellow. so maybe i'll do the whole thing yellow...
Old October 23rd, 2013, 12:53 PM   #34
new todo:
- paint frame red
- install new head bearings
- fix ding in front wheel.
- gsxr rear shock - respring, service, install
- need rear swingarm adjusters and an axle
- front end springs and oil
- install the new engine
- repair yoshi exhaust
- redo controls
- need sprockets, have chain.
- needs new tires
- needs paint
- front brake need love
Old October 23rd, 2013, 04:21 PM   #35
Amazing rim repair by Papo Restrepo
Would you mind posting pictures of the webbing and a top bracing?
Old October 23rd, 2013, 04:33 PM   #36
sure i'll take some photos tonight. phone was dead when i finished yesterday so i didn't take any. unfortunately you can't really see the webbing underneath the top bracket that i made but you'll be able to see the enclosed topside. i'm not the best welder and since its structural and not external i decided not to sand/grind the welds afterward. so they're a bit ugly but they do what they need to do
Old October 23rd, 2013, 05:07 PM   #37
..........i'm not the best welder and since its structural and not external i decided not to sand/grind the welds afterward. so they're a bit ugly but they do what they need to do
Hey, we are not judging here but admiring and learning from your work and ingenuity.
Welds don't need to be pretty to be strong, I was always against grinding welds.
Old October 24th, 2013, 09:13 AM   #38
Old October 24th, 2013, 09:50 AM   #39
simook
looking good!
simook is offline   Reply With Quote
Old October 24th, 2013, 09:52 AM   #40
i took off the tire from the front rim last night and was trying to heat it and bend it but i think i'm going to need better suited tools than what i was using. also i forgot to take out the valve stem and it started to burn from the heat. oops.
Beware everything. Including falling trees. Alex Videos 24 June 13th, 2014 11:46 AM
Falling with style choneofakind Videos 10 March 5th, 2014 10:32 PM
Falling down Thorgrim !%@*#$%!)@#&!%@ I crashed! 30 September 14th, 2013 06:08 PM
Help! engine bolts falling out? az3200 General Motorcycling Discussion 15 December 18th, 2012 06:46 PM
Foam Pads falling apart chrisenglandus 2008 - 2012 Ninja 250R Tech Talk 14 April 11th, 2010 08:38 AM
